Pulsing Woofer - Mustang Evolution
Old 05-04-2005, 01:32 PM   #1
StreetRacer4371's Avatar
Pulsing Woofer
i have a 95 gt and i put a woofer in my trunk and it worked good for about 1 week then all of the sudden...my woofer started jumpin in and out and makin this spaceship type sound...anybody know what it is or how to fix it?...i dont know much about the speaker stuff im a motor man
http://www.mustangevolution.com/foru...ine=1102399529
Its not revenge... Its PUNISHMENT
StreetRacer4371 is offline   Reply With Quote
Old 05-04-2005, 02:44 PM   #2
bluemustang's Avatar
what kinda sub and what kinda amp you have
Old 05-04-2005, 03:18 PM   #3
I liek gramer
WhiteStang99's Avatar
Probably interference. Make sure that all the wires from the front of the car to the back are shielded.
Old 05-04-2005, 08:50 PM   #4
pyramid amp and spl sub...what shielded mean?
Old 05-04-2005, 09:04 PM   #5
I liek gramer
it means that interference won't bother your subs. Just look for shielded wires or cables when you buy some. They will protect the wire and signal.
Old 05-04-2005, 11:51 PM   #6
Kiljosh's Avatar
Don't run your power and RCA's right next to each other run them down opposite sides of the car.
Check to see if you crossed negative and positive on on of the subs some of them you have to wire in reverse or something.
Make sure your box is sealed nice, I don't know if you made it but if so and you have a lot of air leask you may ot have enough pressure inside to support the sub's suspension and could be damaging it.
Do what whitestang said and check anything I have said that might apply.
Lay off on the bass untill you get it straightened out.
Old 05-05-2005, 05:20 PM   #7
Yeh, sounds like interference to me. Run your rca's on the opposite side of the car, otherwise you get a weird space ship like sound.
Old 05-05-2005, 10:10 PM   #8
it ended up bein a bad ground....now i have another problem....when i turn the main output on the amp past half way it started doin something diffrent but kinda the same.
Pulsing in Pedals njstang97 Pre-2005 V6 Mustang 13 10-05-2004 07:15 AM
08:28 PM
