Mach 460 not ejecting CD's - Mustang Evolution
Old 07-25-2009, 01:09 PM   #1
a3705872's Avatar
My mach is not ejecting CD's at all I have degraded myself to using two butter knives to get it out. Is there any way to fix this problem? I don't want to spend 150 for a new Mach 460 head unit. I also don't want to change to an aftermarket head unit, I love my mach system...
a3705872 is offline   Reply With Quote
Old 07-25-2009, 02:29 PM   #2
Re: Mach 460 not ejecting CD's
Unfortunately, jammed cd's are an essential part of the Mach 460 audio system lol. When mine would do it, I would press the eject button, then pound the side of the console moderately, and the cd would usually eject the rest of the way. It's aggravating, but that's part of it I guess. Easiest solution is to use your Ipod if you have one. That's what I do.
I attached a picture of where I tap it when they get stuck...usually works better than putting something in the slide door and scratching the hell out of it and the cd.
Name:	GTInterior mach audio.JPG
Old 07-25-2009, 06:29 PM   #3
a3705872's Avatar
Attachment 20863
I want to setup my Zune in the mustang, but really dont know how to do this with a Mach. I know the 2005+ have an MP3 jack but 04 and earlier dont have one. Any help where to get one and how hard to install?
Old 07-25-2009, 09:21 PM   #4
Well, I don't know much about zunes. I just bought an adapter that plugs into the cigarette lighter for the Ipod. Its an FM transmitter that syncs with the radio stations to play the music. It also charges the Ipod.
I don't know if zune offers anything like that. That'd probably be the easiest way to run it with the Mach sytem.
I know some people ***** about sound quality. It isn't as great as a cd, but it isn't terrible, at least to me.
Old 07-26-2009, 07:36 AM   #5
jimmy_beaner's Avatar
Region: Iowa
You'll have issues with how your car sounds if you switch to an aftermarket head unit. It will still sound "ok" but nothing like it does with the Mach head unit. The reason for this is that the speakers are all set up at something like 3 ohms, and that isn't anywhere near a common resistance.
Old 07-26-2009, 05:47 PM   #6
OsirisGuy's Avatar
I disagree.
If you were to pick up an aftermarket speaker that's rated at 4ohms and measured its resistance you would not get a perfect number, it could be in the 3's or it can even go past 4, albeit aftermarket speakers are (read: should) much closer to the 4 ohm mark and much more uniform between individual speakers. Meaning normally a speaker may have a 3.4-4.6 ohm reading however a good set of speakers should have a closer value, say between the 3.8-4.2 ohms.
Usually I'll say to pick the same ohms when setting up amps and speakers. And an all Mach audio system is the best solution when any stock part is included in the audio set up. And yes the Mach 3 ohm configuration is quite an odd resistance. The "ok" sound may not be so much as the aftermarket headunit as it is the stock speakers.
Basically, without going into a physics lesson, the lower 3 ohm Mach speakers allows slightly more current to reach the speakers which affects the frequencies (read: sound) coming out of the speakers, while this shouldn't actually affect the sound quality, it does affect the power output (a.k.a. Wattage), which can be considered as making the speakers louder then they normally would have played. So if (making up numbers here) the Mach 460 Headunit each produces 100 watts at 4 ohms (pretend you have aftermarket speakers) then the stock Mach 460 HU playing through 3 ohm speakers may have a 105 wattage.
The vice versa is true, if you go from 3 ohm to 4 ohm then the wattage may drop from say 100 watts at 3 ohm to 95 watts at 4 ohm.
It's really all a way to understand the performance of each component and understanding how they all will react with each other.
You can also take a look at this
Mach 460 Information
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 07-27-2009, 08:55 AM   #7
Region: Iowa
Originally Posted by OsirisGuy View Post
I disagree.
Disagreeing is well and good, but I've switched several head units in, and they all sound like complete ***. I hate how the Mach 460 head unit has issues playing CD's... but I refuse to make the car sound like *** so I can play CD's. I've gotten to the point now where bays 4 and 6 will both work, even change CD's back and forth.
