Subs - Mustang Evolution
Old 06-03-2007, 05:13 PM   #1
Subs
Hey guys i just went in my car and my subs dont work do u think they can be overheated from being outside in 90 plus degree weather in a black on black car in cali.
jaredp is offline   Reply With Quote
Old 06-03-2007, 09:21 PM   #2
Re: Subs
No...I promise mine have been through more in the Mississippi Heat in my trunk.
Check your fuse and your ground.
Old 06-03-2007, 09:31 PM   #3
Re: Subs
What lights if any are on your amp? The subs won't overheat. The amp will.
Old 06-03-2007, 10:07 PM   #4
Y2E0L0L5OGWT's Avatar
Re: Subs
What kind of amp/subs?
Old 06-04-2007, 12:14 AM   #5
Re: Subs
Sony Xplod amp and Rockford Punch P2 subs ya i know its my amp im gonna get it checked out tomorrow or maybe get a new amp wat do u guys know about the infinity amp my friend has one and it lights up and sounded good on his 1 p2 i have 2 12 in p2's though
Old 06-04-2007, 12:36 AM   #6
Re: Subs
I saw the title "Subs" and his user name was "jaredp' and was thinking that this was going to be something about Subway.
JROC is offline   Reply With Quote
Old 06-04-2007, 12:38 AM   #7
Re: Subs
Infinity makes much better amps than Sony. Always want to make sure the amp is matched up correctly to the subs though.
Old 06-04-2007, 07:43 AM   #8
Re: Subs
basically, the problem is that the sony xplod amp isn't enough to power the 2 rockford sub's...even though power-wise it probably should be, the xplod amps (1) are highly over-rated power wise (2) are very inefficient compared to some of the other brands. I used to have an xplod 2 channel 1200W amp powering two 10" Alpine subs, and it worked just fine for about 6 months through all power ranges. Then all of a sudden one day, the amp start going into it's stupid safe mode. Eventually, I figured out that the amp would work just fine at lower power and mid power ranges, but the second I cranked the bass up to full power, it would short out and go into safe mode. Basically, the amp essentially wore itself out, in a rather short period of time, and wasn't enough to power the subs at full power. Try running your setup at lower power for now to see if you can at least get it to stay running for a while. I changed to a Kenwood mono block 1000W amp and I have never had a problem again...so my suggestion would be not to buy another Xplod as they don't last hope this helps...
Old 06-04-2007, 11:34 AM   #9
Re: Subs
MTX ftw.
Old 06-04-2007, 06:16 PM   #10
Re: Subs
Ya i had a 800 watt kenwood amp from my cousin he said it might work and they installed it then it didnt work it powered but they said something inside was wrong so i had to get a new one and i got this one for 60 dollars so i thought it was worth it but wat is the best amp i can get for about 300 dollars? and ya i have 2 12in. Rockford Punch P2 subs and a alpine headunit.
Old 06-05-2007, 03:21 AM   #11
Re: Subs
ok here check this place out CarStereo.com - Car Stereo is the #1 Car Audio Online Resource I am on there all the time and have learnt a lot from this site. I cant tell you price wise cuz I am in canada but MTX, Clarion, Kenwood, even alpine ALL make good amps
Stupid speed limits!!! :( Stupid tickets!!!! :mad: PANTERA, PEDAL TO THE METAL AND DRIVE IT LIKE YOU STOLE IT!!!!
BNUTS
Bnuts is offline   Reply With Quote
Old 06-05-2007, 04:09 AM   #12
Kiljosh's Avatar
Re: Subs
This is exactly what happened to me with my 2ch 600w Xplod amp. It would work fine with about half power going to it but when I cranked it it cut out.
I got a full 4 years out of it powering one sub around 250rms then one day it just stopped playing.
Old 06-05-2007, 04:14 AM   #13
Re: Subs
I have had nothing but good from Planet Audio amps. If you got a local shop near you that carries them you may want to check them out.
Old 06-05-2007, 12:22 PM   #14
Kiljosh's Avatar
Re: Subs
I just got a Power Acoustic 1600w and I can tell you the quality and performance kills the sony I had.
Old 06-05-2007, 06:04 PM   #15
Re: Subs
Never heard of Power ACoustic how mcuh is that amp
Old 06-05-2007, 07:18 PM   #16
Kiljosh's Avatar
Re: Subs
I traded for it but I would guesstimate in the 200 to 400 range.
Old 06-05-2007, 10:03 PM   #17
Re: Subs
Aight Thx
Subs jaredp Mustang Audio & Video 2 05-01-2007 05:32 PM
subs mustang0386 Mustang Audio & Video 5 08-27-2006 11:56 AM
what subs? plstktnkr2 Mustang Audio & Video 6 08-24-2006 10:51 PM
subs coolstang Mustang Audio & Video 1 06-14-2005 11:10 AM
Subs 19ClearCobra96 Mustang Audio & Video 5 12-17-2004 12:52 AM
12:58 AM
