I'm 1/4 way to deaf! :D - Mustang Evolution
Old 05-11-2006, 01:40 PM   #1
jimmy_beaner's Avatar
Region: Iowa
eBay: NEW 2006 KENWOOD KAC-X812D EXCELON AMP 1600 W. CLASS D (item 9724401777 end time May-11-06 12:32:01 PDT)
just bought that... now I just need the sub, a 2 ohm Kicker L7, the install... and the car to put it in ... we should be doing something about the car in the next week or two. Brent, my old amp and sub are wanting a new home...
Old 05-11-2006, 01:46 PM   #2
Re: I'm 1/4 way to deaf! :D
and I'm waiting on a new check lol
Old 05-11-2006, 01:53 PM   #3
Region: Iowa
ok ok ok.... I"m 1/2 WAY TO DEAF.
sub problem, taken care of... I got it in 2 ohms.
eBay: 06 KICKER S12L7 SOLOBARIC 12" Subwoofer 12L7 L7 SUB NEW (item 9725365499 end time May-17-06 19:15:38 PDT)
Old 05-11-2006, 02:23 PM   #4
Region: Iowa
how hard would it be to build this box? I don't think it'd be terrible...
Old 05-11-2006, 06:13 PM   #5
Let me know when you can fit a 13 1/4 inch sub box in the trunk of a mustang in one piece...
Old 05-11-2006, 06:34 PM   #6
Region: Iowa
I'd build it in the trunk... not buy it. I had like 12 semester hours of college in construction... I just need to know the proper dimensions, so I get optimal sound from the box.. and sub.
Old 05-11-2006, 10:38 PM   #7
Kiljosh's Avatar
Yea, have fun with that building the box in the trunk. You'll love it when it doesn't move enough to get your spare out...
Old 05-11-2006, 10:42 PM   #8
Region: Iowa
who uses a spare?... I blew out a tire on my old car... called my dad, and he came with the car trailer. I'm not gonna use the spare at all... it's just wasted weight as far as I'm concerned.
Old 05-11-2006, 10:45 PM   #9
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Personally, I like to be able to pull my sub box out, so I have more "rompus room" with the seats folded down.
DarkShadow is offline   Reply With Quote
Old 05-11-2006, 10:53 PM   #10
Kiljosh's Avatar
I dunno, perhaps when you are somewhere 300 miles away from home, no trailer, and in the dark without cell coverage you'll understand....
Old 05-11-2006, 10:59 PM   #11
Region: Iowa
why would I be 300 miles from home? The car isn't gonna be a DD... it's gonna be almost like a show car. This fall, I'm gonna pick up an older Explorer 4x4 for the DD.
Old 05-11-2006, 11:54 PM   #12
Region: Hawaii
Check out this website. Look for the "Deathbox". I had friend make one for his two 8-inch subs back in the day for his Miata. I sounded like two twelves in a traditional box. This box hits, check out some of the testimonials. I am making one for two Type r twelves and a alpine 1800 watt amp. The dimensiona are small and should fit.Audio by DECWARE(tm) High Fidelity Engineering Co.
99 Atlantic Blue V6- SOHC 4.6 swap, Tremec 3650, 8.8 rear end/ Flowtech Ceramic LT headers, off-road x-pipe, Spintech side exit exhaust. K&N drop in filter, removed snorkel, 18x10, 18x9, Anthracite Bullitt Replicas 295-35's, 265-35's. Eibach Pro-Kit springs, M&M Camber Plates
wrecked2001 is offline   Reply With Quote
Old 05-12-2006, 12:37 AM   #13
Thomas91169's Avatar
i believe the total height of the trunk is 14.5". its gonna be a tight fit. with the spare and the trunk hinge out, its very possible to finnagle a sub box of that magnitude into the trunk. i got mine into the trunk and its 14" High x 22" wide x 20" Deep.
if the car has the rear mach deck dohickey, thatll have to be ****canned.
trust me, i spent a month on the trunk area. i can give you exact dimensions if i head into the attic and open up my amp box. i can point out the best ground spots, best places to drill for hinges, and best positions to be in when working on the car(and doing other things).
those "special" boxes are good for smaller subs, but when you get into competiton 12"s and youre moving alot of air, they become highly inefficient. nothing beats the right box dimensions for the right sub. audiobahn helped me out, i told them the application, that it needed to be a wide box, and deep enough to fit a eternal and 3" of clearence. he was able to tell me specs that kept the box in the correct internal volume, even compensating for the volume taken away by the sub itself, and compensating for having no ports and not a bandpass box(since it sits 3" behind the rear seats, it makes its own bandpass enclosure by design).
-Thomas-
Old 05-12-2006, 01:22 AM   #14
Kiljosh's Avatar
And how would I know that? I am not trying to pick a fight here man, Im just saying why use such a big sub, why not 2 small 10's. There isnt much trunk space. But if its going to be a show car than its a different story.
Old 05-12-2006, 10:53 AM   #15
Region: Iowa
cause my set up is gonna be great .. and I don't know if I'm gonna take it to shows or not yet. The car we're looking at now is white, and I don't know about white, I may have to have my buddy repaint it. $1500 should be enough to have it painted whatever color I want.. for $2000, should be able to get a killer paint job too. Depends on the car, and what's wrong with it. Anyway, I need to wait for the stuff to get here, and then I'll start working on fabrication.
Old 05-12-2006, 01:16 PM   #16
I run 2 12's and have enough room to get my spare tire and such out within 2 or 3 minutes. All I do is unhook the boxes, slide them out, unhook the wiring, and fanagle them out the hole in the back (that's the hard part). I made my boxes to where they have 1/16th inch clearance getting in and out of the trunk. Talk about a tight fit..l.
Old 05-12-2006, 03:30 PM   #17
Kiljosh's Avatar
First box I bought was a 300 dollar Alphasonik Box with a 12 inch sub included. The thing was pretty, I knew I had to have it the minute I saw it. It was black leather with polished aluminum accents, a mirror in the bottom, Plexi-face, 2 polished Aluminum ports on top and an Orange Neon inside.
It was 17 inches tall, I got it in by trimming metal off the piece the backseat attaches too.
I got a flat in New Jersey, and the only way to get my sub out was to dismantle almost my entire back seat enough to pull it into my cab enough to pull me spare out.
NOT FUN. I now have a single DVC 10" with a small homemade box that does the trick. I am Happy!
Old 05-12-2006, 07:39 PM   #18
Region: Hawaii
GSTDUDE, I know how to build boxes, with the right volume and all that stuff, i have been a Installer for about 9 years(now on the side). I have worked at mom and pop shops and for one of the large retail companies. The last set of subs i had were 2 12 inch MTX Thunder 9500 with 2 older Alpine MRV 1000 amps pushing them. It was louder than it needed to be, but being in a Integra i had alot of space. I have heard this box with jl 10w7's and it was louder and punchier than my sealed box with the 12's with about the same amount of power. Only reason i was looking into this box is space limitations in the stang trunk. If you look at the website there is alot of reaserch into the box and you can use high excursion/compettion subs in the box. Plus this box is adjustable. You look at you sub specs for the box, and adjust the box baffle to the sub. It is a great design just look at the website. Something to consider.
Old 05-17-2006, 09:58 AM   #19
Region: Iowa
amp is in. Can't wait to start building the sub box... maybe next week I can start doing that. I just need the trunk to build it in. I can't decide where to put the amps though. I'm thinking about putting them in that cubbie hole in the trunk.. build a double deck thing to hold them up. I guess I still have some time. Tomorrow, my sub should come in.
11:27 AM
