Help! - Mustang Evolution
Old 11-28-2005, 09:33 AM   #1
V6STANG007's Avatar
Send a message via AIM to V6STANG007 Send a message via Yahoo to V6STANG007
Help!
If I need to connect two 130watt 2 Way speakers and a 500 watt single coil sub, Do I use this?:
http://www.millionbuy.com/adba8000t.html
or
http://www.millionbuy.com/adba8002t.html
or none of the above?
Jorge ~
Originally Posted by Danger Dude
OK you are right!!! Maybe I am the Old Crazy One
V6STANG007 is offline   Reply With Quote
Old 11-28-2005, 09:57 AM   #2
Re: Help!
not sure really, brent is on and he may know (i think he is still on)
Can you set the watts going to each channel individually? Else you may blow up those 130 watt speakers.
Old 11-28-2005, 11:27 AM   #3
Re: Help!
You definitely don't need the first one, it's a mono amp, hence it only has 1 channel. To be honest, I'd recommend using a separate amp for the sub than you use for the other speakers. But, if you are intent on using only 1 amp, it is possible to use a 4 channel amp if you do the impedence right.
Old 11-28-2005, 11:52 AM   #4
Re: Help!
thats what i was going to say but i decided not to
Old 11-28-2005, 02:09 PM   #5
V6STANG007's Avatar
Re: Help!
sorry no spki englich define impendence please
how bout: http://www.millionbuy.com/bosc650.html
as u can tell I am completely lost
I don't wanna use 2 amps if possible
Jorge ~
Old 11-28-2005, 06:41 PM   #6
Re: Help!
Impedence is what OHM the amp is running at. You normally set this to the optimum OHM of your speaker. And it's really really gonna be hard to just run one amp to be honest for 2 mids and a sub...
Old 11-28-2005, 08:57 PM   #7
V6STANG007's Avatar
Re: Help!
It would be really really hard, but is it possible?
Jorge ~
Old 04-11-2006, 09:51 AM   #8
V6STANG007's Avatar
Re: Help!
I got it set up with a 4 channel amp, but now I have a slight wine on the speakers when I rev the engine. Could be bad ground.
Jorge ~
Old 04-11-2006, 11:34 AM   #9
Re: Help!
Classic example of interference.
Old 04-13-2006, 06:39 PM   #10
timpryor's Avatar
Re: Help!
you ran your power wires on the same side as your signal cable didn't you?
i would definately run 2 amps, and whats the RMS power on the sub and speakers NOT the max(peak) power?
"The LORD shall judge the people:judge me, O Lord, according to my righteousness, and according to mine integrity that is in me." PSALM 7:8
In Texas? check out www.lonestarstangs.com
timpryor is offline   Reply With Quote
12:12 AM
