factory amp + system: - Mustang Evolution
Old 10-23-2003, 09:07 PM   #1
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
I forgot i have fords factory amp in my 95 under the stock head unit.
If i plug in a new deck, and wire in amplifiers and woofers will everything be ok?
Rellik is offline   Reply With Quote
Old 10-23-2003, 09:42 PM   #2
Black95GT's Avatar
Send a message via AIM to Black95GT
I didnt have a facotry amp in my 95...if there was I took everytrhing out lol
-Jason
2003 DSG Cobra -2.2L KB, 60lbs Injectors, Single Blade TB, SCT2400 MAF, Kook's LT's, Kook's High-Flow Catted X-Pipe, Magnaflow CB, JLT RAI, MGW Short-Throw, H&R Race Springs, MM CC Plates, MM Bumpsteer, BF IRS Brace, BF Idlers, and AFS 18 Chrome Reps w/ R888s
Black95GT is offline   Reply With Quote
Old 10-23-2003, 09:43 PM   #3
I got one, dont got mach 460 either.
Old 10-23-2003, 09:55 PM   #4
Black95GT's Avatar
I didnt have the Mach i had the premium audio package, and there was no amp
-Jason
Old 10-23-2003, 09:59 PM   #5
how much power are these things rated for, i saw a page on them before, i believe it was 60w. But i cant find that page anymore.
I just dont want ti to burn out the headdeck or anything.
Its wired right into the head units harness........
Old 10-23-2003, 10:03 PM   #6
Black95GT's Avatar
well you wont need it the new headunit will power speakers take it out, and hook in the HU, if the Wire Harness doesnt match like mine did, there is a 2nd set bolted to the fram behind the dash for radio too....I had to use the other set to do mine, but all my speakers are wired to my amp which was a *****
-Jason
Old 10-23-2003, 10:04 PM   #7
you have to by pass the amp
I will tell you how to do it tomorrow
Old 10-23-2003, 10:05 PM   #8
the head units harness is a combined harness WITH the amp.
Old 10-24-2003, 06:31 AM   #9
Are you wanting to just amp your subs? If that's all you're wanting to do, go to any competent car audio place and get a wiring harness specific for you setup. Then get some tap in clamps you just clamp to your speaker wires that will give you outs for your sub. You won't even be messing with the factory amp at all. Once you've done this, connect the rca plugs to the end of the wires you clamped in and run directly to the amp. Something else you'll have to do is find the "remote" wire running to your head unit. This should be labeled on any aftermarket unit....actually, come to think of it, any aftermarket unit should have pre-amp outs on it already. Wasn't thinking when i started this and i'm too lazy to delete it. Ok, ignore me, I'm officially out of it now. So i just wrote a whole bunch of bs...
Running power around the factory amp to the speakers Kiljosh Mustang Audio & Video 0 01-06-2007 09:17 PM
K&N Air Intake System Cajun JungleBoy Pre-2005 V6 Mustang 18 04-11-2006 08:32 AM
Remove factory amp. ASSEMbler Mustang Audio & Video 3 07-29-2003 04:48 PM
Used factory Ford 7.5 3.73s & T-loc --- Any Good? Stang01 Pre-2005 V6 Mustang 24 07-18-2003 04:40 PM
12:02 AM
