horrible interference problem - Mustang Evolution
Old 10-11-2009, 09:53 AM   #1
ok heres my problem......everytime i turn a light on, turn signal, touch any thing, say if i tap the dash board the car speakers react and make noise, they run with the engine, heck talking makes them react.....
it just started out of no were a while ago, i bought a fresh battery and regrounded the amp still no help. it very annoying and decently noticable
any ideas?
eddie1 is offline   Reply With Quote
Old 10-11-2009, 05:01 PM   #2
OsirisGuy's Avatar
Re: horrible interference problem
Do you have any type of hands free included device installed?
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 10-11-2009, 08:17 PM   #3
nope.
Old 10-11-2009, 08:54 PM   #4
OsirisGuy's Avatar
Well it sounds like there is a feed into the lines somewhere. You grounded the amp so I'm assuming you're running aftermarket stuff? Is your ground against bare metal? If there's not a good enough connection they circuit will look to ground itself elsewhere. I would recheck all connections on anything that is different. Check individual components if you have to to see what is causing the problem.
OsirisGuy is right
2002 Mustang GT
Old 10-12-2009, 07:17 AM   #5
you can try unhooking the amp (if your front speakers are not runing on it) to see if that is the source of the issue.
Old 10-16-2009, 08:20 PM   #6
67mustang97's Avatar
Region: Vermont
Do you have all the amp wires run in the same location? If you do I'd try running the power wire on the opposite side away from your RCA cable. You could also try installing a power filter. I'd also double check your ground wire you could try a different location.
Old 10-16-2009, 10:03 PM   #7
outlawfrog's Avatar
Definately sounds like a grounding prob. Not only check all pwer and ground connections, but also check all of the wire, just to make sure there's not a damaged spot.
1996 GT, 5-speed, Moonlight Blue, Opal Gray leather, Flowmaster Cat-Back exhaust (Delta 40 series), BBK cold air intake & 75mm TBI, Super Chips programmer.
Originally Posted by 67mustang97 View Post
outlawfrog is probably right
Originally Posted by outlawfrog View Post
I might pull an "osirisguy", and make that my new sig quote!
outlawfrog is offline   Reply With Quote
Quick Links interference: MarkuzLS1 ME Site Help & Announcements 13 08-30-2007 02:42 PM
horrible way to die meteorachick The Bar 11 03-29-2005 09:05 PM
Wow.. this is horrible.. wiarumas The Bar 16 03-22-2005 01:24 PM
This is horrible Seph The Bar 38 12-31-2004 06:07 AM
this is horrible Warfire80 The Bar 8 10-06-2004 08:37 AM
04:08 AM
