Running the power wire - Mustang Evolution
Old 11-07-2005, 12:28 PM   #1
cterie's Avatar
I have a 2000 Mustang GT and Im trying to find a hole in the firewall so I can run a power wire to my amps. Anyone know where I can find one?
cterie is offline   Reply With Quote
Old 11-07-2005, 01:12 PM   #2
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Re: Running the power wire
Let's see it was a while since I did mine....the easiest place to see one is by looking under the hood, not the inside of the car. I believe it was between the brake drum and the steering components. It's just a little black grommet that you'll have to use a knife to make a whole to put the wire through, and then it'll close around the wire so don't make the hole unnecessarily big.
DarkShadow is offline   Reply With Quote
Old 11-07-2005, 01:26 PM   #3
cterie's Avatar
do you know what side its on? The side with the battery or the other side? Im working right now I'll have to look better when I get home. But its good to know that there is one.
Old 11-07-2005, 01:35 PM   #4
I would say look on the drivers side first by the steering column and such. I believe that is where a number of people that have run battery relocation kits have run their wires as well. I think there is at least 1 extra hole there if I remember right.
Edit: Oh yeah, and, Welcome to the site :beer:
Old 11-07-2005, 03:21 PM   #5
I liek gramer
WhiteStang99's Avatar
there's definitely one where Smurfin said, under the dash on the driver's side. It has a rubber grommet thing around it.
Old 11-07-2005, 04:43 PM   #6
DarkShadow's Avatar
Yes, on the driver's side between the brake drum and the steering components.
Old 11-07-2005, 06:06 PM   #7
You guys forget..he has a gt, a little harder to get in there and find one. Rob is about the only one that can look and find a spot.
Old 11-07-2005, 06:51 PM   #8
I liek gramer
It's still there, haha.
Old 11-07-2005, 07:26 PM   #9
DarkShadow's Avatar
Yep it's still in the same spot.
Old 11-08-2005, 07:30 AM   #10
cterie's Avatar
ok thanks alot guys I found it. It really wasnt hard at all I was just missing it.
Old 11-09-2005, 02:05 PM   #11
Tbird232ci's Avatar
i thought thats where the clutch cable passed through?
power wire? tylbrune Mustang Audio & Video 2 02-16-2010 12:10 PM
Running power around the factory amp to the speakers Kiljosh Mustang Audio & Video 0 01-06-2007 09:17 PM
running problem less power jedwards242000 Pre-2005 V6 Mustang 7 08-01-2006 03:23 PM
WHere to wire A/F ratio sensor wire?!? TheSarge Pre-2005 V6 Mustang 0 09-04-2003 02:00 AM
I need a power wire to splice into. Rellik Pre-2005 V6 Mustang 22 07-30-2003 11:56 AM
02:17 PM
