How-To: Angle Eye Headlights - Mustang Evolution
Old 05-23-2007, 12:56 AM   #1
matthews.stang's Avatar
Found this on a website. Thought it was kinda cool.
Angel Eye? What is that? 'Angel Eye' is a cool headlight feature found on the new (2001+) BMW 5 Series. The projector headlamp unit on the BMW 5 series has a pair of circular-shape rings that when light up, they produce a pair of halos. BMW calls them 'Angel Eyes'. They are also referred to as 'Demon Eyes'. They look very nice on the BMW 5 Series. They don't serve any purpose other than for the nice and aggressive look, and to distinguish the newer BMW 5 Series from other BMW models at night. Great design for an already-great looking car. Would definitely look awesome if BMW put them on the 3 Series.
My install is a little different from the BMW. Only three quarter of the rings are lit up, like a crescent moon. They are not exactly like the full circle of the BMW's Angel Eyes. Only BMW deserves the full circle; my humble CRX is not worthy enough for the full circle, but it still looks great!
Creating Angel Eye Rings
Instead of a round glass rod used by BMW, I used a clear acrylic/plastic rod. I bought it for $1.97 at a home improvement store, such as Home Depot. Not all Home Depotís carry them, so you may have to shop around. The rod is actually made for your window blind to open/close the blind when you turn it left/right. It is about 2.5 feet long with a diameter of 8mm, and you can create 2 angel rings out of it. The rod has a hex-shape structure, not a round shape like the BMW, but it will do just fine because this reflects more light.
The first thing I did was to create a circular ring out of it. I measured the diameter of my high-beam projector housing, which comes out to be 4" (or 2" radius). Usingthe circular formula (C=2'pi'r, where pi=3.14), you'll have to cut your rod about 12.5 inches long. I suggest cutting it 15" long, and use the extra inches as handles to help in the molding process.
Next, I find an aluminum can or jar that has about the same diameter as the ring (I used a peanut jar). After heating the rod in a small toaster oven for about 5-7 minutes at 300įF, I held the two ends of the now flexible rod with a pair of pliers, and wrapped them around the peanut jar with one end crossing over the other end.
For better control, you can wear your winter gloves or use your socks. The flexible rod will harden within a minute. So, you may have to repeat this step 1 more time to mold it into a perfect circular ring.
Once done, you can use a Dremel tool to cut the extra handles that were used during the molding process. You will end up with one end above the other, as shown.
Don't worry; later when you wrap electrical tape around the rod to hide the LED bulbs, the two open ends will realign themselves. If you like to be perfect, you can simply put it back in the oven one last time and allow the ends to soften and flatten.
To test out how it lights up, I put a small halogen bulb between the open ends of the ring. "Wait a minute here, young man. It doesn't look like 'Angel Eye'. No halo ring effect. You suck!" Yes, I know. That is because light goes in a straight line, and it takes the shape of whatever object it goes through. In this case, it goes through one end of the rod and out the other end, like a fiber optic cable.
Making The Eagle Ring Light Up
In order to make it lights up like the true 'Angel Eye', I had to refract the light as it goes through the rod by making multiple cuts (scratches) along the rod, using a Dremel tool. Each cut/groove allows the light to 'escape' the ring. Each cut is about 2~3mm apart. Don't make the cuts too close to one another. This will make your ring look like a continuous band of light, like those glow-in-dark flexible toys. In my opinion, the ring look better and more sophisticated with the cuts evenly space out.
It will take about 2 minute to do the cuts using a Dremel tool. If you don't have a Dremel tool, you can use a small saw or a butter knife, but will take you longer. A Dremel tool set would cost about $30. It has many uses, such as cutting, sanding, carving, buffing, etc. Good tool to have for hobbies.
Hint: To get the cuts look perfect, you can do the cuts ahead of time before making a circular ring out of it. You only need to make the cuts along 1 of the 6-sided rod.
Doing 2 or more sides will make your ring look dimmer, because most of it has 'escaped' before it reaches the other end of the rod. Also, let the cut side be the backside. When you turn it over to the front, the hex shape, which acts like mirrors, will multiply the cuts and the cuts are brighter too. The light appears to be refracted inward (take a look at the pictures below on the right to see what I mean).
With a Dremal tool, you can
create the cuts in 2 minutes.
Full view of angel eye rod.
Cuts along the backside of the rod.
On the front side, the cuts are multiplied by the hex-shape.
Angel eye with some foreground light.
The halo ring effect is more noticeable at night.
LED Light For My Eagle Eyes
I suggest you use LED lights for your angel eyes. I was only using halogen bulbs to test out my ring. Halogen bulbs are very hot and may deform your acrylic rod. It is inefficient, and doesn't last very long. You don't want to take apart your headlight to replace the bulb every time it burns out. The purpose of Angel Eyes is not to light up the road, but for look. As such, I suggest using LED bulbs.
