MWspeedshop door panel decals - Mustang Evolution
Old 10-18-2003, 05:41 PM   #1
wiarumas's Avatar
i am going to start modding the interior (its cheaper) and i was wondering if these were a good idea or should i just spray paint them? i also have a white car and i was wondering if white is a good color for them since they would get dirty really easily and the dirt would be really noticable. any input is appreciated, thanks ahead of time.
Old 10-18-2003, 05:42 PM   #2
wiarumas's Avatar
and for those who dont know what im talking about...
http://www.mwspeedshop.com/jamz/jamz1.htm
Old 10-18-2003, 05:45 PM   #3
Send a message via AIM to Requiem
I personally think if you take out the door jam and paint it, it looks like 10x better than those vinyl things. :thumb2:
Requiem is offline   Reply With Quote
Old 10-18-2003, 09:34 PM   #4
Send a message via AIM to DropTop_Stang
Yeah, just take them out and paint them if you want color. What color is your interior? Because some interiors don't look good with colored parts.
-Brian
Feel free to hit me up for questions or chat at AIM: LostMe 03
Keeping my car.
DropTop_Stang is offline   Reply With Quote
Old 10-18-2003, 09:38 PM   #5
wiarumas's Avatar
my interior is grey and black.
Old 10-19-2003, 09:29 AM   #6
MusclesFromBrussels's Avatar
Send a message via AIM to MusclesFromBrussels
i had the yellow decals from MW they worked good and looked good
MusclesFromBrussels is offline   Reply With Quote
Old 10-19-2003, 11:14 AM   #7
wiarumas's Avatar
how long did they last? i notice you say it in the past tense... what did you do?
Old 10-19-2003, 08:45 PM   #8
they lasted forever never faded or anything i just decided i wanted to have an all black interior again and took em off.
Old 10-19-2003, 09:26 PM   #9
Zim
You want to **** me?
Zim's Avatar
If youre going to paint them, make sure you do it right. Make sure there are no chips or scratches in the door jam to begin with otherwise the paint will start cracking and peeling away.
I like toys
Old 10-19-2003, 09:34 PM   #10
Black95GT's Avatar
Send a message via AIM to Black95GT
Mine has a scracth how should I prep it before painting, I am using the Duplicolor paint with a clearcoat to put over paint, or no clear coat, just paint?
-Jason
2003 DSG Cobra -2.2L KB, 60lbs Injectors, Single Blade TB, SCT2400 MAF, Kook's LT's, Kook's High-Flow Catted X-Pipe, Magnaflow CB, JLT RAI, MGW Short-Throw, H&R Race Springs, MM CC Plates, MM Bumpsteer, BF IRS Brace, BF Idlers, and AFS 18 Chrome Reps w/ R888s
Black95GT is offline   Reply With Quote
Old 10-19-2003, 09:45 PM   #11
Zim
Zim's Avatar
defanitely use a clear coat unless its something like metallic paint or something like that. Just make sure the paint and clear coat actually go INTO the crack, and dont just make a little pocket coating over the top of it. Its also a good idea to use some rubbing alcohol or some sort of cleaner that will get rid of any grease or oils that might be on it. If you dont prep it right.. it will look like theres bubbles in the paint. Clearcoat is going to give you the shiny look that you want... so Id defanitely recommend doing that over just a glossy paint.
I like toys
Old 10-19-2003, 09:58 PM   #12
Black95GT's Avatar
Yea i got primer too so the paint holds better
-Jason
Old 10-19-2003, 09:59 PM   #13
Zim
Zim's Avatar
good call
I like toys
Old 10-19-2003, 10:07 PM   #14
Black95GT's Avatar
yup
-Jason
Old 10-21-2003, 07:55 PM   #15
KrazyPony's Avatar
Here is mine, I have the Black/Silver cobo going on in my 98 that is white!
I painted my interior pieces Black/Silver and used the Silver door decals...
http://www.rhythmuniversity.com/donna/Upstate%20Mustang%20Club/Members%20Rides%20June%201/Output/pages/DSC00116.htm
http://i201.photobucket.com/albums/aa307/KrazyPony/KrazyPonysigBlue.jpg
KrazyPony is offline   Reply With Quote
Old 01-20-2004, 05:32 PM   #16
Send a message via AIM to Hockeyb0y3
i HAD the door jams . . i musta god bad ones cause they didn't work verry well and i wish i saved my $12
Hockeyb0y3 is offline   Reply With Quote
Old 01-20-2004, 09:29 PM   #17
It might be worth it to get a very fine grit sand paper and go over everything either...I did this to a s10 i recently painted the interior on. We went over it all with 120 grit at first, primed it, painted with car paint, clear coated (sanding inbetween each coat) and went over the whole thing with what must have been a 240 grit, didn't pay that much attention, he had it laying around. Turned out really nice. I'll get some pictures up when we finish everything.
Old 01-21-2004, 04:00 PM   #18
Dom
Dom's Avatar
Send a message via AIM to Dom
Best paint to do it with is Krylon Fusion. It will bond with the plastic on a molecular level. Plus Krylon is real good about spraying flat instead of circular.
Old 01-21-2004, 04:10 PM   #19
Send a message via AIM to Crispy
The fusion cans also have a special nozzle that makes spraying evenly a simple and joyful experice.
No im not employed by Krylon...yet
Crispy is offline   Reply With Quote
Old 01-21-2004, 04:39 PM   #20
Dom
Dom's Avatar
Takes alot of spray painting to figure that out. Or someone told you.
Old 01-21-2004, 09:01 PM   #21
KrazyPony's Avatar
It took me a while to figure out what the hell door jamz were until I saw the MW pic, I'm like WTF MAN...
I just painted the door bezles and upper small vents in the dash on the corners too in my wifes mach1 silver, they look pretty good... I would say the most important thing to remeber is to be patient with them in the drying process, dont be in a rush to have them installed or you may be very very VERY MAD with yourself, being that they dont always just slide right into place when installing them back into the door, I found this out first hand myself when doing my car on the 1 side.
When I painted this set, I let them dry in the basement hanging from clothes hangers for about 3wks... And then they got installed....
How do you take out the Vents just below the light knob and over towards the glovebox compartment aswell, she would like those painted to the silver trim now too
Thanks!
Old 01-21-2004, 09:23 PM   #22
Dom
Dom's Avatar
Under the glove box, when you open it, there are two bolts. Just don't break the vents unbolting or bolting them back on.
Now, on the driver side, gets harder. When I was putting my switch panel on, I couldn't even see if I could get the gaurd off.
Old 01-22-2004, 01:07 AM   #23
the trick to the interior paint is the prep. PREP PREP and PREP some more sand those mofos till ALL the rubber is gone before you do anything or else you will always see the fuggin lines, its verry easy and looks great when done, i did 320 then 600 wet dry sand paper works the best, mostly cause stuff last forever! anyway sand all the rubber off primer sand paint clear coat . . .yes its that simple kids
Martin
Anyone know how to remove a door panel? 00stang3.8 Pre-2005 V6 Mustang 15 04-04-2007 09:22 PM
Door Panel Problems Justin 1979-1995 Mustang GT 8 10-11-2006 01:51 PM
Door Panel Removal Hints? Mustang Mike Classic Mustangs 2 02-23-2006 03:47 PM
2004 door panel speaker removal drwang Mustang Audio & Video 3 10-13-2005 07:43 PM
door panel insert idea Bane- Pictures and Videos 4 05-27-2005 12:19 PM
05:59 PM
