How to Connect two amps together? HELP! - Mustang Evolution
Old 11-23-2006, 02:58 PM   #1
stangfreak12243's Avatar
I want to hook a 4-channel amp to a 2-channel amp. How is this done or how can i do it?
The 4-channel amp will go to my 4 main speakers and the 2-chennel amp will go to two sub woofers in the trunk.
How could I pull this off?????????????????????????????
Any other suggestions would be great!!
stangfreak12243 is offline   Reply With Quote
Old 11-24-2006, 01:21 PM   #2
Re: How to Connect two amps together? HELP!
Probably the easiest way to do it would be get a set of rca splitters so you can run to both amps, get a fuse block so you can split your power wire, and find two ground points and simply run the remote wire to the other amp. I'd recommend using two separate ground points to ensure the amps are properly grounded.
Old 11-26-2006, 02:22 PM   #3
I'll be looking into it.
If anyone else has another suggestion let me know.
Facebook Connect Brent ME Site Help & Announcements 12 05-28-2009 01:00 PM
2 amps? Kryptonite Mustang Audio & Video 5 10-14-2006 09:22 PM
Ultra X-Connect 500watt Power supply unit (for computer) SpectorV Mustang Parts for Sale and Wanted 1 04-21-2005 01:29 PM
amps mohrnormal Mustang Audio & Video 3 01-04-2005 09:22 PM
amps Warfire80 Mustang Audio & Video 6 03-28-2004 10:28 PM
04:48 PM