LED bulbs are very efficient, last very long (no filament to burn out), and produce very little heat. The LED bulb along with the resistor use less than 1W of power, compare to a 35W halogen bulb used in the real BMW angel eyes. LED bulbs are bright too even though they are only 1 mcd. If you ever pointed a key chain with LED light toward your eyes, you know what I mean.
LED bulbs are used in street signal lights, jumbo television, car alarm indicator etc., for their efficiency and reliability. They are bright in the day too. Hence, they are now being used in Mercedes S Class and Infiniti G35 taillight and stoplight.
LED light comes in many different color, red, blue, orange, yellow, green, and white. Red is really nice and will definitely make your car stand out, but I used white LED to be compliance with state laws. They even come in multi-blinking colors too; just in time for the holidays, but I think cops love them. They'll be happy to turn on their lights when they see them. (I am not responsible for any tickets)
Angel Eye with yellow LED.
Angel Eye with blue LED.
Angel Eye with red LED.
Angel Eye with white LED.
They cost from around $3 to $4 each at your local Radio Shack store. Note that LED bulbs are not like halogen bulbs where you can just connect positive and negative wires to them to light them up. You must use a resistor. The purpose of the resistor is to limit/resist high current going through the LED bulbs. LED bulbs require only a small amount of current to light up. Hence they are very efficient. Resistors should cost about $1 for a set of 5 at a local store like Radio Shack. Very cheap!
Resistance is measured in ohms. To get the correct resistor for your LED, use this modified version of Ohm's Law:
Ohms = ( V.bat - V.led ) / Amp.led. where V.bat = voltage of battery, V.led = voltage of LED, Amp.led = Amp of LED
When you buy the LED bulb, it will tell you the voltage and amp used. Just plug them into the equation to get the Ohms value. In my case, I have a 12V battery and a 3.6V LED with 20mA (or .02A). So, I used a resistor of 420 ohms [(12V - 3.6V)/.02A]
You can use a lower ohms resistor, eg 220 ohms, to light up your LED. In fact, it will make your LED brighter because low resistance allows more current to go through the bulb. I have been doing this for 3 months now and still havenít had any problems.
Also, you must attach the resistor to the positive terminal of LED bulb, which is the longer of the 2 terminal legs. I suggest that you attach a wire to the LED bulb first, and then attached a resistor at the end of the wire on the positive terminal. This will give you flexibility because the resistor will be outside your headlight unit and you can change it if you have a need to do so later, like changing to a lower resistor to make your Angel Eye brighter.
A white LED bulb.
Positive is the longer terminal.
A 1100 vs a 2000 mcd LED bulbs.
mcd (milli-Candela) measures brightness.
A 220 ohms resistor. Resistors
restrict current going through a bulb.
Resistor connected to positive lead,
which is the longer one.
Securing LED Bulbs Inside Eagle Eye Rings
To secure the LED bulbs into my Eagle Eye rings, I drilled a hole in both ends of the ring, about 6mm wide and 5mm deep. I used two white LED bulbs and parallel
paired them together. After soldering a foot-long wires to the positive and negative legs of the LED bulbs, I wrapped black electrical tape around the legs to keep them apart. I will attach the resistor to the end of the wire later when I connect the wire to my parking light.
Next, I inserted the bulbs inside the holes of the ring, and wrapped black electric tape around it to hide to LED bulbs. This will also hold the bulbs and the two ends of the rod in place. DO NOT paint the rod black. For some reason, the black paint will absorb the light and will make your angel ring look dim. If you plan to wrap the black tape around the uncut/unused part of the ring, make sure you wrap some aluminum foil around them first before wrapping the black tape. The aluminum foil will reflect
the escaping light back into the ring, making the ring brighter.
Angel ring with a 5mm hole.
LED bulbs inside ring.
Use black electrical tape to secure and hid the bulbs.
Taking Apart My Projector Headlight
Next, it was time for me to put them into my HID projector headlight unit. First, I had to open apart my headlight unit. This is done by heating it in a cooking oven for about 10-15 minutes at 275įF or until the glue loosens. It may take a longer or shorter time to soften the glue on different headlamp units. Remove any attachments, like your bulb or wire harness, that may not be able to withstand the heat. Be very careful when separating your projector unit because the glue will stick to anything it can get a hold of. Think of hot melted cheese on a slice of pizza when you pull it apart.
Here's my recommendation: As you pull apart the front cover from the headlight unit, cut/trim the cheesy web-like glue using your hand. The glue is not that hot, but the headlight unit is. Remember, pull a little and then trim a little, and repeat this step. Take your time and do it SLOWLY. You have about 20~30 minutes before the glue harden. Plenty of time. As you trim, the glue will retract, and you can reuse the glue later when re-attaching the headlight back together. I have done this process about 4 times already, and the glue is still good and I have no problem with rain fogging up the headlight.
Cheesy-like glue.
