same gauge wire for mono amp as multi-channel? - Mustang Evolution
Old 05-04-2005, 08:15 PM   #1
Send a message via AIM to tedness
several questions:
- if i un-install my subs/amp, can i keep the same wiring setup running from my battery to my trunk w/ nothing hooked up to it? will doing this drain power from the alternator if there is nothin plugged in to the wires?
- can i use the same gauge wire to power a multi-channel amp for component speakers?
in a nutshell i wanna remove my old subs and amp and drop new amp and components without having to re-wire everything from the firewall. is this possible?
tedness is offline   Reply With Quote
Old 05-04-2005, 08:36 PM   #2
If you unhook your amp from the power wire, take out your fuse, hence no power beyond that point to the wire. And yes, you can run the same gauge wire to the multi channel amp without a problem.
Old 05-04-2005, 10:26 PM   #3
fuse? eh where is that exactly. im electronically impaired.
Old 05-04-2005, 10:43 PM   #4
19ClearCobra96's Avatar
Region: Nebraska
Send a message via AIM to 19ClearCobra96 Send a message via MSN to 19ClearCobra96
under the hood shortly after the battery.
19ClearCobra96 is offline   Reply With Quote
Old 05-05-2005, 12:53 AM   #5
Kiljosh's Avatar
I stored my car all winter with the fuse by the battery out and the positive out of my amp and nothing went wrong.
Old 05-05-2005, 06:21 PM   #6
That would be because there is no power going to the wire beyond where the fuse goes. Doh. And yeh, look under your hood, look for a wire running from your battery that doesn't look stock, unless someone did an incredible install. There should be a case on it about a foot down, open it up, there'll be a fuse inside, pull that fuse out and vuala, no more power.
Gauge Wire Routing w/CDC gauge pod tripod_2005 2005-2010 Mustang GT 13 04-30-2010 12:46 PM
4 Gauge wire help blue-saleen Mustang Audio & Video 22 04-13-2010 12:55 PM
fs: 2 jl 10" subs, 500w mono amp, custom box & wall tedness Mustang Parts for Sale and Wanted 3 05-12-2005 11:42 PM
Which wire does the A/F gauge need to be spliced SpectorV General Mustang Discussion 16 08-23-2004 03:12 PM
Guys 2 gauge wire isnt cheap Brent Mustang Audio & Video 18 05-13-2004 12:18 PM
04:03 AM
