Update I want to see pics of amp installations - Mustang Evolution
Old 02-02-2006, 10:23 AM   #1
Danger Dude's Avatar
OK I want some ideas on where to mount a amp. I would prefer to not mount it in the trunk and forget about using the spare tire area. Has anyone mounted it under the seat, in front of the console where the stock amp is. or if in the trunk how about attached to the bottom of the package shelf.
Let me here from you guys
Old 02-02-2006, 10:33 AM   #2
Re: Where to mount the AMP
you MAY can get by with putting it under the bottom of the back seat, im not sure if there is much if any room under there... but its a thought.
Old 02-02-2006, 12:25 PM   #3
I mount it on the back of the backseat.
I always did it on the back of the driver side back seat. Fold the backseat down and mount it on the back of that.
Old 02-02-2006, 01:20 PM   #4
Did you run wires under the carpet over the drive line tunnel and under the back seat???
Old 02-02-2006, 02:16 PM   #5
I ran the wires under the driver side door sill and then under the backseat.
You can do it that way though
Old 02-02-2006, 03:16 PM   #6
I liek gramer
WhiteStang99's Avatar
I have some wires going under the carpet, you can do that easily if you take out the console and rear seats. no chance they'll be seen, and they're safe there.
Old 02-02-2006, 04:57 PM   #7
Probably the easiest way to run wires is to run them under the door sill and under the back seat from there. Unless you want to take your seats out and run the wires under the carpet there. Just be sure to run your power wire away from your signal wire, otherwise you will most likely get feedback that will drive you crazy.
As far as mounting the amp, when I get my other amp in..I'm gonna make a custom rack that hangs down from the rear deck and mount my amps there, that way they're out of the way, and kinda stealth.
Old 02-02-2006, 06:35 PM   #8
I liek gramer
Taking the seats out is easy though, and definitely worth it. I have power under the door sills and signal under the carpet, or vice versa. I think it is vice versa.
Old 02-02-2006, 07:10 PM   #9
the passenger seat takes like 5 minutes to take out
Old 02-02-2006, 07:40 PM   #10
yea but your power wire drops in through the driver side firewall
Old 02-02-2006, 10:18 PM   #11
I liek gramer
you don't even need to remove the front seats!
Old 02-02-2006, 10:22 PM   #12
timpryor's Avatar
DONT put it under the rear seat, no ventallation, i would mount it to the back of the back seats, as that is where we install them at work
"The LORD shall judge the people:judge me, O Lord, according to my righteousness, and according to mine integrity that is in me." PSALM 7:8
In Texas? check out www.lonestarstangs.com
timpryor is offline   Reply With Quote
Old 02-02-2006, 11:28 PM   #13
I would not dare stick it under the rear seat it would burn slap up.
Old 02-02-2006, 11:31 PM   #14
Thomas91169's Avatar
i second this. nice and clean and easy to access. run the amp from the battery through a grommet(youll see one), down behind the drivers kick panel, and under the carpet, under the rear seat and up to the amp. find youself a nice piece of unibody, and take a wire brush attachment and stick it on the end of a drill, and remove the paint till that surface(1"x1") is super shiny, then use a self taping screw and youre done. just make sure youre not drilling into anything important. the edges and walls of the spare tire compartment are pretty empty from anything important or support welds that suck to drill through. trust me, i have 3 seperate ground points all along the spare tire recess.
eh **** it corey, lemme build you up something nice......... im pretty sure the stuff for my enclosure would fit the same in your trunk.
-Thomas-
Old 02-03-2006, 05:11 AM   #15
What enclosures are you talking about. I want the full use of my trunk. I travel all the time in my stang. I could handle maybe a amp mounted on the rear seat back but I dont want anything that occupies trunk floor space
Old 02-03-2006, 09:56 AM   #16
a00v6stang's Avatar
I mounted my amp on the back side of the backseat, just amke sure you have enough celarance toput the seat back, up, i drilled twice but that was my first time doing an amp. what size sub(s) do you have?
It's all about how fast you get from point A to point B, now how you get there
a00v6stang is offline   Reply With Quote
Old 02-03-2006, 10:40 AM   #17
No sub right now I will probably add a Infinity Basslink in the distant future. That is why I am putting 6X9's in the rear instead of the 6X8's The 6X9's will give me added bass.
