Wiring for 2 amps - Mustang Evolution
Old 03-22-2010, 12:16 PM   #1
blue-saleen's Avatar
Region: Utah
Wiring for 2 amps
will this wiring kit be okay for two amps that push out 300watts rms?
NEW AMP INSTALL KIT 2000-2500 WATT 4 GA GAUGE WIRING - eBay (item 140392779998 end time Mar-27-10 16:15:30 PDT)
blue-saleen is offline   Reply With Quote
Old 03-25-2010, 10:48 AM   #2
Re: Wiring for 2 amps
It will work good for one amp. To hook up your second amp you need to get two distribution blocks so you can split your ground and power wire to each amp. You may also need one more rca pair
-Milwaukee Brewers '10...Enough Said
-1998 Mustang GT Coupe
-Cold Air Intake
Della446 is offline   Reply With Quote
Old 03-25-2010, 12:16 PM   #3
Region: Utah
why do i need two distribution blocks?
could i not just split the power, then ground each one sepperately?
Old 03-25-2010, 12:29 PM   #4
Yeah, that's exactly what you need to do. Idk what I was thinking before with that second distribution block
-Cold Air Intake
Old 03-25-2010, 12:46 PM   #5
I'd run the two seperate grounds from the amps and ground them in the same location. (mines grounded under the carpet in the trunk via some paint scratching and a bolt.)
19Delta is offline   Reply With Quote
Old 03-25-2010, 01:45 PM   #6
Region: Utah
okay, cool. Thanks
Old 03-25-2010, 10:13 PM   #7
hello. i have a 2000 3.6 mustang and i took out the factory radio/stereo units. there were 4 harnesses. i bought wire harness from walmart to fit it for my aftermarket dvd player. the adapter only fit 2 of the 4 harnesses. when i hooked it up that way it didnt play any sound threw the speakers. what am i doing wrong? please help me.
jmccall88 is offline   Reply With Quote
Old 03-25-2010, 10:42 PM   #8
You sure you wired everything up right? Also, check out your harnesses. Which plugs did you go with? the ones from wal-mart?
Old 03-26-2010, 10:04 AM   #9
yeah. actually today i just went in there and pulled everything out. including the stock amp. someone before me had cut some wires int here for a sub out. so im guessing those are the wires i need to get to. so now the question is what color is what? all the diagrams online all have the same colors but dont match mine. they all say something different.
Old 03-26-2010, 11:27 AM   #10
hrm, should just be color to color, at least mine was that way.
2000 Mustang V6 Wiring Door panel wiring problem wyatt-00' Pre-2005 V6 Mustang 3 11-30-2009 12:43 AM
How to Connect two amps together? HELP! stangfreak12243 Mustang Audio & Video 2 11-26-2006 01:22 PM
2 amps? Kryptonite Mustang Audio & Video 5 10-14-2006 08:22 PM
amps mohrnormal Mustang Audio & Video 3 01-04-2005 08:22 PM
amps Warfire80 Mustang Audio & Video 6 03-28-2004 09:28 PM
09:54 AM
