gauges - Mustang Evolution
Old 08-08-2006, 10:13 AM   #1
Send a message via Yahoo to o3mustangGTafs
gauges
i have just got a n2o gauge an a air fuel gauge. the thing is is that i dont know how to instal the air fuel gauge . i have a good idea on how to put in the n2o gauge. its just i need to know how to make it look neat like what i need to take off to have a more easy install an what route to take while installing so i can have a nice clean look. i well apreshate eny help on this topic. thanks
o3mustangGTafs is offline   Reply With Quote
Old 08-08-2006, 03:27 PM   #2
Re: gauges
A/F guages are worthless unless you spend 400+ for a good gauge. With that said... I would probably buy an A pillar gauge mount from autometer (I buy the bolt on version so you can place it where ever you wish rather than the prefaved overlay (complete version) speed of sound (the company) may also have a nice version (google them)
the wires will run down the crack of the door (the weather stripping pulls back) and under the dash though the hole located there (currently a rubber groumet is there just pull it out to feed the wires though) from there you can make the connections for the senders as needed.
For the gauge's lights you can splice them into the rear defroster (very close depending on year) or use the light switch (i had mine ran over to the dash to the rear defroster for both lights and gauge power) the power wire can be ran to the rear defroster or anywhere else as well. PUT A FUSE ON THE LINE!
The ground wires can be ran together to a good ground~
Use a wire tester to determine which wires you want to run to where. Use a sodering iron if at all possible to ensure you have great connections, you can use a wire stripper that pulls the coating off of the wire with out cutting the wire so you dont mess up the stock wire.
Old 08-08-2006, 04:15 PM   #3
rydog's Avatar
Send a message via MSN to rydog
Re: gauges
This might be helpfull for finding the right wires to tap into for your guages its what I used for mine
97 V6-GT40 turbo-42#rs-BA2800 MAF-4.10's & tlok-254rwhp-369rwtq
Turbo'd by-TMA Turbo(http://www.tmaturbo.com/)
Tuned by-Dyno Tuned Performance(http://www.dtpracing.com/)
rydog is offline   Reply With Quote
gauges gearbanger67 Classic Mustangs 4 01-02-2007 08:59 PM
Gauges... Scottiedont Pre-2005 V6 Mustang 12 07-28-2006 04:45 PM
got gauges? whipster24 Pictures and Videos 19 04-10-2006 10:57 PM
Need some help with gauges... Ibanezplayer272 Mustang Audio & Video 12 01-10-2005 11:20 PM
gauges, help jimmy_beaner Pre-2005 V6 Mustang 13 08-27-2004 08:45 AM
10:32 AM
