back seat question.... - Mustang Evolution
Old 04-23-2005, 08:50 PM   #1
project232's Avatar
Send a message via AIM to project232
Question back seat question....
i decided to lay my backseats down since no one ever rides back there. but.. they dont lay totally flat because of the lower part of the seat cushion. so my question is . does the bottom cushion of the seat come out? if so i think that would allow the "back" cushion to lay tottally flat.
please reply...
http://www.generationblueoval.com/GBO/GBOwebbanner.jpg
johnson-performance.com
2000 Ford Mustang V6
mods listed on Johnson-performance.com
project232 is offline   Reply With Quote
Old 04-23-2005, 09:13 PM   #2
It does come out... how I am not sure
There are two tabs underneath the backseats at the front.... put your hand under the front and slide it across and you will feel the two tabs... release these tabs and the seats come up and you now have to look for bolts I assume to unbolt the cusions
Old 04-24-2005, 12:21 AM   #3
The tabs are actually white lock mechanisms. You have to find a little button to push and they will release the bottom cushion. It comes right out. After that just pull your other seats down and it will be flat. You will experience a lot of road noise that way though.
Brandon is offline   Reply With Quote
Old 04-24-2005, 12:23 AM   #4
So no bolts to take out then. Good deal.
Old 04-24-2005, 07:17 AM   #5
project232's Avatar
thanks alot , i might give it a try and see how loud it is with the road noise and all
Old 04-24-2005, 10:10 AM   #6
it pops right out, just take a long phillips screw driver, not that long... but what ever, and run it under the edge of the bottom seat where it meets the carpet starting at the side of the car by the door and you will hit a bump, there is a little butting you push in on the front of that bump push it in with the end of the screw driver, when you hit the bump you will have to move the screw driver to the front of it, the button is NOT on the side, and then just pull up, same on the other side, the buttons are about 12 inches in from each side then the whole bottom parts just comes right out... not much to it.
Old 04-24-2005, 12:33 PM   #7
bluemustang's Avatar
Might as well get yourself a rear seat delete kit :yup:
How much back seat room Cblaze 1996-2004 Mustang GT 21 01-01-2010 08:28 PM
Back seat driver:confused: KustomSaturn The Bar 9 02-14-2009 08:44 AM
Back in the drivers seat 06blkGT New Member Introductions & Greetings 11 05-13-2007 02:00 PM
98 SEAT Question augustamustang Pre-2005 V6 Mustang 7 02-15-2007 08:16 PM
back seat project: Reloaded Thomas91169 Pictures and Videos 27 02-26-2005 01:17 AM
08:38 AM
