Speaker recommendations - Mustang Evolution
Old 10-26-2006, 02:54 PM   #1
Stumpy's Avatar
Does anyone have any advice about a speaker to replace my lows. I know I can't use 3 ways, but will 2 ways work? And which brand is preferred?
~Roman~
2003 Mustang V6 Vert with a Flowmaster Super 40 series dual exhaust
I'm not a target in the sights of your mercy. I've never asked for anything. I'm not asking now.
Stumpy is offline   Reply With Quote
Old 10-26-2006, 03:02 PM   #2
Zim
You want to **** me?
Zim's Avatar
Re: Speaker recommendations
two ways will work... are you looking to get a lot of bass? I personally like Boston Acoustic and MB quart. Corey will come in here and praise infinities 6x9s, but seeing that you have a vert... I doubt youll be putting 6x9s in there.
I like toys
Old 10-26-2006, 03:25 PM   #3
Stumpy's Avatar
Not a lot of bass. More is preferred but also better sound quality. I was looking at Infinity but I wanted to get some other imput.
~Roman~
Old 10-26-2006, 04:47 PM   #4
Many brands are good, but I've always been a fan of ECLIPSE speakers, and thought they sounded pretty good in my Integra, but I also haven't kept up with car audio in a while.
ECLIPSE by Fujitsu Ten
JROC is offline   Reply With Quote
Old 10-27-2006, 12:08 AM   #5
Thomas91169's Avatar
BLASPHEMY!
You cant put Eclipse anything in an Integra!
Just like putting Type-R subs in a Eclipse is also illegal, though i would be hung for treason if anyone found out i had some at one time...........
i may sound like a cheap ***, but ive always liked Pioneer stuff. Infinity makes great component setups, as do Kicker, MB Quartz, Eclipse and sadly Audiobahn.
-Thomas-
Old 10-28-2006, 06:53 PM   #6
rydog's Avatar
Send a message via MSN to rydog
Infitiy is always good for sound quality but not as much bass as some others
97 V6-GT40 turbo-42#rs-BA2800 MAF-4.10's & tlok-254rwhp-369rwtq
Turbo'd by-TMA Turbo(http://www.tmaturbo.com/)
Tuned by-Dyno Tuned Performance(http://www.dtpracing.com/)
rydog is offline   Reply With Quote
Old 10-28-2006, 07:06 PM   #7
Danger Dude's Avatar
HAHHAHA 6X8's dont have anywhere near the bass as a 6X9 but you are right a difficult fit for a Vert. Any of the big names like MB, BA, Infinity, Polk, Eclipse, and Alipne well be nice upgrade. It is really about cost and your personal hearing taste. Most audiophile people will tell you 6 1/2 are better than 6X8
s but you will need a adapter. Personally a set of Infinity Kappa's 6.5 or 6X8's will give you the best bang for the buck
INFINITY 62.7i <BR>6.5" 2 Way 255W Kappa Series Speakers
INFINITY 682.7cf <BR>6" x 8" (5" x 7") 2 Way 300W <BR>Kappa Series Speakers
Old 10-28-2006, 10:13 PM   #8
Stumpy's Avatar
i currently have pioneer 6.5 3 ways in there now but the stupid factory amp won't support the additional highs in the rear. but i do know that 6.5 will fit without an adaptor. but i will check out the infinity line.
~Roman~
Old 10-29-2006, 02:19 PM   #9
Stumpy's Avatar
should i get plain lows or 2 ways? is there enough support for the 2 ways from the amp?
~Roman~
Old 10-29-2006, 02:33 PM   #10
Actually you have 2 ways in the back now. They are rather uninspiring and crude 2 ways but they are 2 ways. Any manufacturer 2 ways will work. You just need to find the most efficent. The higher the Sensitivity of the speaker the more efficent it will be at lower power. so find a speaker above a sensitivity of 92db or above.
