Got my bullitt petals on - Mustang Evolution
Old 06-27-2005, 03:56 PM   #1
they came from rdmotorsport.com (97stallion) in record time. They were a BIOTCH to put on.... the dead petal was easy (just had to take the entire bracket off by removing the kick panel and side door jam panel to get to it) you can not just pry it off... to hard. I used a hammer to tap the new one in and it went fine. The accelerator petal also wasnt to bad.. the pin just tapped out with a little force and a vice to hold the assembly. The throttle cable was a little pita but not to bad.
here is the fun part... the brake and clutch petals... very very frustrating... they in NO WAY just slide over... it took forever and I thought I ripped the side of one, which you can do pretty easy. I finally worked them around... omg.... if you have a short fuze do NOT try this lol.
Old 06-27-2005, 04:14 PM   #2
Hm...dead pedal popped right off and back on for me. Brake pedal slid right on after I found the right tool, my problem was getting the pin out on the gas pedal, O well.
Old 06-27-2005, 05:43 PM   #3
KyleUSAF's Avatar
Send a message via AIM to KyleUSAF Send a message via MSN to KyleUSAF
but i bet it was all worth it wasn't it Brandon
oh and :worthless
Originally Posted by Darkshadow
I could say nothing for my complete awe. He then. confidantly, purchased the gallon.
KyleUSAF is offline   Reply With Quote
Old 06-27-2005, 07:41 PM   #4
I liek gramer
WhiteStang99's Avatar
The dead pedal should have been much easier than that...
The brake pedal isn't so bad once you realize you have you whoop on it a minute and use something like a screwdriver to assist in the whoopage.
Old 06-28-2005, 03:31 PM   #5
I realized why your petal was so easy to put on Brad.... cuz you have an auto...if i had the petal the size of my foot to put on it would have slide on rather easy also... try putting a clutch petal or even worse a brake... OMG
Old 06-28-2005, 04:01 PM   #6
I'm sure it goes on the with the same pain, I just found a tool that did it right.
Old 06-28-2005, 05:02 PM   #7
fast64's Avatar
i bet i had the hardest time put my bullit pedal covers on!
GO BRAVES
Old 06-28-2005, 05:15 PM   #8
did you have the assembly out?
Old 06-28-2005, 05:41 PM   #9
He had to fab his own up if I remember right.
Old 06-28-2005, 05:47 PM   #10
all you got to do is JB weld the suckers on...
Old 06-29-2005, 06:54 AM   #11
fast64's Avatar
yeah, i had to cut a ton of metal off my pedals to make them fit, plus modify the gas pedal since it came from a fox
GO BRAVES
02:23 PM
