Troubleshooting sub install - Mustang Evolution
Old 12-21-2006, 11:47 AM   #1
megax29's Avatar
Send a message via AIM to megax29 Send a message via Yahoo to megax29
My car is wired for subs. I got a pioneer 760w amp on my screwed to the back of my rear seat. I bought a box w/ 2 subs claiming 450w rms/ 900w peak, I don't believe but whatever. They are C4's all black 'special edition'. Anyways so my problem is that my subs cut in and out. It cuts out when the song begins to bump. If I keep them low volume they're fine until the bass is too much and then it cuts out. How do I fix this?
V6 Midnight Black
CAI w/ K&N Filter, Tokico Complete Suspension kit, Single Flowmaster w/ turndown, GT rear sway bar.
megax29 is offline   Reply With Quote
Old 12-21-2006, 12:46 PM   #2
Thomas91169's Avatar
Re: Troubleshooting sub install
sounds like the amp is clipping. Basically the amp is trying to push more than it can, its falling under 10v at times and cuts out. Buddies truck did the same, added a 10farad cap (audiobahn) and it fixed the problem. Then again audiobahn amps have the voltage gauge and a clipping meter built in.
or the subs are shorting when they hit a certain point, which i doubt.
-Thomas-
Old 12-21-2006, 02:46 PM   #3
bluemustang's Avatar
yeah i agree as above the amp is def clipping.
you know in certain amps you can adjust the amp to more of the subs specs, i really have no clue on pioneer cause i never messed with there products but if it does you might just wanna mess with the dials I know ive personally seen amps get "tuned" so bad like the dials are all the way up or certain switches are in the wrong way (mostly for JL Audio) and now the amp is overloading itself and pushing more power then its suppuse to be pushing.
if that amp doesnt or even if it does you can always have the amp tested at a local audio place to check and see.
Old 12-21-2006, 10:11 PM   #4
I have the same amp, how do you have the subs wired and are they dual or single voice coil?
I had my 2 dual voice coil subs wired up at 1 ohm for a short while, I had the same problem. Wired them up at 2 ohm and it fixed the whole problem. It's a good strong amp, haven't had a problem out of mine for 3 years now, and that's saying something for me.
Old 12-21-2006, 11:12 PM   #5
Wiring the subs up wrong will def. cause this. Make sure you got them wired right
Old 06-09-2007, 10:45 AM   #6
wkndpaintballer's Avatar
Send a message via AIM to wkndpaintballer
i have the same amp and i had to get bigger power wire and that helps but it still cut out at full volume so adding a capacitor will definitely help, but for a 760 you definitely dont need a 10 farad cap, it generally goes 1 farad per 1000 watts of power so a 1 farad should be plenty but if you want to play it safe go with a 1.5 or 2 farad
NOBODY cares about threats over the internet. Don't try to act hardcore with the keyboard. FIGHTING ONLINE is like racing in the special Olympics; even if you win, you're still RETARDED .
wkndpaintballer is offline   Reply With Quote
Old 06-09-2007, 12:50 PM   #7
Kiljosh's Avatar
My money is on too much/little resistance from wiring them wrong IF they are dual coiled.
another install SaturnMan8227 Pre-2005 V6 Mustang 12 03-18-2010 10:52 AM
May have hurt my motor, need troubleshooting ideas PureVenom 1996-2004 Mustang GT 22 01-27-2010 03:11 PM
Fog light Troubleshooting runvsofthisbull Mustang Audio & Video 4 06-30-2009 07:50 PM
CB Install n8r The Bar 40 03-19-2004 08:22 AM
sub install el cheapo Mustang Audio & Video 28 07-27-2003 09:52 PM
02:34 PM
