Paint questions - Mustang Evolution
Old 04-10-2005, 09:58 AM   #1
Tbird232ci's Avatar
Paint questions
id google to find info, but i have no idea where to really start looking, so maybe you guys can help me out here
im looking to paint the top half of my turbo coupe, since the paint on the sides is still great, other than a few blemishes that it need to fix
my main question is, how do i blend sections of fresh paint to the old paint? do i spray the section, sand it all smooth with the old paint, then clearcoat the entire panel, or do i spray the paint, and clear, then blend it?
whats the process of blending the paints together?
Old 04-10-2005, 10:59 AM   #2
you have to wet sand the entire car and then just paint the areas were paint is needed, then blend the paint if its on the same body panel (say top off fender painted ut middle ist thats where you blend. then clear coat the entire car. that will make the whole car beutiful, if you just clear the section you had just painted on a car that old you willl easily be able to tell a difference.
Old 04-10-2005, 11:25 AM   #3
Yeh, the only problem with spot painting on an older car is the paint fade. My roommate painted the top of a hunter green eclipse he bought to sell, and somehow matched it perfect. I guess it's a matter of trial and error, might just be easier to just paint the whole car. Might take less time.
Old 04-10-2005, 11:37 AM   #4
but he says the bottom half is perfect, so there should not be a problem.
Old 04-10-2005, 11:38 AM   #5
true
Old 04-10-2005, 11:51 AM   #6
just paint the whole car its alot better that way.
Old 04-10-2005, 01:02 PM   #7
Bane-'s Avatar
are you talking like bottom half as in..below the body molding? if so then it might not be to bad since the molding is seperating the new/old paint
Old 04-10-2005, 02:14 PM   #8
basecoat usually is not the problem, thats why spot painting is so effective because you only replace the clear coat which is what ussually ****s up.
Old 04-11-2005, 10:44 PM   #9
Tbird232ci's Avatar
just under the doors is where id like to cut it in
i decided, if/when i can go through with this, ill do the whole car, theres enough small flaws throughout the car to piss me off
new paint!! 1980rustang 1979-1995 Mustang GT 7 01-26-2010 11:10 AM
Paint ? stangarang Mustang Audio & Video 8 10-17-2008 04:23 AM
Brother Corey has more paint questions!!! Danger Dude Mustang Audio & Video 20 02-20-2006 08:25 AM
Few quick questions about paint jobs DropTop_Stang Mustang Audio & Video 4 08-07-2003 04:16 PM
02:04 PM
