Headlights Cleaning - Mustang Evolution
Old 03-28-2007, 02:16 PM   #1
Seph's Avatar
Headlights Cleaning
I'm going to attempt this when I get back home from class, is it pretty simple? I haven't even looked at anything yet.
I just assume I'm going to open the hood, take the screws outta the headlight holder and pop the thing out.
Sound about right?
-Patrick
http://home.socal.rr.com/sephiros/images/NewBan.jpg
Seph is offline   Reply With Quote
Old 03-28-2007, 02:19 PM   #2
rydog's Avatar
Send a message via MSN to rydog
Re: Headlights Cleaning
Sound about right?
I actually dont ever take any screws out i use needle nose plyers and squeeze the black gromets the screws go through and pop them back through the holes and pull the headlight out
97 V6-GT40 turbo-42#rs-BA2800 MAF-4.10's & tlok-254rwhp-369rwtq
Turbo'd by-TMA Turbo(http://www.tmaturbo.com/)
Tuned by-Dyno Tuned Performance(http://www.dtpracing.com/)
rydog is offline   Reply With Quote
Old 03-28-2007, 02:24 PM   #3
bluemustang's Avatar
if i remember correctly arent the 99+ on some slides that you gotta pull out?
Old 03-28-2007, 02:51 PM   #4
Seph's Avatar
Hrm I dunno. I do know about the black tac like things that are planted in there. After I washed my car, cleaned the rims, I looked at the headlights and sighed. All foggish and they look dirty on the inside.
I remember someone cleaning their headlights awhile ago and they turned out great. I found an old picture of my Mustang when I first got it, the headlights looked great. I want to at least get it looking back to when I first got it stage
-Patrick
Old 03-28-2007, 03:49 PM   #5
Restoring Ford Mustang Headlights
Old 03-28-2007, 05:23 PM   #6
Cajun JungleBoy's Avatar
Send a message via AIM to Cajun JungleBoy Send a message via Yahoo to Cajun JungleBoy
advance auto parts has a headlight cleaning kit... hear it works very well
Cajun JungleBoy is offline   Reply With Quote
Old 03-28-2007, 05:27 PM   #7
Seph's Avatar
Quite a lot of steps in that O_o
And things I don't have.. The final product looks great, but geez..
-Patrick
Old 03-28-2007, 07:00 PM   #8
you pull the two pins holding the headlight in then you put a cloth in front of the headlight to keep the paint from being scratched then you pull out on the headlight making sure you pull directly forward so it doesnt get hung. Then it comes out and you carefully unplug it trying not to break the clips. Thats it.
Old 03-28-2007, 09:11 PM   #9
The clips break, part of it lol. Now when I pull my headlights out the bulbs pull themselves out...but it works.
Old 03-28-2007, 10:24 PM   #10
Seph's Avatar
O_o I'm nervous now lol
-Patrick
Old 03-29-2007, 07:29 AM   #11
yea the clips do suck pretty good, even if they break its not a big deal they still hold on there fine just try not to break them if you can help it.
Old 09-06-2007, 02:12 PM   #12
Seph's Avatar
Alright, I tried the steps on trying to restore the headlights from that link Brent posted, but it only made my headlight look worse. I'm pretty sure all the dirt and stuff is on the inside, I can see a lot of moisture inside of the headlight itself. I may have to just buy new lenses if I can't repair the one lens I tried restoring. I used the really soft sand paper, used the restore solution and the plastic cleaner, nothing worked.
-Patrick
Old 09-06-2007, 02:55 PM   #13
What do you mean by soft sandpaper? Did you use the 1500 and 2000 grit that was mentioned in the writeup?
Old 09-06-2007, 04:15 PM   #14
Seph's Avatar
I just used what I had on hand when I sanded down my Garand wood, the stuff is pretty light. Figured there wouldn't be much of a difference?
-Patrick
Old 09-06-2007, 06:20 PM   #15
Look on the back of the paper, there should be a number on the back. If it says anything under 800 it's gonna take alot to get it back....
