Do I need to upgrade my alternator? - Mustang Evolution
Old 10-23-2010, 02:47 PM   #1
I have a 01 v6 mustang, currently there is one 400rms amp, one 12" sub and a 3 farad cap. My current voltage when the car is running is bewteen 14.3 and 14.8. I recently have gotten a zx1500 watt rms kicker amp, two l5 solo barics, a blue top optima and 16' of 0 gauge wire.. By my calculations the 1500w amp will be pulling from 100a-150a, my alternator can put out between 95a-105a. This seems unsustainable and will cause problems correct? Do I need to upgrade my alternator before I install the new system? Here is my wiring diagram.
Here is my the wiring on my 400w amp 12" sub. I plan on putting the second battery by the cap, removing that 12" and sony amp, then running a 0guage power wire from the second battery to cap then to the 1500w amp that will be mounted on a box that sits on my back seat. I need feedback and advice.
Main battery
Second battery for trunk
This is how im mounting my amp, the fuse will be moved though.
Justus is offline   Reply With Quote
Old 10-23-2010, 09:34 PM   #2
Re: Do I need to upgrade my alternator?
Your alternator should be fine because your amp will not draw that much amps continuously I have a kenwood 1000w/rms mono amp and it does fine with the stock size battery but you might want to upgrade your capicitor if you can "the bigger the better". Your stock alt should be 130 amp if you have air because mine is.
Straublittleman is offline   Reply With Quote
Old 12-21-2010, 12:56 PM   #3
What you need is a capacitor to store an energy charge so when the bass hits your lights don't dim. An extra battery wouldn't hurt as long as it was wired in parallel. It would store extra energy as well and vastly improve cold starting in winter
Old 12-25-2010, 07:13 PM   #4
Gster's Avatar
Main battery
As long as you haven't put on new pulleys you should be fine.
Gster is offline   Reply With Quote
alternator 968 1996-2004 Mustang GT 6 06-24-2009 08:47 PM
alternator help immenukka Pre-2005 V6 Mustang 1 06-09-2007 02:25 PM
Brand New Alternator for 5.0 v6stanger Mustang Parts for Sale and Wanted 0 09-22-2004 11:51 PM
Alternator Whine Kessler Mustang Audio & Video 4 01-22-2004 09:44 PM
96 GT alternator Rellik Pre-2005 V6 Mustang 8 11-19-2003 12:12 PM
02:23 AM
