Sub enclosure in 01 gt? - Mustang Evolution
Old 08-31-2006, 11:38 AM   #1
Ok so i baught my 01 gt of my cuz, and he is a goof n got 2 Fosgate 12's and an amp and didnt check to see if they fit in the trunk so he put them on top of the folded down backseats which looks like hell... i was thinkn of selln them n getn 10's.. will the 10's even fit in the trunk? that plastic crap under the rear speakers holdin those amps takes up soo much room.. i think it leaves like 11.5" to work with..err
FrvrDreamin is offline   Reply With Quote
Old 08-31-2006, 01:46 PM   #2
Re: Sub enclosure in 01 gt?
you can put 12s but you will have to face them up or down... or have a custom box made and face them backwards (they cant really angle as the angle would be so severe that the magnets would hit the bottom)
Old 08-31-2006, 02:23 PM   #3
I have 2 12's in my 02, plenty of room to work with. I used to have 2 12's in angled boxes then decided to do fiberglass and mold the boxes into the side. You can use those speakers, just ditch the box you have now
Old 08-31-2006, 03:41 PM   #4
when you have the mach 460 system there is a big huge plastic box that they bolt under the bottom. It makes the clearance level 11.5 inches I think from bottom of the trunk to the underside of the box. I had this same issue when going from my 98 to my 01.. my speaker boxes would not fit anymore.
Old 08-31-2006, 03:57 PM   #5
so do i take the big plastic thing off, because i think somehow the mach amps are in some way possibly connected to that monstrosity lol...
Old 08-31-2006, 04:15 PM   #6
you can get around it you will just have to pay for a custom amp box OR face them up and slide them under the plastic box. Just remember to build the box with enough clearance to include the speaker poking out over the top edge of the box.
Old 09-01-2006, 03:29 PM   #7
My boxes in no way interfere or come in contact with the 460 system. The old boxes I had didn't either. It's very easy to run subs of any size in your trunk.
Old 09-01-2006, 04:28 PM   #8
02V6TTcoupe's Avatar
I've got 2 Kicker CompVR 12's in mine and when i started to install them in mine I thought I'd never get em in. All i had to do was take out the back seat and the Frame that holds the back seat and they slid in perfectly. My box is the angled design, plain and simple but still one of the best designs for sound.
02V6TTcoupe is offline   Reply With Quote
Old 10-06-2006, 08:50 AM   #9
Was it tough to get those backseats out? I think i might give it a shot this weekend.. but still my box measures 12.5 and the clearance from the shaker plastic is only 11.5??
Old 10-06-2006, 05:01 PM   #10
Thomas91169's Avatar
you gotta do some work.
the plastic dohikey holding up the mach amps and speakers can be removed and will free up almost 5" of space, then just remount the amps somewhere else.
my box dimensions for my 1 Audiobahn 12 are i believe 15" tall x 18" deep x 20" wide. the sub is normal mount, the woofer faces the inside of the back seats and the rear of the box is 1/2" plexiglass with the MDF being 3/4" thick.
http://www.cardomain.com/ride/2090686/4 for some pics.
-Thomas-
Old 10-11-2006, 09:59 AM   #11
Ok So im gona remove the plastick and attempt to figure out how to get the backseats out, then maybe i can stuff that box in there, the box is not all that big, only 12.5 actually, I guess there is ALOT of playn around to do this week haha...
PS
Im getn REAL Saleen rims on Thurs
Woot Wooot
Score for the new kid haha
Old 10-12-2006, 02:05 AM   #12
its definately do-able. you can take out the spare and the trunk latch to get a pretty hefty box in through the back. i heard of a guy who fit a Kicker Box for 2 12" subs through the trunk, it just takes finesse and alot of patience.
you will not be able to stick it in from the back seats, there is only a 12" opening from the bottom of the trunk to the top of the body chassis framing in the back seat to trunk opening. unless you cut that out(which would be very stupid), youre not going to fit much through there.
-Thomas-
Old 10-16-2006, 09:30 AM   #13
yeh i measured the opening before i would have yanked the seats out..
another ? i had was... is there any bass what so ever with the stock 460? its seems like ALOT of highs
Old 10-18-2006, 12:17 AM   #14
i dunno, its decent enough for me now that i took out the Eternal from the GT(since im selling it). i think the mach460 is a great system for most audiophiles. i think the most you need to help out is a single 10", unless youre just going for bragging rights(like i did).
-Thomas-
Old 10-18-2006, 09:32 AM   #15
see when i unplug my subs RCA's n turn up the bass on the headunit i cant even tell there is bass at all.. i wonder if teh thing my cuz had spliced into it messed up the speakers at all?? he had a lil thing spliced into it so that the subs could run off of the stock headunit which i replaced with a new pioneer
Old 10-18-2006, 10:18 AM   #16
Zim
You want to **** me?
Zim's Avatar
The stock 460 system should have a decent amount of bass, I know mine does. Also, dont face your subs towards the rear seats, face them backwards towards the back of your car. Facing them forward is horrible for subs with the way acoustics work.
I like toys
Old 10-18-2006, 11:34 AM   #17
if he used the rca modulator then no. thats what i have in BOTH my stangs and no ill effects on the GT plugged in or not.
its possible the speakers have bass-blockers installed as well.
-Thomas-
Old 10-19-2006, 12:26 AM   #18
what is a bass blocker n how do you get rid of it?
Old 10-19-2006, 12:47 AM   #19
Zim
Zim's Avatar
theyre basically resistors that block below a certain frequency range... usually 80 hz an below...
I like toys
Old 10-19-2006, 12:51 AM   #20
are they easy to disconnect?
Old 10-19-2006, 12:59 AM   #21
Yea they should be inline with your speaker wire.
Old 10-19-2006, 03:28 PM   #22
ok thanks guys.. ima go look for sumthin not normal back there in a few minuts..
Old 10-25-2006, 07:33 PM   #23
ok umm... so the subs are out, i can not find a bass blocker, also i can not figure out how to get than plastic peace outa the trunk?? i just took out the 4 bolts from the maine big holes and un screwed the amps... its still in there soo tight... do i have to rip the rear deck out to get at something??
Old 11-01-2006, 01:49 AM   #24
Region: Montana
I'm putting 4000 watts to a single 10 in a modified stealth box without interfering or losing any trunk space. It hits.
95 Crystal White Cobra #702 of 4007
Polished Vortech S-Trim @ 12psi
18X9 FR500s
MANY INTERIOR MODS...
Coming soon....Dart 427 with a T-76!!
Blwnbyu is offline   Reply With Quote
Subwoofers w/ Enclosure 4 SALE TafoyaMNAA Mustang Parts for Sale and Wanted 5 06-21-2007 01:57 PM
subwoofer enclosure help TripleBlack Mustang Audio & Video 7 01-25-2007 01:34 AM
HELP building a fiberglass enclosure Murph00 Mustang Audio & Video 10 12-01-2004 08:11 AM
Fiberglass Enclosure SquirrelNutz154 Mustang Audio & Video 9 08-27-2004 12:00 AM
sub enclosure Falcon Mustang Audio & Video 3 12-27-2003 01:20 AM
09:57 PM
