sticker on paint - Mustang Evolution
Old 04-24-2007, 06:41 PM   #1
powerhungry966's Avatar
Send a message via AIM to powerhungry966
sticker on paint
how do u remove stickers from your car w/o scratchin da paint.. some ******* stuck a postal sticker REAl StickY **** on my car
1989 coupe 5.0 yeessur.
"Shake n bake"
powerhungry966 is offline   Reply With Quote
Old 04-24-2007, 06:48 PM   #2
jimmy_beaner's Avatar
Region: Iowa
Re: sticker on paint
WD40 and a soft towel? Maybe?
Old 04-24-2007, 07:04 PM   #3
The easiest way will probably be to heat it up either with the sun or a hair dryer.
Whatever residue is left you can get off with a clay bar fairly easily.
Old 04-24-2007, 07:08 PM   #4
heat it up (but don't heat the paint to much or it can mess it up) and try to slowly peal it off
Old 04-24-2007, 08:45 PM   #5
bluemustang's Avatar
Hair dryer on low,
heat the area (try not getting the paint)
Then start peeling off
whatever adhesive is still left put some goo gone over the area
if theres still stuff left on it last resort use a claybar
BTW what a bunch of dicks
Old 04-25-2007, 12:43 AM   #6
yeah wat i get for living in a area w/ a buncha baby booming muther fukers hhaha... n i tried goo gone... and not even that miracle doesnt work...
"Shake n bake"
Old 04-25-2007, 08:46 AM   #7
try turtle wax bug and tar remover. i use it to gets the tire rubber of my carat the end of the season.
02vert is offline   Reply With Quote
Old 04-25-2007, 10:14 AM   #8
Use a razor blade very carefully to slowly remove it. Then wax the area to remove the left over sticky residue.
Old 04-25-2007, 10:16 AM   #9
man if you really need to use a razor my best advice on that is to tape the edges of the razer cause if you slip the wrong way those edges will bring up that paint up with the quickness
Old 04-25-2007, 10:46 AM   #10
Stumpy's Avatar
i would not let a razor blade near my car. you asking for a nice scratch in your paint. try diluted solvent. soak it pretty good and then slowly pull at the edges. and if that doesn't work, a pressure washer sprayed at the edges would probably do the trick. just don't get too close to the paint for too long in one spot. if the pressure is hard enough, that can lift the paint as well.
~Roman~
2003 Mustang V6 Vert with a Flowmaster Super 40 series dual exhaust
I'm not a target in the sights of your mercy. I've never asked for anything. I'm not asking now.
Stumpy is offline   Reply With Quote
Old 04-25-2007, 06:16 PM   #11
matthews.stang's Avatar
That plus Windex got rid of the residue on my window from a sticker.
matthews.stang is offline   Reply With Quote
Old 04-25-2007, 06:39 PM   #12
Gas will remove sticky stuff. Only use it as a last option.
Old 04-25-2007, 06:41 PM   #13
bbunt302's Avatar
You know what else will remove sticky stuff?
More sticky stuff.
Just a thought.
Scary stuff.
Old 04-25-2007, 06:50 PM   #14
mike05gt's Avatar
GOOF OFF works great
mike05gt is offline   Reply With Quote
Old 04-25-2007, 07:18 PM   #15
well i tried all those cept for the razr n the sticker came off but now im left with the sticky ****..FUK
"Shake n bake"
Old 04-25-2007, 08:22 PM   #16
Windex got rid of mine.
Old 04-25-2007, 09:00 PM   #17
Did you try Goo Gone again? like actually let it sit for a minute?
If not a type of Wax and Grease Remover will get that off as well I dunno if you have any laying around or not ya know.
Claybar??
Old 04-26-2007, 01:23 AM   #18
Thomas91169's Avatar
hrm, i used gasoline on a sticker i had on my gst when i bought it. ****ing "I <3 Sweeden" sticker, wtf? i used a heat gun to get the sticker off, and gasoline to get the goop off. then followed up with soap/water and a layer of wax around the area.
-Thomas-
Old 04-26-2007, 02:24 AM   #19
Yes! success ! i got it off using bug tar!! its waxed n ready to go right on guys! saved +100
"Shake n bake"
Old 04-26-2007, 08:25 AM   #20
nice
Rejection sticker HELP!!! Mustang1804 1996-2004 Mustang GT 13 04-29-2010 07:27 PM
M.E. Sticker 2007STANG Pre-2005 V6 Mustang 33 08-23-2009 11:58 PM
Sticker placement Mustang GT HO 1996-2004 Mustang GT 19 06-14-2008 03:21 PM
New Bumper Sticker Herbstang The Bar 2 02-17-2006 11:46 AM
01:50 AM
