mach 1 grille delete problems - Mustang Evolution
Old 08-13-2005, 03:36 PM   #1
Send a message via AIM to charkelly9
i have the top bolts unscrewd from my honeycomb grille; however there are some bolts upside down latching the bumper to the old grille i cant remove or access.. does anyone have some instructions or anything thanks
charkelly9 is offline   Reply With Quote
Old 08-13-2005, 04:02 PM   #2
Re: mach 1 grille delete problems
anyone? this is a *****; the plastic screws suck and ive broken like 3 of them
Old 08-13-2005, 05:09 PM   #3
slvr2000stang's Avatar
this might help.
http://www.classicdesignconcepts.com...liminator.html
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 08-13-2005, 05:10 PM   #4
you just got to pull the bumper back after removing the two push pins that hold the top pointed areas of the bumper on (gives more flexing) or you can just remove the whole bumper to do it.... they are a pita.
Old 08-13-2005, 05:47 PM   #5
99CobraVert's Avatar
char did you get the 2 piece or 3 piece kit? and leave feedback on how it went, i bought the kit on ebay today and im sure whatever probs you are having i'll have too. thanks! :thumbs2:
2001 Saleen S-281SC
Kenne Bell SC w/ intercooler, 90mm maf, mac cai, 70mm throttle body, 3:73 gears, Kenne Bell performance chip
99CobraVert is offline   Reply With Quote
Old 08-13-2005, 05:56 PM   #6
the issues I have seen is that some kits come with the wrong radiator grill peice, if one at all. You must have the correct one else you have a gab where the hood meets the front bumper above the horse.
Old 08-13-2005, 08:19 PM   #7
I bought the 3 piece kit for 20$ used from a friend that bought it directly from ford. Awesome condition with everything included
Old 08-14-2005, 11:52 AM   #8
i guess im going to buy a 7mm socket and i ll take pictures of the project... could i make a how-to for this? I sounds amazingly easy but you'd be suprised- dont believe then just try to take off your grille and put it back on
Old 08-14-2005, 01:01 PM   #9
I liek gramer
WhiteStang99's Avatar
Yes, please make a how-to for it!
Then send it to me so I can edit it, and I'll get it put up on the site through Smurfin or someone.
Old 08-14-2005, 07:44 PM   #10
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
yea i remember when i pulled the grill out it was a problem. i just broke a lot of the stupid plastic screws, used a ton of force and popped the thing out. after i got my energy back i used bondo to plug up the holes, then sanded and painted it so it looks like new. i didn't use the best method but it worked for me.... i don't know what your kit comes with or if you need to save the original screws or not.
good luck man
I_luv_HP&trq is offline   Reply With Quote
Old 08-15-2005, 03:09 PM   #11
take many good pictures and write it up and ill put it up as a how to and credit you to it. IF you get many good pictures and all that.
Old 08-15-2005, 04:46 PM   #12
heres a bunch of pictures
Old 08-15-2005, 05:36 PM   #13
heres the pictures and i'll definity need to explain some... because i've found theres a variety of ways to do this install-some destructive... Like
A. Remove bumper cover then use 7mm socket wrench to unscrew bolts holding bottom of honeycomb grille to the top of the bumper.
B. Remove top bolts above honeycomb grille then bend back the urthane bumper to use a very small 7mm socket on the bolts
C. The easiest way... and the way i completed mine was to unscrew top bolts to honeycomb grille along with top bolts to bumper then bend back the grille and use a box cutter and dremmel to break off the back plastic pieces holding the bumper and grille together. This way their will be 4 broken pieces of plastic still screwed to the bumper but yet not held to the grille.... now use a flat screw driver to bend the top of the nut then twist the bolt free. After that; if you have the 3 piece kit remove the plastic covering radiator and place new piece in (pictured above) then put down the other plastic piece from the kit across the bumper and use the two screws from before to put that in... next put the pony in place and align it with the two screw holes..- the screws that held your bumper to honeycomb grille will screw the pony into place perfectly.
this is only a rough overview.. i have more details and legistics spector so if this starts to get the HOW-TO going then awesome... also i can pieces apart and take more photos in minutes if necessary..
ID:	10305   Click image for larger version
ID:	10307   Click image for larger version
ID:	10309   Click image for larger version
ID:	10311   Click image for larger version
ID:	10313   Click image for larger version
ID:	10315   Click image for larger version
Old 08-15-2005, 05:42 PM   #14
nice, ill make it a How to asap
Old 08-16-2005, 10:25 AM   #15
Pony Ride's Avatar
I don't know why you removed your bumper to do this mod. It's not necessary! Once you remove the screws from the top, you can carefully pull the grill forward, which bends the top of the bumper where the bottom of the grill is attached to get access the bolt heads for removal. IMO, care and patience using this technique is easier than the extra work of removing the bumper.... worked for me anyway.
Pony Ride 2!! 2007 Grabber Orange GT Premium with 5-speed manual transmission
Pony Ride is offline   Reply With Quote
Old 08-16-2005, 11:40 AM   #16
I didnt acutally remove the bumper... i stated it as an option.. i broke the small plastic pieces under the honeycomb grill (really fast and easy plus the grill can still be used later on but can be bolted to the bumper again) i was only giving spector all the different ways and options to swap the grill that i know about... and yes you can bend the grill however... if youve been in a wreck or have a fiberglass bumper your outta luck... also if you bend the grill forward the space is still very very tight and most ppl dont have a ratchet that will fit down there to remove the 7mm bolts.. And still be very careful bending the grill forward even with a urthane bumper like mine the paint can crack around the sides-almost started to happen to me
Old 08-17-2005, 09:54 PM   #17
!!!WOOT!!! spector V deserves the credit for this how-to.... unbelievable job!
Old 08-19-2005, 12:51 AM   #18
Send a message via AIM to tedness
i got the 3piece version from mustangtuning.com who outsourced steeda.
ya it was ***** to have to ratchet behind the bumper. half the time i was afraid i'd snap it off at one place or another. but it all payed off
tedness is offline   Reply With Quote
Old 08-19-2005, 01:25 PM   #19
pictures make the how to
wtt my billet grille for mach 1 grille/chin spoiler tigerfan2771 Mustang Parts for Sale and Wanted 1 07-11-2008 07:27 AM
V6 Hood grille delete DMAC Mustang Audio & Video 5 05-03-2005 10:46 PM
grille delete/chin spoiler...the hassles tedness Mustang Audio & Video 13 03-23-2005 04:51 PM
pic request of mach 1 chin spoiler and grille delete.... project232 Mustang Audio & Video 16 03-08-2005 08:00 AM
Mach 1 Delete StangGt804 Mustang Audio & Video 11 01-03-2005 02:31 PM
10:23 AM