Old 10-29-2006, 02:38 PM   #11
Stumpy's Avatar
I see. I thought they were just lows with mids above them. And do most of the better brands run 94db and above?
~Roman~
Old 10-29-2006, 02:49 PM   #12
Zim
Zim's Avatar
You dont have the mach system in there do you?
I like toys
Old 10-29-2006, 02:54 PM   #13
rocknbronco's Avatar
Rockford Fosgate
Mustang wanted for here...
rocknbronco is offline   Reply With Quote
Old 10-29-2006, 02:56 PM   #14
Most good speakers are above 90db but Infinity and great speakers are 92db and above. The Sensitivity db on speakers actually quoted in most product information. The 2 comparisons below are Infinity. Thge top ones are Kappa's and ar very good but they really would require a seperate high power amp to really get the advantage out of them. The ones on the bottom are reference and they are rock solid and would preform much better with good sensitivity on stock equipment.
Home > Car Audio > Speakers > Infinity > INFINITY 682.7cf
Features:
Plus One woofer cones
Edge-driven MMD dome tweeters
Unipivot (patent no. 6,002,780).
Woven glass fiber woofer cone material
SLI high-output design
Computer-optimized voice-matched outboard passive crossovers
Adjustable tweeter level
Power Handling, RMS: 100 Watts
Power Handling, Peak: 300 Watts
Sensitivity: 94dB
Frequency Response: 40Hz - 25kHz
Mounting Depth: 2-1/4"
Impedance: 2 Ohms
or
Home > Car Audio > Speakers > Infinity > INFINITY 6812CF
Features:
6" X 8" Two way Car Audio Loudspeaker Component System
Plus One (patent pending) woofer cone
Edge-driven silk-dome tweeter
UniPivot(patent no. 6,002,780)
4-Ohm impedance
Sensitivity: 92 dB
Frequency Response: 49Hz - 21 Khz
Power Handling, RMS: 60 Watts
Power Handling, Peak: 180 Watts
Contents: 1 pair
Old 10-29-2006, 03:04 PM   #15
Originally Posted by rocknbronco View Post
Rockford Fosgate
RF speakers are known for being booming and that is about it there efficency and sensitivity are not great for stock replacements not to mention they have terrible high frequency music reproduction
# 3-way 6"x8" speakers (pair)
# mica-injected polypropylene woofer cone with butyl rubber surround
# 3/4" titanium composite dome midrange and 1/2" PEI dome tweeter
# power range: 2-60 watts RMS (120 watts peak power)
# frequency response: 56-21,000 Hz
# sensitivity: 87 dB
# top-mount depth: 2-9/16"
Old 10-29-2006, 06:01 PM   #16
timpryor's Avatar
i like my 6.5 Arc Audio foose components in muh cobra
"The LORD shall judge the people:judge me, O Lord, according to my righteousness, and according to mine integrity that is in me." PSALM 7:8
In Texas? check out www.lonestarstangs.com
timpryor is offline   Reply With Quote
Old 10-29-2006, 06:24 PM   #17
Diameter: 6.5"
Max power :175 watts
Normal power :90 watts
Sensitivity: 86 db Not very efficent Infinity is 92-94db
Frequency response :60Hz-20KHz Not very much low bass Infinity has 45Hz - 25kHz
Old 10-29-2006, 06:31 PM   #18
I think I might give those INFINITY 682.7cf a shot. I see they are 2ohms. Is there any special wiring required to make the amp see a 2ohm load?
Old 10-29-2006, 06:43 PM   #19
No you just need a amp that can handle 2 ohms
Old 10-29-2006, 07:12 PM   #20
2ohms stereo correct?
Old 10-29-2006, 07:51 PM   #21
What do you mean by 2 ohm stereo. you just need a Amp that can handel 2 ohm
Old 10-29-2006, 09:28 PM   #22
timpryor's Avatar
Originally Posted by Danger Dude View Post
Diameter: 6.5"
1. i don't perticularly care for infinity.
