power wire? - Mustang Evolution
Old 02-16-2010, 10:33 AM   #1
tylbrune's Avatar
power wire?
hey, trying to find a good spot to run my amps power wire. not havin much luck. any suggestions?
tylbrune is offline   Reply With Quote
Old 02-16-2010, 12:03 PM   #2
Re: power wire?
most run it from the battery back to the area near where the clutch cable goes (its a round rubber bung that can be wiggled around to get into the cabin) then down to the passenger door side, under the door edge molding, up and under the back seat using the back panel to stick under the edge of it. Then from there right up and into the trunk.
Old 02-16-2010, 12:10 PM   #3
Re: power wire?
Also, there should be a boot on the drivers side you can run it through the firewall, down under the carpet after taking off the door sill all the way back to the back seat, under it, and into the trunk. That's how mine is ran anyway. As far as grounding goes, it's best to use a selft tapping screw and take a putty knife and scrape the paint away. If you use a screwdriver, it creates creases and doesn't get a good ground.
19Delta is offline   Reply With Quote
4 Gauge wire help blue-saleen Mustang Audio & Video 22 04-13-2010 11:55 AM
Wire tapping... DarkShadow The Bar 11 05-13-2006 09:52 PM
Running the power wire cterie Mustang Audio & Video 10 11-09-2005 02:05 PM
WHere to wire A/F ratio sensor wire?!? TheSarge Pre-2005 V6 Mustang 0 09-04-2003 02:00 AM
I need a power wire to splice into. Rellik Pre-2005 V6 Mustang 22 07-30-2003 11:56 AM
» Members Mustangs
GOODBY
Mlarv5
0
Scotty 1
Add your Mustang
07:57 AM