Components of my projector headlight with angel eyes glued to black frame.
My aftermarket projector headlight is divided into 3 components, a reflective housing, an internal black frame, and a clear front cover. I glued my angel rings to the black frame, using clear silicon adhesive or Crazy/Super glue. I applied only a very small amount of glue to the un-scratch/un-cut part of the ring. The inner black frame acts as a barrier and helps protect my angel eyes from the heat coming from the reflective housing.
Putting the Headlight Back Together
Next, it was time for me to re-attach the front cover back onto the headlight unit, using the same glue. Just reheat them in the oven until the glue softens again. Very important, I only had to heat the reflective housing and the front cover. You don't need to reheat the black internal frame. Plus, the angel rings on your black frame may deform.
Once the glue is softening again, I took out the reflective housing and the clear front cover. I put the black frame with the angel rings back onto the reflective housing.
Then I ran the wire from the angel ring through the water drainage opening of the housing. Now, I put the clear front cover back onto the headlight housing. Remember to apply pressure to get an airtight hold. I had to sit on it to get this done. I also used clamps to make a tight seal.
High-beam housing without Angel Eye.
High-beam housing with Angel Eye.
Angel Eye at work with halogen bulb.
Close-up shot.
Finally, I put the headlight unit back onto my car. With a 220 ohms resistor attached to the positive terminal of the LED wire, I made a parallel connection to my parking lights. You can connect it to anything, an external light switch, high beam, running light, etc.
Miscellaneous Pictures of My Angel Eyes At Work
For those who don't like getting their hands dirty or don't have any free time and have money to spend, you can buy the real quality BMW Angel Eye on the web. These Angel Eye kits, AKA 'Demon Eyes' kits, are made exclusively for BMW headlights. The kits will use 2x 35W halogen bulbs, which are mounted, inside the engine compartment area, and the light is being feed into the angel rings via fiber optic cables. I don't think its 100% plug-n-play. You still have to open up your projector housing, fit the Angel Eye inside, and connect the wires. Also, make sure your car can handle an extra load of 70W of power, and that you have some amble cooling space behind the headlight to mount those 35W bulbs. The fiber optic cables are about 1 foot long.
There are also aftermarket projector headlights with built-in LED Angel Eye rings, but not one made for a CRX I liked them so much that I had to do it myself, and I found the process to be fun too.
Imagine a BMW Z3, an Audi TT, a Honda S2000, a Supra, a Celica, a Miata, a 300Z, a Beetle, and not to mention a 2nd or 3rd generation Eclipse coming down the street with Angel Eyes and creeping toward you from behind. Makes me scared and nervous just thinking of it.
matthews.stang is offline   Reply With Quote
Old 05-23-2007, 11:31 AM   #2
Herbstang's Avatar
Re: How-To: Angle Eye Headlights
Nice How to But does it come with a bowl of rice
Old 05-23-2007, 12:13 PM   #3
Zim
You want to **** me?
Zim's Avatar
Cheesy rice at that!
I like toys
Old 05-23-2007, 05:50 PM   #4
Kiljosh's Avatar
Well, I like them, looks good with the eyes angled slightly, mine just light up fully.
Old 05-23-2007, 05:53 PM   #5
bullitt482's Avatar
See if I made a post like that, bbunt would have tore into me.
But yeah, so would that be long grain or short grain rice??
J/K Great info and good right up.
01 Bullitt
Old 05-23-2007, 06:35 PM   #6
Zim
Zim's Avatar
Ill tell you a secret [whisper] He has a stick up his *** :yup: [/whisper]
I like toys
Old 05-23-2007, 07:05 PM   #7
bbunt302's Avatar
It's a good thing I can't read.
Scary stuff.
Old 05-23-2007, 08:34 PM   #8
bluemustang's Avatar
thats something thats pretty cool, good find
Old 05-23-2007, 09:28 PM   #9
Since most angle eyes will burn out after sometime, this could benefit those with projector headlights.
Old 05-23-2007, 09:43 PM   #10
Kiljosh's Avatar
Yea Ill keep this post in mind if I ever want to brighten mine up or change the colors.
Old 05-24-2007, 04:55 PM   #11
bullitt482's Avatar
Now that you mention it your right. A few of the imports around here(cleaner non ricer ones) had problems with them burning out all the time.
01 Bullitt
split port heads Ported 3 angle valve job oh1coupe Mustang Parts for Sale and Wanted 0 09-29-2004 12:51 PM
99+ guys who want projector headlights with angel eye halo's cuban3jumper The Bar 2 07-24-2004 10:14 AM
CHROME TIPS..>Brand NEW!....2.5" diameter, Angle Cut..PICS!! Autobadges.com Mustang Parts for Sale and Wanted 5 05-02-2004 11:48 AM
My Cd Player.... at a new angle :lol: Brent Mustang Audio & Video 15 09-22-2003 09:20 PM
03:06 PM
