Need HELP with my system!! - Mustang Evolution
Old 06-13-2005, 02:07 PM   #1
BuddyLee's Avatar
Ok, i have problems with my subs and amp, and there are so many possible causes, i have no idea where to start. so i will start with the problem:
My amp will turn off after a while, its a different amount of time each instance. Alot of times, when i turn up my volume loud, or fade the stereo towards the back, it will shut off then. Today, i adjusted the ground wire, and the line output converter and now the amp will turn off after a few seconds.
At first i thought it was the ground wire. I have a ring terminal attached to a bolt on the body, and i made sure to sand all the paint off. It isnt tightened all the way, but it still makes contact, could that cause a problem?? Also, where the ground wire goes into the amp, there is a lot of access wire sticking out, but there is still enough to make contact with the connection in the amp, but i didnt know if that could be the problem.
also, i think it could be line output converter. Its pretty ghetto, like the back of it is totall broken off, i taped it back on, haha. is there any way to test if this is the problem, besides buying a new one.
i figured the amp is shutting off to protect itself, ive heard amps sometimes shut themselves off when there are problems, so i assume this is what is going on, but i suppose my amp could be bad.
finally, whenever my amp is on, my subs do not hit hard at all. I had the same setup in my integra, and it hit 20 times harder. I figured since i am using a line out converter, and its tapped into my rear speakers, that could be the reason why it is so weak. That, and the fact that i think on my subs is blown, but its hard to tell because they hit so weak.
Please help me out here. thanks
out with the old: 93 turbo integra
in with the new: 03 mustang
BuddyLee is offline   Reply With Quote
Old 06-13-2005, 02:36 PM   #2
Need exact setup setup and specs on the Amp and subs. Need to know exactly how you have them wired.
Old 06-13-2005, 03:34 PM   #3
BuddyLee's Avatar
subs are both 4 ohm, svc. around 125-150watt rms. amp is 2 channel 400 watt, about 150 rms watts.
Old 06-13-2005, 03:37 PM   #4
So nothing is bridged? You simply have one channel going to one sub and the other going to the other sub?
What subs are these and what model amp?
Sounds like the amp is going into protection mode when you crank it up which means its wired up wrong or pulling lower ohms than its suppose to...
Old 06-13-2005, 03:41 PM   #5
coule it be getting to hot?
Old 06-13-2005, 03:54 PM   #6
Possibly but I do not think thats the problem
Old 06-13-2005, 06:16 PM   #7
BuddyLee's Avatar
nothing is bridged, its just like you said. the subs are mtx road thunder.
Old 06-20-2005, 08:15 PM   #8
Well, your amp is running in 4ohm mode, the subs are 4ohm, dunno what to tell you without personally looking at it...
Old 06-20-2005, 11:07 PM   #9
BuddyLee's Avatar
well i found out the problem, and of course, all the problems were cause by one little thing. one of the speaker inputs on my LOC was wired backwards....d'oh
need opinions on new sound system for 98 cobra with Mach system tennisfreak802 Mustang Audio & Video 7 04-28-2010 01:29 PM
My New System Rellik Mustang Audio & Video 12 03-16-2005 08:51 PM
Next System Shahrum Mustang Audio & Video 18 04-18-2004 10:17 AM
What my new system will be. Dom Mustang Audio & Video 9 12-21-2003 12:32 AM
OK, Here's my system as I'm seeing it now. Dom Mustang Audio & Video 4 11-17-2003 12:09 PM
05:00 AM