Old 02-03-2006, 04:20 PM   #18
psst. http://www.cardomain.com/ride/2090686/4. i still have around 40% of trunk space left, enough for 50 bucks in groceries. http://www.mustangevolution.com/foru...ry-getter.html
-Thomas-
Old 02-03-2006, 11:13 PM   #19
timpryor's Avatar
i put my 4 channel amp to the back of my seat today, so thats what i would reccomend, pics tomorrow
Old 02-04-2006, 06:10 PM   #20
40% isnt alot
Old 02-04-2006, 09:46 PM   #21
DarkShadow's Avatar
Send a message via AIM to DarkShadow
That's a good idea with the 6x9's. I have a Infinty 12" with a humongous (sp?) ported box, I have maybe 60% of original trunk space after just one sub... I read the first post about putting it under the seat and about had a coniption! I'm glad it was fixed by others. I put my amp ON my sub box so if I ever need to remove it, it comes out as one, but you don't have a box so that doesn't really help you...I'd just put it on the back seat.
DarkShadow is offline   Reply With Quote
Old 02-04-2006, 09:48 PM   #22
So it is either the back seat or on the bottom of the package shelf. I am going to take measurements and see if the under side deck is a good idea.
Old 02-05-2006, 12:35 AM   #23
I liek gramer
I've got 2 Bazookas (yeah, crappy rep, but not bad sound) and I have about 85-90% of my trunk space.
Old 02-05-2006, 12:42 AM   #24
I want 90% of my trunk space. it is a must. Amps attached to the rear seat will take up lttle space. I also dont care if they go unnoticed.
Old 02-05-2006, 04:56 AM   #25
40% isnt alot
yeah but i still have a back seat(which is useless for passengers, good for cargo).
bazookas/bass tubes are good for the price if you dont want loud bass, but want to increase the overall quality and range of your sound. i personally like the infinty basslink's. alot of newer cars are using these types of systems with their cars to increase the quality. the rsx-s uses a bass woofer box that fits under the spare tire inside the well. couple other cars use the same setup and sound reasonably well.
-Thomas-
Old 02-05-2006, 10:13 AM   #26
I dont know why Bazooka has a bad rap because they were the original plug and play amplified bass amp. They might be old school but they are far from crappy.
I have a 5 year old and a 8 year old and the back seats are very useful
I will agree the Infinity Basslink are very nice sounding. If I get a Sub that would be what I get.
Old 02-07-2006, 09:05 PM   #27
a00v6stang's Avatar
i dont run my subs anymore or my amp and deciding to get rid of them, 2 10 foscate punch phase 1, 600w sony xplode amp, if anyone is interested, or knows of someone that wants an amp for cheap, pm me, im selling by whole or by part, if interested let me know ill show where i have pics of it, ill post tomorrow
Old 02-08-2006, 10:01 PM   #28
dude i jst put it right behnd the foldable part of the bac seat on the hard surface. I used a plexi glass sheet as a base.
Old 03-01-2006, 07:05 PM   #29
Re: Update I want to see pics of amp installations
OK I Need to see pics of amp installation in your cars. I want some visual ideas
So post them pic's!!!!
Old 03-01-2006, 07:18 PM   #30
I don't have any of mine now
Old 03-01-2006, 07:32 PM   #31
Fine example you are !!!!
Old 03-01-2006, 08:18 PM   #32
Kiljosh's Avatar
Bad pic, but only one I got...
Old 03-01-2006, 08:51 PM   #33
Well it is a start thanks. The Amp I bought has the connections on either end and I am contemplating on installing the amp on the back of the drivers side rear seat and running all power, ground and remote wire under the carpet over the drive tunnel and under the seat. Have the left RCA's and speakers to the am go down the left side under the door sill and the right RCA's and speaker wires running around the right side door sill
Old 03-01-2006, 09:11 PM   #34
19ClearCobra96's Avatar
Region: Nebraska
Send a message via AIM to 19ClearCobra96 Send a message via MSN to 19ClearCobra96
nice toothbrush?
19ClearCobra96 is offline   Reply With Quote
Old 03-01-2006, 09:16 PM   #35
Kiljosh's Avatar
Toothbrush was for cleaning in between the heat sinks. Lol.
My new rims/tires are ready! finally (pics) **UPDATE** SpectorV Pictures and Videos 30 05-17-2009 07:40 PM
Project G.O. Update! (PICS) BlueSnake1013 Regional Mustang Discussion 5 04-07-2008 12:49 PM
FFW Update with track pics AlmostN8 Pre-2005 V6 Mustang 10 04-29-2005 10:15 PM
Evals Mustang Update (for everyone wanting/wondering!) *PICS Autobadges.com The Bar 48 08-22-2003 01:48 PM
Rims + Tires UPDATE: THEY'RE HERE **PICS** fast64 Mustang Audio & Video 27 08-20-2003 06:39 PM
02:44 PM
