Installing subs in 2011? - Mustang Evolution
Old 03-18-2011, 01:55 PM   #1
2011Rushracing's Avatar
I'm attempting to install 2 subs in my 2011 and I'm trying to figure out if it's possible to do this while still keeping the stock radio in. Any help would be great.
2011Rushracing is offline   Reply With Quote
Old 03-18-2011, 07:45 PM   #2
06mustangmike's Avatar
Re: Installing subs in 2011?
if it's a shaker 1,000 you already have subs i believe there in the doors.if you get subs that are seperate you will need an amp then tie into stereo,and power from batt.the stereo they come with are pretty good tho.good luck i recomend crutchfield if you go with after market subs!
06mustangmike is offline   Reply With Quote
Old 03-18-2011, 08:30 PM   #3
It's only the shaker 500 system. The subs are separate, 2 12" Memphis. My question was if the amp I purchased is able to be installed to the stock radio.
If I didn't already have the subs, I'd definitely look at the crutchfield ones. I'll keep them in mind for the future.
Old 03-18-2011, 08:37 PM   #4
that's what i had in my 06 and there are subs in door.i diconected mine and i put an alpine amp and dual subs in trunk'.i believe you can tie the new amp in to be cotrolled by the stock deck.good luck
Old 03-18-2011, 08:49 PM   #5
I'm wanting to keep my door speakers in. Lol
That's what I'm wanting to do with mine, putting them in the truck with my kicker amp.
Hopefully it is compatible since I have the touch screen electronics package. Haha
Thank you.
Old 03-27-2011, 08:38 AM   #6
gixxer007's Avatar
Man I wish I was up on all the radio system stuff, I want to put a system in my car also and have no clue what to do. Looks like I would have to take it to a place to get done.
gixxer007 is offline   Reply With Quote
Old 03-27-2011, 09:43 AM   #7
There is a write up someone did to do this on a 2011, I can't remember the link but if I find it I'll post it for you.... I think what you need in order to keep your stock radio is a MTX reQ. It will allow you to tap into your rear deck speakers and the reQ unit adjusts the subs so they only play lower frequencies and it helps with volume.. My suggestion if you can't find the link is to call Crutchfield and ask if the reQ is what you need, or call a local audio shop, you can still use your memphis subs but Crutchfield should talk you through everything especially if you buy your reQ from them. There may be similar/cheaper units than the reQ but I know thats what the guy used for the write up. Best of luck though, and let us know how it turns out!
Robaire is offline   Reply With Quote
Old 03-27-2011, 09:46 AM   #8
i would look at crutchfield cat. and look through there stuff.they have a very good tech. dept.that will help you also.i'm partial to alpine myself.good luck
2011 mustang or 2011 challenger srt8 The Darkside 2011-2014 Mustang GT 55 12-16-2010 07:01 PM
Need Help Installing New Aftermarket Head Unit and Subs with Amp! 99supercharged Mustang Audio & Video 8 04-15-2010 10:57 PM
Subs jaredp Mustang Audio & Video 16 06-05-2007 10:03 PM
08:32 AM
