Alternator whine - Mustang Evolution
Old 04-27-2011, 10:06 AM   #1
Snapple750's Avatar
Alternator whine
How do you eliminate alternator whine?
2 Legit 2 Quit
Snapple750 is offline   Reply With Quote
Old 04-27-2011, 10:33 AM   #2
Titus Wadicus
svtlx's Avatar
Re: Alternator whine
buy buying a new alternator...lol. unless u have something putting a heavy load on it, like a bad starter, bad electric fan, bad battery.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-27-2011, 10:34 AM   #3
Las0mbra's Avatar
In the speakers? Have you installed amps to your system?
Old 04-27-2011, 06:59 PM   #4
Snapple750's Avatar
I have dual 10 inch Rockford fosgates an a 600 watt rockford amp. The subs whine, and I'm pretty sure that it's alternator whine
2 Legit 2 Quit
Old 04-27-2011, 08:10 PM   #5
Las0mbra's Avatar
Check your grounds and make sure your signal cables aren't next to any electrical wires, and if they have to cross, make sure they cross perpendicular.(90 degree angle) those are normally the causes of alternator wine with subs.
Old 04-27-2011, 08:39 PM   #6
Snapple750's Avatar
If they cross and they are both protected wires, could the whine still be present?
2 Legit 2 Quit
Old 04-27-2011, 08:44 PM   #7
Las0mbra's Avatar
At 90 degrees, it should be mostly okay... Oh, and if your power is running down the same side if the car, switch it to the other side. Protected wires really don't do much though...
Old 04-27-2011, 08:46 PM   #8
Snapple750's Avatar
I see, I'll look into it, thanks for the help
2 Legit 2 Quit
Old 04-27-2011, 08:47 PM   #9
Las0mbra's Avatar
You're welcome man, and if you have any more questions, just pm me. I just installed a sub in my car and I did a ton of research about that kind of stuff.
Old 04-27-2011, 09:10 PM   #10
Knight F Mohawk's Avatar
Send a message via AIM to Knight F Mohawk
As stated, check your grounds, ensure proper protection/insulation on your wiring, and make sure it's not running too close to the power wires.
-Will
Knight F Mohawk is offline   Reply With Quote
Old 04-27-2011, 09:27 PM   #11
Probably ran the rca and power wires next to each other, or at least on the same side of the car.
Old 04-28-2011, 08:18 PM   #12
Snapple750's Avatar
It is very inconsistent I might add
2 Legit 2 Quit
Old 05-14-2011, 08:24 PM   #13
Cinn's Avatar
Region: Arkansas
I rewired my entire sound system 4 times last week. First time my subs also whined with the alternator very bad. Even after I added a second amp for the aftermarket inside speakers the subs still whined even though the others didn't. The amp to the subs went out and I ran the subs off the second amp and the whining started in my front speakers then which was worse. But after I got a replacement amp and put the subs on the new one then suddenly I have no whine at all it is weird. I also don't have the instant thump or sound check when I start my car either.
I am taking a shot in the dark that is lies either with your gauge wiring you have running to the back. How well your ground is. How old your amp is and what wattage it is pulling compared to the gauge amp kit you used. Mine wasn't random though it was always on when my car was on then after I drove it a little while it would fade away or I mentally blocked it lol. Check the simple things first.
Cinn is offline   Reply With Quote
Old 06-28-2011, 05:19 PM   #14
TaylorF25's Avatar
Just make sure that you ran your power cable on one side of the car and your rca's and remote wire on the opposite side
TaylorF25 is offline   Reply With Quote
Old 06-28-2011, 05:47 PM   #15
Send a message via Skype™ to Texastboneking
RCA noise filters got rid of mine. Sold on eBay for 15 bucks
Texastboneking is offline   Reply With Quote
DIFF GEAR WHINE classman Pre-2005 V6 Mustang 10 01-11-2011 12:26 PM
cheese with my whine andi Pre-2005 V6 Mustang 2 05-21-2009 11:00 AM
engine whine? tedness Pre-2005 V6 Mustang 34 05-02-2005 09:28 PM
Alternator Whine Kessler Mustang Audio & Video 4 01-22-2004 08:44 PM
Engine whine DropTop_Stang Pre-2005 V6 Mustang 33 12-29-2003 02:22 AM
04:17 AM
