need help installing aftermarket stereo - Mustang Evolution
Old 01-21-2011, 08:17 PM   #1
Region: Montana
ok so i have a 2000 ford mustang v6 convertable i just bought an aftermarket cd player and was trying to install it i took out the radio and cd player units and wired an adapter i got from walmart up and plugged it in the problem is when i hook everything up my new cd player doesn't get any power or anything.
CJP59868 is offline   Reply With Quote
Old 01-21-2011, 11:21 PM   #2
Re: need help installing aftermarket stereo
Have you checked the fuses?
19Delta is offline   Reply With Quote
Old 01-22-2011, 09:20 AM   #3
stampde's Avatar
yup, check fuses ,and double check the wiring to the adapter
2011 GT Auto
Old 01-22-2011, 10:19 AM   #4
06mustangmike's Avatar
adapter may be wrong one,check and make sure . also make sure all terminations are connected firmly.
06mustangmike is offline   Reply With Quote
Old 01-22-2011, 07:30 PM   #5
OsirisGuy's Avatar
Did the OEM radio work before you took it out? Is that the reason you replaced it? If so then it's probably a fuse.
Are you sure you wired the harness correctly? What did you use for your connections? If you've never done wiring before I'd also check the connections as they could have come undone.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 02-28-2011, 11:48 AM   #6
Sonofjarell's Avatar
When hooking up aftermarket radios u should go to crutchfield for wiring harness made just for ford mustang super easy install
Sonofjarell is offline   Reply With Quote
Old 02-28-2011, 03:22 PM   #7
i second that, i did and was very happy
2010+ aftermarket stereo dash panel white sally Mustang Audio & Video 2 11-22-2010 12:47 PM
Need Help Installing New Aftermarket Head Unit and Subs with Amp! 99supercharged Mustang Audio & Video 8 04-15-2010 11:57 PM
Aftermarket Stereo IHTECH Pre-2005 V6 Mustang 2 07-10-2008 10:18 PM
Installing an aftermarket deck? mvp828 Pre-2005 V6 Mustang 5 06-16-2008 02:14 PM
dash lights out after installing aftermarket radio vblic 1996-2004 Mustang GT 3 08-10-2007 06:46 PM
03:33 AM