I did mine with 800, 1200, 1800, 2400, and 3000 then rubbing compound, a coat of polish, and a few coats of wax. Still not perfect, but alot better.
BTW, wet sand it....makes it alot better...as in sand with water running over the headlight, this will not be as abrasive.
Old 09-06-2007, 06:35 PM   #16
OsirisGuy's Avatar
I was able to get the yellow out of my headlights with 600 and then 1500 wet. I forget where but I heard 600 was fine to use and 1500 was also listed and also the finest grit I was able to find. I also did it wet, which I suggest and isn't really all that more difficult to do. My instructions also suggest Mother's Mag and Aluminum Polish to restore the plastic from all those little microscopic scratches. My headlights are still a little foggy but I didn't finish off with wax or a hard polish and buff. My car is also a lot of work so that might of made it harder to get out and others might find other results.
I think over at AmericanMuscle.com they have a tech article on resealing headlights to stop condensation.
I'm just happy they aren't yellow anymore and at night the light is much clearer and not as fogged up as you would think.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 09-06-2007, 10:51 PM   #17
Seph's Avatar
My lens is kinda messed up, I'll take pics of it tomorrow so you guys can give me any suggestions. I think the stuff is built up on the inside, and I'm going to have at it with the headlights tomorrow as well. Pics will be taken to show the progress and how badly I am doing
-Patrick
Old 09-12-2007, 05:19 PM   #18
Seph's Avatar
ok the headlight is OUT.
How the hell do I get the covering off of it now so I can actually clean the inside of it?
-Patrick
Old 09-12-2007, 05:42 PM   #19
Seph's Avatar
nevermind, this **** isn't coming off. **** it I'm just getting new headlights. This **** is impossible to get off. Used the cleaning solution, the sandpaper, windexing it, and even simple green doesn't even do anything to the headlights.
-Patrick
Old 09-13-2007, 12:40 AM   #20
Do exactly what the directions say and it works great. I did it on my old Roush and my headlights looked brand new.
JROC is offline   Reply With Quote
Old 09-13-2007, 09:31 AM   #21
Thomas91169's Avatar
just buy new ones and protect them from the start. theyre what, 100-150$ on ebay?
-Thomas-
Old 09-13-2007, 01:54 PM   #22
wiarumas's Avatar
i cleaned mine before... it was pretty easy. i followed that article prettly closely. the results were really great. the downside... i had to clean them again in a few months.
Old 09-13-2007, 06:10 PM   #23
Seph's Avatar
I'm just going to buy new ones. I think it was because this one year I didn't wash my car for a few months? lol?
Mostly because we had a lot of off and on rain that made it very inconvenient.
-Patrick
Old 09-13-2007, 10:31 PM   #24
thats another good point.
once you do the process, your have to keep up on the headlights, and you have to likely repeat the above process sooner and sooner, until youre doing it almost every other wash.
my cousin had this with his 86 eclipse, it had the drivers side headlight haze issue that every 95-96 gets. it was every month he would wetsand, polish, wax, etc. finally i found a new one on ebay for 40$ and picked it up for him.
-Thomas-
Old 09-14-2007, 07:15 AM   #25
I have owned 3 stangs and NON have ever had headlight haze... WTF are you guys doing to them???? I mean take care of them when you clean the rest of the car and your golden... do you people also never put any protection on your black trim parts/panels... or just assume car wash soap will protect them lol?
Old 09-14-2007, 08:50 AM   #26
Seph's Avatar
Mine don't have that haze to it, it's this nasty grimey ****. No yellowing or anything like that.
-Patrick
Leather cleaning help sailorsstang06 2005-2010 Mustang GT 2 04-09-2009 09:16 AM
cleaning question shamdoodie Mustang Audio & Video 12 09-24-2007 12:43 PM
cleaning help!!!! millastang Pre-2005 V6 Mustang 3 06-21-2007 09:39 AM
Cleaning rims The Arson The Bar 4 04-11-2005 03:54 PM
I am cleaning my keyboard! 03redfire cobra The Bar 4 05-18-2004 11:11 PM
09:14 AM
