Stuck Bolts on shifter - Mustang Evolution
Old 08-29-2009, 09:01 AM   #1
blue-saleen's Avatar
Region: Utah
I am putting in an MGW short shifter (thanks to those of you who helped me pick it) but i cant get past the second step!!! Those two 10mm bolts on the left of the shifter are stuck, and the top one is pretty stripped. What should i do?
blue-saleen is offline   Reply With Quote
Old 08-29-2009, 10:11 AM   #2
Re: Stuck Bolts on shifter
do you mean the head of the bolts are worn so you cant turn them?
Old 08-29-2009, 09:03 PM   #3
Tape's Avatar
by pass them and just remove the 4 mounting bolts and remove it all as one piece
Tape is offline   Reply With Quote
Old 08-29-2009, 11:39 PM   #4
OsirisGuy's Avatar
How about a pic? There's a few bolts I could be thinking of. There should be the 4 bolts that hold the entire shifter assembly in and that's all you would need to remove the shifter. The two bolts directly on either side of the arm do not need to come out and I advise against it.
I'll try and take some pics tomorrow if you still can't get it.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 08-30-2009, 12:26 AM   #5
upton7's Avatar
ya its easier to remove with the shifter handle since you can pull with it.
Old 08-30-2009, 09:42 AM   #6
two two front most bolts are a pita to get out due to angle is it those
Old 09-01-2009, 07:35 PM   #7
Region: Utah
sorry it took so long to reply. I dont even know if i put the picture on right. i did it as an attachment??? yes i know im a noob. anyway, its the two bolts on the side in the middle of the picture. can i really just remove the four that hold the thing in? why would the instructions tell me to remove these stupid two bolts?
Old 09-01-2009, 07:52 PM   #8
SaleenFiend's Avatar
They tell you to remove those so that you can get the boot off without damaging or having to cut it. If you are good and patient go ahead and leave the shifter handle in place and start removing the bolts that are holding the metal trim down (the trim holds the boot down) then use time and patience to pull the boot over the shift handle... it will take time and you will stretch it. Then you have 4 more bolts that hold the actual shifter in place.
Old 09-02-2009, 07:18 AM   #9
those bolts you can see in the pic are just for that ring to hold the rubber boot down. Its not the end of the world fi those break as you can get new clips and such and replace them~ but I would personally put some penetration lub on them to soak really good and then try to remove them. You can spray the underside of the bolt as well as you can see it from under the car (tight fit but its there)
Old 09-03-2009, 05:09 PM   #10
Region: Utah
thanks so much everyone. I'm going to try few more tricks on the bolts one more time on Saturday, and if that doesnt work ill just slide the boot over it. wish me luck
shifter knob and short throw shifter help blue-saleen Pre-2005 V6 Mustang 7 05-19-2009 07:52 PM
Stage 8 bolts, but no bracket bolts? CreationNation 1979-1995 Mustang GT 1 04-13-2009 10:00 AM
shifter linkage on a toploader with hurst shifter gardgriff24 Classic Mustangs 7 03-02-2009 10:34 PM
03:15 AM
