12000K HID Kit - Mustang Evolution
Old 11-07-2005, 04:34 PM   #1
Dark02Pony's Avatar
Send a message via AIM to Dark02Pony
12000K HID Kit
last kit i had which was an 8000k ive upgraded to 12000K, I am in the process of installation ( its a plug and play kit ) and i noticed that theres 3 wires left over, 1 seems to be a ground wire, and theres 1 split prongs that fit into the stock light socket though i noticed theres only prongs on the driverside. It all hooks up to a relay then to the battery so it would possibly make sense that i only need to wire them to 1 socket and the relay puts the power over to the passanger side as well..should this be fine ? My 8000k kit a friend installed so i never got very hands on with a kit except for popping the lights in and mounting everything. Thanks a lot.
http://img.photobucket.com/albums/v6...rtandgrill.jpg
Operation: Evolutionization.......Member #3
Originally Posted by MonteCitan
Ford Motor Company = FoMoCo..
what does that make Honda Motor Company????
Originally Posted by Nicole
Mineral Gray is such a hott color. Much better then orange
Dark02Pony is offline   Reply With Quote
Old 11-07-2005, 05:06 PM   #2
Re: 12000K HID Kit
how much do these cost?
and those are goingto be some blue ****ig lights.
i heard 4-5 k is the best because its provides the whitest light
Old 11-07-2005, 05:11 PM   #3
Dark02Pony's Avatar
Re: 12000K HID Kit
i got em for 230 shipped, if you go on ebay theres some companys on there selling tons of them for cheap brand new with a warrenty
Old 11-07-2005, 05:39 PM   #4
Re: 12000K HID Kit
HID with the standard headlight design (on non HID cars) are not efficient or works well... i found a very nice and long site about this, it was very interesting.
Old 11-07-2005, 05:44 PM   #5
I liek gramer
WhiteStang99's Avatar
Re: 12000K HID Kit
Link?
Old 11-07-2005, 07:30 PM   #6
Re: 12000K HID Kit
I'll try talk to my friend (headlight guru) and get a good explination
-Denver
2002 Mineral Grey GT, 5-speed: MGW short throw, JLT CAI: SOLD
2002 Electric Green V6, Auto: SOLD
greenpony02 is offline   Reply With Quote
Old 11-07-2005, 09:10 PM   #7
Re: 12000K HID Kit
www.danielsternlighting.com <---the link mentioned is most likely Dan's
Quote The Headlight guru
"Adding a lightsource that is not intended for your headlamp or any optical device is a poor choice. Putting HID, LED, neon, whathaveyou in a optical system not intended for these systems will not perform as intended. An HID lightsource produces a light arc vs. the straight filament in halogen and incondesent light sources. A round peg in a square hole.
Putting a much higher output lightsource in place of another will create glare problems as the optics of the headlamp will not be able to cope with the increased light output. Headlamp development is a very complicated process. There is a reason that headlamp laws are by far the greatest and most complete of all the automotive requirements. Check out FMVSS and see how much bigger 108 requirements (headlamps) are to the others.
Higher K temps will make your headlamps appear brighter. Not actually produce more light.
For performance, use a standard boring 9007 (HB5) bulb. No tint, no fancy packaging, no highwattage, no bulb over $15, no BS. Add relays or larger wires per Dan's site for maximum performance.
Dont forget to reaim your headlamps after suspension changes, adding a heavy stereo, etc."
-HIDGolf...vwvortex.com/tdiclub.com/mercedesshop.com/pagoda113.com
-Denver
Old 11-08-2005, 11:05 AM   #8
Dark02Pony's Avatar
Re: 12000K HID Kit
^ nice write up indeed, the 12000k seem much much brighter but of course its only daytime so we'll see tonight and ill get pictures also
Old 11-10-2005, 11:40 AM   #9
wiarumas's Avatar
Re: 12000K HID Kit
i like the idea that they are $15 also
HID kit SaturnMan8227 Pre-2005 V6 Mustang 42 03-06-2010 08:19 PM
HID Conversion Kit RudyJ 1996-2004 Mustang GT 8 10-16-2009 06:30 PM
what do you guys think of this HID KIT Rollin Thunder Mustang Audio & Video 11 04-05-2008 07:59 PM
WTB HID Kit Cajun JungleBoy Mustang Parts for Sale and Wanted 5 05-04-2006 09:20 AM
HID Kit for Mustang Cajun JungleBoy Pre-2005 V6 Mustang 11 04-05-2006 01:22 PM
10:58 AM
