hey are these good subs? - Mustang Evolution
Old 10-15-2006, 08:42 PM   #1
i got 2 12inch audiobahns in my car. the model is awc12t. they dont sound like they hit so hard. my amp is e1400d. are my subs to weak or is it my amp?
mustang0386 is offline   Reply With Quote
Old 10-15-2006, 09:43 PM   #2
Re: hey are these good subs?
I'm too lazy to look up those models, but alot with how speakers sound is the box design, what box are they in?
Old 10-15-2006, 10:10 PM   #3
its a custom box from a store. dont know diemenisons. but its rectanlge.
Old 10-15-2006, 10:32 PM   #4
Thomas91169's Avatar
those are entry level audiobahn subs. i think 250rms/500w max, 4ohm dual voice coil. make sure you have it wired up correctly, i thought i knew what i was doing, but according to my audiobahn guru that helped me with the setup in the GT, i made the same wiring mistakes everyone else makes because they wire the audiobahn stuff like every other sub.
if you have the book that came with your subs, open it up and see how they wire it. i had mine all ****ed up, i figured both negatives from the subs go to the negative of the amp, and the positives to positive, but no, that only runs the subs in 8ohms. there are different ways for 4, 2 and 1 ohm setups depending on sub.
once we rewired my single 12" Eternal to 2 ohm (i was running 8 ohm with a 1300HCT amp), that sucker pounded. later he found the wiring diagram to run 1ohm and holy shat.
-Thomas-
Old 10-15-2006, 11:37 PM   #5
do u know how many watts my sub pushs out. they wired it up like this.http://www.cardomain.com/shop/woofer..._dvc&x=130&y=7
Old 10-19-2006, 11:52 PM   #6
im no audiophile, so i have no idea other than whatever i was doing for the past few years was wrong.
my advice would be to call audiobahn or look on their site.
-Thomas-
Old 10-20-2006, 08:07 AM   #7
You have it wired 2 ohm if I got the correct image, in that mode the amp is pushing 400 rms watts, which means in normal listening you are putting about 200 watts into each speaker. The amp won't support 1 ohm, so you are getting all the power you can out of it.
I'm running my pioneer at 2 ohm with 2 dvc premier subs, and it sounds really good in my car, and I'm not pushing but about 200 into each sub. Like I say, box design has alot to do with it.
Old 10-20-2006, 11:51 AM   #8
yea they sound good i just didnt think that the amp was pushin enough out for the sub to go to max.
Old 10-20-2006, 12:29 PM   #9
Zim
You want to **** me?
Zim's Avatar
did you check the gain on the amp?
I know it sounds stupid... but worth a shot...
I like toys
Old 10-20-2006, 12:30 PM   #10
wats the gain?
Old 10-20-2006, 12:34 PM   #11
Zim
Zim's Avatar
Originally Posted by mustang0386 View Post
wats the gain?
Its basically how much power the amp pushes out... there should be some dials on the amp. One of them will be the gain... just turn it up if its not already all the way up. It could also be called "level" or something to that effect.
I like toys
Old 10-20-2006, 04:19 PM   #12
Kiljosh's Avatar
Not all the way up though, I never go more than 2/3.
A car audio nut buddy of mine said if you crank mthe gain on your amp you can burn it out.
Old 10-20-2006, 04:34 PM   #13
It's either Level or Gain.
Usually if it is Gain it will have a normal section. Just leave it on normal. If it is level then usually you want it on Max. Atleast that is how it is on my amp that is connected to my sub. It says Level and came from the factory turned to Max
Old 10-20-2006, 05:15 PM   #14
my amp says input sensitivity and filter frequency and filter mode
Old 11-27-2006, 07:31 PM   #15
Region: Montana
Gain is exactly that, the Gain of the input on the amp and what comes out. The higher the gain, the higher the amplification of the input signal.
95 Crystal White Cobra #702 of 4007
Polished Vortech S-Trim @ 12psi
18X9 FR500s
MANY INTERIOR MODS...
Coming soon....Dart 427 with a T-76!!
Blwnbyu is offline   Reply With Quote
Subs jaredp Mustang Audio & Video 16 06-05-2007 10:03 PM
Subs jaredp Mustang Audio & Video 2 05-01-2007 05:32 PM
Subs 19ClearCobra96 Mustang Audio & Video 5 12-17-2004 12:52 AM
Hey guys that are good at lowering, need help for poster DUW Zim The Bar 2 10-13-2003 09:54 PM
subs mexor Mustang Audio & Video 3 08-07-2003 09:25 AM
04:14 PM
