smoke - Mustang Evolution
Old 07-07-2011, 11:02 AM   #1
kickerofdoom's Avatar
smoke
I think the amp and sub don't match amp is 380 Rms and sub is 250 rms
Old 07-07-2011, 12:47 PM   #2
Las0mbra's Avatar
Is the sub smoking? If so, you're cooking the voice coil... Turn down the gain and you should be fine for a while
Old 07-07-2011, 01:13 PM   #3
The ratings on the sub only depicts what it requires to work at maximum capacity and the amps ratings are not 100% correct a 2000 watt amp can sometimes only push 1500.
And subs are only truly made for pass they add a voice coil so you can use it if necessary so is there is smoke that's why. Put your amp to lws so only bass comes out of it.
16218 is offline   Reply With Quote
12:15 AM