2. I've got a monster sub, so i DO NOT WANT NEED OR CARE FOR BASS FROM SPEAKERS!!!!!!!!!!!!!
3. they still sound very good
Old 10-29-2006, 10:41 PM   #23
But if you are underpower and use the stock radio and amp you want a higher sensitivity. Not that your system sounds bad because I dont know. The pick of speakers is to the ear of the beholder. Everyones ear is different and what sounds good to one sound off to others. It is the nature of the beast.
Old 10-30-2006, 06:01 AM   #24
Stumpy's Avatar
i do have the mach 460 system in there. does make a difference in speaker selection?
~Roman~
Old 10-30-2006, 07:57 AM   #25
Wait....Dont our Mach 460's have 6x8's in the Rear deck?? i yanked it out n there are separate 6x8 and like a tweeter or something in the big plasic housing??
FrvrDreamin is offline   Reply With Quote
Old 10-30-2006, 08:15 AM   #26
timpryor's Avatar
true however i am using a 70x4RMS amp so they arn't being under powered
truth is anyone buying speakers NEEDS to listen to them 1st as that all ears are different
Old 10-30-2006, 08:31 AM   #27
Stumpy's Avatar
i don't have a rear deck. mine's a vert.
~Roman~
Old 10-30-2006, 09:18 AM   #28
Oooo Lucky..
that rear deck is a big Cluster F**k :dunno:
Old 10-30-2006, 09:53 PM   #29
QFMFT!
-Thomas-
Old 10-30-2006, 11:16 PM   #30
Zim
Zim's Avatar
It might, I know the mach system in mine is broken up in components... might want to check that out, Im not sure of the setup in a vert.
I like toys
Old 11-01-2006, 12:35 AM   #31
Region: Montana
If you are running off deck power I highly recommend an efficient speaker, not one that is rated for more than 100 watts peak.. I am running Memphis Car Audio M Class coaxial 5x7's in my explorer and they are the best sounding deck powered speakers I have ever heard, and I do this for a living. Efficiency is key to bass response with low power, not some ridiculous peak ratings, like the 8000 Watt system in my Cobra..
95 Crystal White Cobra #702 of 4007
Polished Vortech S-Trim @ 12psi
18X9 FR500s
MANY INTERIOR MODS...
Coming soon....Dart 427 with a T-76!!
Blwnbyu is offline   Reply With Quote
Old 11-01-2006, 12:37 AM   #32
Region: Montana
Memphis warranty is Lifetime too, just most dealers won't tell you that, but it can't be bought online to carry a warranty...
I literally just trashed a pair of 6x8 Infinity Kappas because they sounded like dog ****.
18X9 FR500s
Old 11-01-2006, 06:40 AM   #33
You evidently had a bad set of Kappa's because they dont sound like dog**** unless something was wrong with them. I am not here to say Infinity is the end all best speakers on earth but to say they are dog **** is irresponsible and utterly rediculous
Infinity and JBL are owned By the Harmon Company. They are the leaders in speaker innovation. Go to any Music studio and see what speakers are in the studios when they are recording. JBL's.
Harman International
Old 11-01-2006, 06:45 AM   #34
Stumpy's Avatar
Corey is not a paid spokesperson for Infinity. This is real life testimony from a real client.
~Roman~
Old 11-01-2006, 01:42 PM   #35
timpryor's Avatar
^lol so very true
Shop recommendations MetallicMist 2005-2010 Mustang GT 4 01-07-2010 03:22 PM
need a new clutch recommendations jkaminski24 1996-2004 Mustang GT 7 10-13-2009 11:07 PM
C/C plate recommendations BlueDonkey Pre-2005 V6 Mustang 3 07-15-2004 06:04 AM
CAI Recommendations Seph Pre-2005 V6 Mustang 34 05-15-2004 10:36 PM
need recommendations... 35thAniVertible Pre-2005 V6 Mustang 3 09-15-2003 05:26 PM
09:34 AM
