Lowering Springs - Mustang Evolution
Old 04-09-2006, 07:13 PM   #1
ridenmystang's Avatar
Talking Lowering Springs
I'm thinking about getting some lowering springs for my 03 gt but cant decide what kind to get and how much I should lower it. I was going to lower it 2 in but I wonder when I get the new cobra bumper I want, if it will tear it to bits. Should I just go with an 1.5" or what?:pickle:
ridenmystang is offline   Reply With Quote
Old 04-09-2006, 07:28 PM   #2
01mineralgrey6's Avatar
Re: Lowering Springs
you talking about the splitter, like on the cobra R?
-Tony
'99 cobra 'vert
Old 04-09-2006, 07:35 PM   #3
I liek gramer
WhiteStang99's Avatar
i don't know exactly which cobra bumper you want, but 1.5" is what I have and it's perfect. 1.5" is really about the limit for daily drivability. People say that's the line for C/C plates, but some say they don't need them, and I most definitely did.
Old 04-09-2006, 08:08 PM   #4
Dom
Dom's Avatar
Send a message via AIM to Dom
You'll have to learn how to handle dips and hills again anyway.
Old 04-10-2006, 12:58 AM   #5
Yeh, 1.5 is about the limit, and I needed c/c plates as well so you might as well just go ahead and plan that into your costs. And for c/c plates I recommend maximum motorsports 4 ways, best ones for the money IMO.
Old 04-10-2006, 09:04 AM   #6
any more than 1.5 inches you run into driving issues. I would recommend CC plates from maximummotorsports.com (4 bolt ones) with any drop. They also sell H&R springs which are extremly good springs. If you are on a budget you can get ford C springs and cut a bit from them for a good drop.
Old 04-10-2006, 11:34 AM   #7
I liek gramer
I have C-Springs with a cut coil. You can decide if that's enough for you by looking at my pics.
http://www.mustangevolution.com/gall...ry.php?cat=549
Old 04-12-2006, 04:58 PM   #8
Zim
You want to **** me?
Zim's Avatar
dont fear the drop!!! 2" ownz you!
I like toys
Old 04-15-2006, 07:37 AM   #9
ComputerGuy's Avatar
I have a 1.75 drop on the front. I'll be putting on CC plates when the car gets done. I still need to have the front radiator support removed and welded in and then painting the car.
The project is on hold for the moment though because the money I saved, 1500, is going to be used to get the wife a dependable car.
ComputerGuy is offline   Reply With Quote
Old 04-17-2006, 04:16 PM   #10
Whats the purpose of cc plates?
Old 04-17-2006, 05:55 PM   #11
When you lower your car, it makes it where the stock camber plates cannot adjust enough to give you a correct alignment. Aftermarket caster/camber plates allow the front suspension to be moved more and therefore makes it where you can alight the suspension.
Old 04-17-2006, 08:23 PM   #12
I liek gramer
If you drop your car past a certain point, your front wheels look like this:
/---car---\
so the insides wear disproportional to the outside. The stock suspension setup doesn't allow for enough adjustment to correct it, so new caster/camber (aka "cc plates") are needed.
Old 04-20-2006, 10:44 AM   #13
when you lower a car past a certain point it messes up the alignment of your front tires, usually you have too much negative (I think) camber making your tires look like this / \ instead of this l l
we have Steeda caster/camber plates on the Bullitt and we've bought some for the '91 but haven't put them on yet
the Bullitt has been lowered about 1.75in. I think but the '91 has been lowered even more than that, I'd say about 2in. You can hang up clearing ANYTHING in it though, but once you get used to it you'll be okay
MustangBrandy is offline   Reply With Quote
Lowering Springs explicitrock Mustang Audio & Video 3 04-14-2010 06:59 PM
Lowering Springs MRACING 2005-2010 Mustang GT 1 01-11-2010 03:11 PM
Lowering springs Kryptonite 1996-2004 Mustang GT 3 11-27-2006 02:29 PM
Lowering Springs douGT 1996-2004 Mustang GT 10 02-28-2005 10:16 PM
FRPP Lowering Springs - G Springs Stangthang Pre-2005 V6 Mustang 9 02-23-2005 03:57 PM
09:51 PM
