Sequential Taillights Mod - Mustang Evolution
Old 11-01-2010, 10:48 PM   #1
Cool Sequential Taillights Mod
94-04 Mustang sequential tailights discussion:
Deciding to change you turn signals to a sequential set up leaves you with many options today. I have a '97 and when I first installed the splice kit, it appeared to actually look like a "trailing" flash because the blinkers were so fast. I tried to make things better by purchasing the plug n play harness kit. Because the relay flashed so quickly, it still gave the effect of trailing (one light lit, #2, and then#3) when true sequential would have the first lamp light up and stay lit as the second lights up and then the third with all three lit at once before sequencing again.
I solved the problem by finding a turn signal relay that slowed down the flash rate about 50% giving it the look of the newer Mustangs sequential display. Now looks fantastic. It works with both a splice kit or the harness kit you can get.
Lastly, now they sell LED sequential kits that function at the correct rate while you change out your 3157 lamps with the LED lamps provided.
One last thing I should mention is that I have found that if you install 3157 lamps with thick filaments, you get a brighter and longer illumination.(Silverstar)OR(NightHawk) or on a lesser note any "long life" lamp.
HOPE ALL THIS HELPS AND IS INTERESTING!~Any Questions & I'll Try & Help.
Old 11-01-2010, 11:18 PM   #2
Re: Sequential Taillights Mod
Thank for the tip I will definitely use your advise in the future.
Straublittleman is offline   Reply With Quote
Old 11-02-2010, 08:52 AM   #3
yea different kits work differently as well they dont all flash at the same speed
Old 11-02-2010, 01:27 PM   #4
Where did you find the relay?
Old 11-03-2010, 12:40 AM   #5
I got the relay from autotrix.net and it works great. Something so little really made my day because the flash rate on the newer Mustangs were slower and more pronounced. Like I said, it now flashes slow and in sequence w/the first light bulb staying lit while 2nd and 3rd light up. autotrix has a forum and everything. When I e-mailed them with questions, the owner responded within minutes.
The cost was $25.00 i believe. I am glad I found it. It also functions with LED bulbs-no resisters needed.
I am now looking for a new/used multifunction switch (turnsignal lever) to buy if anyone has one laying around.
Old 11-03-2010, 03:23 AM   #6
sonic04edge's Avatar
Send a message via AIM to sonic04edge
Try and get a video if you can!
Looking for a mustang
2001 Ford Explorer 4x4
2003 Ford F150 Lariat Screw
1998 Ford Ranger-The DD
sonic04edge is offline   Reply With Quote
Old 11-03-2010, 09:16 AM   #7
Yes...a video would be great as this is something I'm thinking to add to my Mustang and would love to see what this looks like.
Thanks
FDIII
Frank3 is offline   Reply With Quote
Old 11-03-2010, 10:52 AM   #8
I changed out the relays on both our cars years ago...slower is better.
Old 11-03-2010, 10:58 AM   #9
I bought my kit from your guy and haven't seen the need to swap out the relay yet. But, I did buy the "slow" flash kit...so maybe that's why.
Old 11-03-2010, 11:42 AM   #10
I will try and get a video posted. I have never used the video portion of the new camera except for by accident and posting a video will be a first- but I'll try.
Old 11-03-2010, 12:03 PM   #11
Thanks!
FDIII
Old 11-03-2010, 04:56 PM   #12
I don't know that much about the new kits. He only had one kit available back when I did these.
I did install a set in a friend's 97 GT and we ended up changing his flasher as well because they were too fast. It might be a SN95 thing over new edge even with the new kits.
Old 11-03-2010, 04:59 PM   #13
I need the relay. Mine are way to fast.
Old 11-03-2010, 05:55 PM   #14
autotrix.net- $24.00
Thats where I got mine. They shipped same day, got it 2 days later.
Old 11-03-2010, 06:33 PM   #15
Heres a vid of mine. It is just the plug and play kit. I like it, but I think I might want to slow it down.
Old 11-03-2010, 10:50 PM   #16
Yes, the relay slows that down by 50% That is the same speed my kit used to flash.
It's raining tonight so I'll post a video in between clouds ASAP
Old 11-04-2010, 03:39 PM   #17
Sequential harness with sequential relay. Not the best video, view-wise but it stopped raining for 10 minutes. Here~ It will not download the video??..I will keep trying- I made 2 videos. Tried downloading 10 different ways. Will try again later.
Sequential Taillights jmeigs Mustang Audio & Video 14 10-20-2009 08:32 PM
You've Seen Others, Now Here's Mine: Sequential Taillights OsirisGuy Pictures and Videos 10 07-01-2007 11:49 AM
Sequential guys.... 01mineralgrey6 Mustang Parts for Sale and Wanted 6 06-18-2006 08:57 PM
Sequential Taillights video WhiteStang99 Pictures and Videos 9 01-19-2005 10:07 PM
Sequential taillights - Where and How much PureVenom The Bar 9 10-19-2004 06:20 PM
07:16 AM
