help building an audio system - Mustang Evolution
Old 08-26-2006, 12:35 PM   #1
Send a message via AIM to 02whitemustang
when building an audio system in a car..what is needed? subs, an amp, anything else? and when building your own box..do you need anything special besides the wood and whatever chosen to cover it? im planning on building one for a school project. all help is appreciated
02whitemustang is offline   Reply With Quote
Old 08-26-2006, 10:50 PM   #2
Re: help building an audio system
What kinda system are you wanting to build? Are you just wanting subs or do you want to do an entire system. For just subs you'll need a set of rca's, a remote wire from the stereo, a power wire, ground wire, speaker wire (all this assuming you have an aftermarket cd player, if not you will need a rf modulator to convert the normal speaker output to rca form for the amp), you will need an amp, sub(s), some sort of an enclosure. If you are wanting to build your own enclosure you will need wood (whatever you choose to build it with) or fiberglass or whatever the box will be made of. You will need either a good jigsaw or a router would be the easiest way to make the speaker opening. Another way to ensure a good sounding system is to make sure you follow the speaker directions as far as cubic foot enclosure requirements for the speaker. They pay engineers good money to figure out what size box and what dimensions sound the best with that certain speaker.
Old 08-26-2006, 11:47 PM   #3
thanks..that helped out and answered some questions. how much would all that wiring run me? also, im planning on building the enclosure of wood..what type would you reccomend? do you have any ideas (or seen something) on something other than carpet to cover a wooden enclosure?
Old 08-27-2006, 07:28 PM   #4
What size amp you want to go with will vary the size of the wiring and hence the price. Expect to spend 50-75 dollars for a good set of wires, including shielded rca's to make the sound better.
As far as what type of wood, I always used a heavy wood for the resonance, not sure what people like to use now, I switched to fiberglass.
You could always bedliner the box, it will give it a texture and I like the look of the bedliner if you match the colors correctly.
Old 08-27-2006, 09:00 PM   #5
what do you mean when you refer to a 'bedliner'?
also..do you think the following will make a pretty loud trunk for me..or will it be too weak?
Details:
» package includes Alpine MRP-M450 mono amplifier and two SWE-1042 10" subwoofers
MRP-M450 mono subwoofer amplifier
» 220 watts RMS x 1 at 4 ohms (400 watts RMS x 1 at 2 ohms)
» variable low-pass filter (50-200 Hz, 24 dB/octave)
» tuned Bass EQ (0-12 dB boost at 50 Hz)
» subsonic filter (15 Hz, 24 dB/octave)
» preamp- and speaker-level inputs
» 8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
» 9-3/4"W x 2-3/8"H x 9-9/16"D
» warranty: 1 year
SWE-1042 10" 4-ohm subwoofers
» Kevlar®-reinforced pulp cone with Santoprene rubber surround
» frequency response: 32-1,000 Hz
» power range (each): 50-250 watts RMS (750 watts peak power)
» sensitivity: 87 dB
» warranty: 1 year
Old 08-27-2006, 10:53 PM   #6
timpryor's Avatar
i would say that those subs won't reach thier maximum potential with just one amp between the 2
"The LORD shall judge the people:judge me, O Lord, according to my righteousness, and according to mine integrity that is in me." PSALM 7:8
In Texas? check out www.lonestarstangs.com
timpryor is offline   Reply With Quote
Old 08-27-2006, 11:14 PM   #7
Details:
» warranty: 1 year
» warranty: 1 year
I would find (2) 10" Subs that are Dual Voice Coil and 2ohm instead of 4 so that you can use that amp and get 400x1 (200rms into each sub)
Old 08-27-2006, 11:57 PM   #8
timpryor's Avatar
^+1
Old 08-28-2006, 12:57 PM   #9
could you guys help me out by finding what you stated above? my school project is building a system on a budget. the subs/amp i posted were $30O so if you could find something around there. i dont really understand the watts and all that yet so its hard for me to pick out something...thanks for all the helps so far
iPod Integration With Stock Audio System DarkShadows Mustang Audio & Video 11 08-18-2010 09:56 PM
Audio System Upgrade erihkastang Mustang Audio & Video 2 02-03-2009 09:28 AM
Finished my audio system Brent Pictures and Videos 15 08-29-2006 10:13 PM
new audio system install friday!!! rnponyrn Mustang Audio & Video 11 08-25-2006 12:20 AM
Building Sound System...Input requested PureVenom Mustang Audio & Video 22 10-28-2005 09:43 PM
» Members Mustangs
Kraken
Cise
Lois
badsheep5.0
Add your Mustang
04:43 AM
