Do i need to put resistor if i am going to replace my parking lights to LED? - Mustang Evolution
Old 10-05-2011, 09:24 PM   #1
Siendly22's Avatar
Siendly22 is offline   Reply With Quote
Old 10-05-2011, 10:59 PM   #2
ColeJohnson's Avatar
Re: Do i need to put resistor if i am going to replace my parking lights to LED?
I would think so. I have LED parking lights and they blink very fast as if a light is out.
2016 Comp Orange GT (current)
Old 10-05-2011, 11:07 PM   #3
Siendly22's Avatar
Really? So if I put resistor, it'll be not blinking so fast right? Thanks
Old 10-06-2011, 01:13 AM   #4
I would figure that the way to system works is that it doesn't have a certain amount of resistance from the bulb, then it will blink fast, notifying the driver a light is out. LED bulbs don't put up the same resistance as OEM style ones, so the system doesn't recognize a bulb being there, even though it lights up like normal. I would figure if you put a resistor on it would clear up that issue. I just am not that bothered by it. Lol
Old 10-06-2011, 04:24 AM   #5
OmegaRedGT 2007's Avatar
its not blinking fast because of the resistor..a resistor only restricts voltage to the LED from the main power source so they dont blow.
Example: 1 2.2volt LED needs a resistor in order to handle 12volts from your car.the more LEDs you add the more resistance you'll need.
---------- Post added at 05:24 AM ---------- Previous post was at 05:21 AM ----------
If you just connect an LED straight to 12volts it will blow.if you connect alot to 12volts the will be dim.
OmegaRedGT 2007 is offline   Reply With Quote
Old 10-06-2011, 11:07 PM   #6
Siendly22's Avatar
How about back up lights, do I still need resistor ?
Old 10-07-2011, 04:43 AM   #7
Anytime you use an LED on 12volts you need a restr, useless you bought the light setup the restr should be preinstalled.
Old 10-08-2011, 12:00 AM   #8
Timm04's Avatar
You don't need resistors for the back up lights I put led bulbs in mine and they work fine! And they look sweet! There not as bright but I don't go places where's there's no lights when I back up so I don't need blinding reverse lights they just add a nice touch but no you don't need resistors
Timm04 is offline   Reply With Quote
Old 10-08-2011, 04:44 AM   #9
A bulb is different than an LED.rstrs are preinstalled on bulbs to handle the extra current.on a plain LED you must install a rstr.or it will burnout. I attached pics of the LEDs i am referring to, if you are using a manufactrd replacemnt BULB..maybe thats how it functions.
Old 10-09-2011, 07:13 PM   #10
Siendly22's Avatar
I put xenon led on my back up lights today, it was a nice addition and it's bright tho.
Old 10-09-2011, 09:06 PM   #11
Timm04's Avatar
Pics please???
Old 10-09-2011, 09:47 PM   #12
Siendly22's Avatar
Yea, will post it tomorrow. Great addition man I'm telling you.
08:06 PM
