150mph/GT speedo - Mustang Evolution
Old 03-05-2005, 01:35 PM   #1
Send a message via Yahoo to 98GreenStallion
150mph/GT speedo
I need to know what all I would have to do and what all I would need to buy to make a GT speedo work in my car. I guess first all I would need is the white faced (94-98) GT guages which are like $60... Then I heard I would need to change the main drive shaft in the tranny or something like that?? Could someone explain that more?
Is there anything else that I would need?
http://images.cardomain.com/member_i.../402003_35.jpg
Mods: BV heads, cut and weld upper, fully ported lower, 216/225 cam, 1.73 RR's, 60mm TB, 19# injectors, new timing set, 25% UDP, CAI, SCT chip, PCV delete, EGR delete, MAC LT headers, O/R H-pipe, durablack cat-back...
www.rpm-mustangs.com
RDmotorsport
New dyno
193.8rwhp/238.9 rwtq
98GreenStallion is offline   Reply With Quote
Old 03-05-2005, 04:57 PM   #2
bluemustang's Avatar
its to much work and money
plus even at that your V6 wont ever see past 130 ever :yup:
Old 03-05-2005, 06:32 PM   #3
its very possible to have a v6 hit 130. once he fixes his problems with his top end swap, he will hit it easily.
Old 03-05-2005, 06:40 PM   #4
Danger Dude's Avatar
Buy a 98 GT speedo, install it then you have to remove the transmisssion tail and install at new gear in it. Rob (97Stallion) has done this
Dude my stang has been over 130 so his should be able. I run my car regularly down a closed runway right by my office. I have a 03 Cobra and a SS camaro that run beside me to get speed numbers since I have not installed a GT speedo yet
Old 03-06-2005, 02:09 PM   #5
i dont see how your cars can hit 130. well unless you have a chip and your speed limiter has been changed but other then your v6 will NEVER hit 130. cause believe me if it would have I would have done it a while ago when I had my V6
Old 03-06-2005, 09:20 PM   #6
I had a chip now my computer has been reprogrammed by Jerry at SCT
I have a raised RPM limiter to 6000rpm
I do not have a speed limiter anymore
I have a RPM Cam, Heads and intakes
As well as many more mods
My RWHP is almost double stock HP
Why is it so hard to believe a V6 getting to 130 ????
Old 03-08-2005, 01:01 PM   #7
Simple cause there limited at 118 thats why they cant hit 130
Believe me I had ALOT more mods then you do on my old V6 and it wasnt till I got tuned by Jerry when he was in Fordchip that I hit passed 120 and thats cause he took my limiter off so take that for what its worth
Old 03-08-2005, 01:11 PM   #8
Dude I have a lot more mods than that I only posted some of them. here is all including some that are not speed related. Other than instaliing a stroker kit there is not much for me to do except add a supercharger. I had a nitrous setup but sold it. hell I had a Vortech and sold it also. I like my car being N/A
RGR Stage 3 Intakes, RPM HP Heads and Cam, 60mm TB, 19lb injectors, Flex spacers, Custom 4R70W w/ shiftkit, FMS Aluminum Drive shaft, Jerry tuned SCT custom tuned, Trans cooler, MAC UDP, MAC CAI, cat back duals w/ Dynomax Ultraflows, MAC O/R H pipe, 3.73 w Trac lok, Bullitt struts & shocks, FMC "C" springs, Front and Rear Cobra sway bar, Steeda SFC's, Steeda STB, UPR Shark C&C Plates, 99 GT PBR Front Calipers, ultra clear headlights and corners, Ultra clear GT Foglights, Bullitt Pedals, 98 Cobra Rims
Future Mods:
Install my RPM BV heads with Harland 1.73 Adj RR's
In reality I could care less if you believe me!!! You keep bringing up You were jerry tuned to get past 120. I had a ford chip for 2 years with my speed limiter removed before I was jerry tuned over a year and a half ago. So I have been busting 120 often over 3 years. Sorry
I also have yet to see where anyone said they busted 120 without a tune or chip!!!!
Old 03-08-2005, 01:26 PM   #9
My car tops out at the governor...take that off and I'm almost positive I could top 130. Might have to try that sometime.
Old 03-08-2005, 02:08 PM   #10
I liek gramer
WhiteStang99's Avatar
I have hit 120 w/o having the limiter removed, but I was coming down a big *** hill, lol.
Old 03-08-2005, 03:53 PM   #11
man the limiter can be removed thats not even a problem
Old 03-08-2005, 05:13 PM   #12
So there we go if you werent tuned/ chipped youd never hit that 120 which is what im trying to say. I believe you done it but there it is in type that if you werent tuned you wouldnt get passed that. WHich is what IM trying to say
So thank you pass go now cause you proved me right
Old 03-08-2005, 07:32 PM   #13
Dude you were arguing with yourself. I did not see anyone post that they had surpassed their speed limiter who has not already been tuned or have a chip.
Old 03-09-2005, 07:53 AM   #14
Okay bud, I hit 130 on the dyno in 4th gear. I have seen minivans hit 120. I know what you were meaning with the whole chip thing, but in your first thread you made it sound like 3.8's were uncapable of hitting 130.
Anyhow, back to my 150mph speedo Q, exactly what do I have to change in the tranny and how difficult is this? Where do I buy this part? Then do I just get the new guages? Is this just the face I have to change or do I have to get a whole new cluster? Then, what do I have to change when I get 3.73s?
RDmotorsport
New dyno
Old 03-09-2005, 12:16 PM   #15
Yeah uncapable of hitting it without a chip. Maybe I was a bit unclear sheesh you guys take things to heart to much sometimes. Without a chip your not hitting 130 just not possible cause all V6s to my knowledge are limited at 118. That clear enough for ya bud
Seems to me you would have to PM 97 there to get your answer
Old 03-09-2005, 12:36 PM   #16
Please tell me where someone said they could hit 130 without a chip? It is pretty common knowledge that you can not go faster than the speedlimiter......
Not to mention the very person you told would never see 130 has a chip plus top end swap
Old 03-09-2005, 03:04 PM   #17
150 speedo is un needed .... dont mess with it.
Old 03-09-2005, 03:04 PM   #18
plus its harder to read...
Old 03-09-2005, 03:14 PM   #19
Alot of things are uneeded. I would like to have the GT Speedo just because I like seeing the 150
Old 03-09-2005, 03:14 PM   #20
Not for me
Old 03-10-2005, 08:09 AM   #21
LOL, look I know what my plans are, and I figure especially when I go S/C and shoot for 400+rwhp Ill need a speedo of 150mph at leaste. Plus like Brent said, It would be cool seeing more the 120.
RDmotorsport
New dyno
speedo off k28gt 1996-2004 Mustang GT 19 11-27-2009 02:42 PM
Hitting an Oil Slick at 150mph at7311 Pictures and Videos 15 05-04-2008 11:51 AM
speedo jimmy_beaner Mustang Parts for Sale and Wanted 2 05-13-2005 07:21 PM
I need a speedo jimmy_beaner Mustang Parts for Sale and Wanted 4 05-13-2005 07:21 PM
150mph Viper crash steedav6builder The Bar 39 12-30-2004 12:15 AM
02:22 PM
