Remote Start? - Mustang Evolution
Old 01-29-2007, 03:12 PM   #1
Send a message via AIM to 98StangGT
Remote Start?
Can you get remote start on a standard vehicle?
98StangGT is offline   Reply With Quote
Old 01-29-2007, 03:15 PM   #2
meteorachick's Avatar
Re: Remote Start?
by standard are you refering to the transmission? i don't know if u can because you have to have the car in park in order to activate the remote start, i could probably find out for ya though. btw i have prestige remote start and its freakin awesome, its my favorite feature
Modified 2004 V6
Old 01-29-2007, 03:18 PM   #3
Re: Remote Start?
yea that would be great if you could find out, thnks
Old 01-29-2007, 03:20 PM   #4
Re: Remote Start?
okay after further research--
it can be done BUT it most states, its illegal, so it may not be worth it. you just have to leave the car in gear so that it would start, but its not a good idea.
Modified 2004 V6
Old 01-29-2007, 03:24 PM   #5
Re: Remote Start?
In gear? How is it going to start with the car in gear and the clutch not depressed? or is there some mechanism that disengages the clutch without depressing the clutch pedal?
Old 01-29-2007, 03:25 PM   #6
Re: Remote Start?
not sure, i called around to a couple of my friends that have it and asked them what they do. i think at night instead of putting it into neutral, they just leave it in first with the ebrake on. then when you go to the remote start it tricks the car to thinking its in gear.
Modified 2004 V6
Old 01-29-2007, 03:28 PM   #7
Re: Remote Start?
There would be no tricking needed since if it is in first, it is, in fact, in gear.
I did a quick search and the 1 quick thing I found said you can't leave it in gear as it would quickly jump forward...you would need to leave it in N with the e-brake on. Then, there is a relay that would trick the car into thinking the clutch was depressed.
This is no in depth research...but it did also state that it is illegal in most states to install it on a manual like you said.
Old 01-29-2007, 03:30 PM   #8
Re: Remote Start?
ah that makes sense, but yeah, its illegal
Modified 2004 V6
Old 01-29-2007, 04:16 PM   #9
MonteCitan's Avatar
Re: Remote Start?
As a previous ford mechanic, who used to install 'factory' remote start systems..
1) It is illegal to install remote start on a manual trans car
2) if you DO install it on a manual trans car, make sure you use neutral all the time, and that your ebrake is strong enough to hold the car
3) to install it they bypass the clutch pedal position switch, which would normally need to be activated to start a vehicle...
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 01-29-2007, 04:36 PM   #10
Re: Remote Start?
As a n00b and part owner/operator of Back Yard Customs, Inc....What he said.
Old 01-29-2007, 06:56 PM   #11
all8280bcc's Avatar
Re: Remote Start?
im with monte you can install it. It is illegal and if you leave it in gear and try to start it for your friends they get a great laugh watching it jump into a wall (like i got to see personally) But i know many people who have done it.
00 Mustang GT: Upr x-pipe,Magnaflow Cat-back, MAC intake with 60mm mass air, underdrive pulleys, 3:73, and tuned
01 CBR RR: Full Erion exhaust, power commander, and intake
all8280bcc is offline   Reply With Quote
The Perfect Remote Herbstang The Bar 11 08-08-2007 09:47 PM
keyless remote carlosc Pre-2005 V6 Mustang 2 03-14-2007 07:48 PM
Remote Starter Help Justin 1979-1995 Mustang GT 2 11-28-2006 06:05 AM
Help! Need Keyless remote id# BuddyLee Mustang Audio & Video 5 06-03-2005 06:15 AM
Remote Start SeadudeRXP Pre-2005 V6 Mustang 16 03-21-2005 06:35 PM
10:57 PM