As a warning to the OP, if you decide to switch head units in... don't be surprised when it sounds like ****. There is a lot more to a sound system than whether the ohms match up.
Old 07-27-2009, 09:10 AM   #8
^^ the fact you had an eclipse and it still sounded like caca is proof enough for me.
When I eventually swap head units, it will be a full system swap as I know the ford speakers aren't exactly steller either.
Old 07-27-2009, 03:18 PM   #9
OsirisGuy's Avatar
Jimmy - what HU did you run? I've never been a fan of eclipse myself. I had a low end Alpine when I got my car and now I have a higher end Pioneer and both sound great; speakers and amps are stock.
Did you change out your amps or speakers, where either or both of those good? I'm just very all surprised at that.
As for the quality of the Mach system, I personally like them I just wish they would work after a few years of use To me it's either all stock or all aftermarket.
OsirisGuy is right
2002 Mustang GT
Old 07-28-2009, 04:29 AM   #10
Region: Iowa
I had an eclipse 3100. I just changed HU. I messed with settings for weeks... sounded like complete ****. Switched the mach unit back in after it was taken apart to remove stuck CD's and sounded amazing as soon as it was plugged in... compared to the eclipse. Then you mess with the settings and it's just so much better.
Old 07-28-2009, 01:34 PM   #11
Ohms shouldn't have anything to do with sound quality, unless you cause components to overheat due to running too low of a resistance. Its easy to overheat things if you have them cranked up and running at an unsupported resistance. If the mach system has amps and such, it probably has something to do with the way they recieve the audio signal from the headunit.
I get pretty good sound from my Iphone's ipod by using a Sony cassette tape adapter that I originally bought for my Sony Discman. Yes, the CD playing walkman thing from like 15 years ago. (my car has a CD/tape mix HU)
ThaWill is offline   Reply With Quote
Old 07-28-2009, 03:28 PM   #12
mine only does this when I have thick labels on the top of them, usually it never sticks
Old 10-27-2015, 03:01 PM   #13
99 RioRed SVT's Avatar
i have the same issue. it didnt do it for the first couple months i owned my Cobra but for the past few months i have been stuck listening to lame *** FM or the same ONE cd that is stuck in there. i hit eject and i hear a sound like its trying to spit it out then nothing. i tried the banging on the side of the console maybe im not hitting it hard enough? and i really dont want to try the butter knives because this is a special CD to me, id rather destroy the head unit than mess up that CD. (i dont want to do either)
so i was just posting to see if anyone has come up with new ideas since this thread lost its attention. Thanks in advanced!
1999 SVT Cobra: Rio Red, Black Leather, 5 speed, Short Throw Shifter, Lowering Springs, 3.55s. Full Engine Rebuild, Ported Heads. (Updated as of 3/18/16)
99 RioRed SVT is offline   Reply With Quote
Old 10-27-2015, 03:05 PM   #14
Attachment 20863
thats where i been hitting mine at but my Mach 460 doesnt look like that would that make a difference (that looks like the one i had in my 04 40th anniv. GT but it never had a CD stick...) the pic i posted is of my current mach 460 in the 99 Cobra
Old 10-27-2015, 03:15 PM   #15
6 year old thread...but... Butter knife or take the unit out of the car and disassemble it. I've done both.
Sent from my XT1045 using Tapatalk
mach 460 charkelly9 Mustang Parts for Sale and Wanted 5 06-15-2005 11:55 PM
mach 460 whitev6stang03 Mustang Parts for Sale and Wanted 4 02-04-2005 02:24 PM
Mach 460 megax29 Mustang Audio & Video 6 09-08-2004 02:25 PM
mach 460 Warfire80 Mustang Audio & Video 15 03-03-2004 09:34 AM
Mach 460 starboarder2004 Mustang Audio & Video 19 01-20-2004 09:23 PM
08:31 AM
