time to get my system started... - Mustang Evolution
Old 09-08-2006, 11:10 PM   #1
OK, i love my mustang. but i have no idea about some of the technical working crap, etc.
basically, i've got 2 10' Audiobahn subs with separate enclosures, a 1000 watt 2 channel bridgeable mosfet amp (it's an off brand but it was basically given to me brand new).
i'm working with a 2004 V6 with a mach system. i really don't want to purchase another headunit unless i absolutely have to. suggestions???
SilverStang04 is offline   Reply With Quote
Old 09-10-2006, 07:59 PM   #2
Re: time to get my system started...
You can run an fm modulator to run the subs, you won't get the clarity you would with an aftermarket unit, but it is possible to hook them up to your factory system.
Old 09-12-2006, 02:23 PM   #3
DarkShadow's Avatar
Send a message via AIM to DarkShadow
You will be surprised at the difference a new head unit can make. I would have started there first, plus they can (most of the time) look better than your stock unit.
DarkShadow is offline   Reply With Quote
Old 09-12-2006, 03:16 PM   #4
Zim
You want to **** me?
Zim's Avatar
When I replaced my head unit, it made my mach system sound 10x better...
I like toys
Old 09-12-2006, 03:59 PM   #5
Stumpy's Avatar
Can you replace just the head unit and still use the same amps?
~Roman~
2003 Mustang V6 Vert with a Flowmaster Super 40 series dual exhaust
I'm not a target in the sights of your mercy. I've never asked for anything. I'm not asking now.
Stumpy is offline   Reply With Quote
Old 09-12-2006, 04:15 PM   #6
I'm pretty sure the amps are bypassed when you install an aftermarket headunit on a mach 460 system
Old 09-12-2006, 04:46 PM   #7
Zim
Zim's Avatar
I dunno, the wiring harness i got plugs right into the factory one that goes to the amps... :dunno:
I like toys
Old 09-12-2006, 04:59 PM   #8
Stumpy's Avatar
what would the minimum specs be for the a/m head unit? a guy from car toys told me that he had a cobra come in and he had to replace the entire system in order for a new head to work.
~Roman~
Old 09-12-2006, 05:33 PM   #9
timpryor's Avatar
^you don't have to, but as brent said you usually have to bypass it altogather so it really is worth it just to upgrade itt all at once. much easier especialy if you end up having problems, then you arn't wondering if its stock or aftermarket giving you the issues.
But Zim, not to disagree with you but sometimes those harnesses work great and others just complicate things, just what i've seen working in the car audio bussiness
"The LORD shall judge the people:judge me, O Lord, according to my righteousness, and according to mine integrity that is in me." PSALM 7:8
In Texas? check out www.lonestarstangs.com
timpryor is offline   Reply With Quote
Old 09-12-2006, 10:52 PM   #10
You can install an aftermarket headunit on the mach system. You have to be sure to buy a quality harness however, not the cheap wal mart brand.
Old 09-12-2006, 11:00 PM   #11
timpryor's Avatar
such as scoche i know that but i've still seen times wher it just didn't want to cooperate
Old 09-13-2006, 09:02 PM   #12
i'm thinking i may as well replace the head unit too. i'd heard that the stock amp wouldn't be compatible...i hope it is though.
Old 09-13-2006, 09:12 PM   #13
Zim
Zim's Avatar
yeah thats what i used... just bought the thing they had at walmart and it works fine...
Ive heard that some people get a really loud pop somtimes using that adapter and there was something else they had to buy, but mine works fine.
I like toys
Old 09-14-2006, 02:21 PM   #14
I haven't installed an aftermarket unit in the 05+ but I would be willing to bet it will work fine with the correct adapter to cut the power going to the factory amps. You can't send a powered signal to the amps, it will mess them up, hence the reason you need a special converter as is in included in these harnesses designed for the mach and shaker systems.
Old 09-15-2006, 07:30 PM   #15
i just bought a JVC KD-AV7010 DVD 7" in dash headunit...anyone have anything like this? i'm sure it'll need a good harness.
Just started gabnmantha New Member Introductions & Greetings 11 01-16-2008 12:28 PM
trying to get something started Kyle Regional Mustang Discussion 0 08-25-2006 09:31 PM
Time say bye to my system :( juvifan1 Mustang Parts for Sale and Wanted 10 06-29-2004 03:23 PM
who started STEVE The Bar 19 06-16-2004 02:34 PM
getting started dansmustang 1996-2004 Mustang GT 2 04-19-2004 01:59 PM
10:07 PM
