2 15" kickers in the trunk? - Mustang Evolution
Old 12-08-2011, 06:51 PM   #1
Will 2 15" kickers fit in the back of a 2006 v6 convertible mustang?
Thanks
Mauldin22 is offline   Reply With Quote
Old 12-08-2011, 08:17 PM   #2
gonzalez0041's Avatar
Maybe but you would have to have a custom box built and its gona be tough. I have two 12" l7s in mine in a sealed box
gonzalez0041 is offline   Reply With Quote
Old 12-08-2011, 08:26 PM   #3
I really would love to have the 15's
Old 12-08-2011, 08:36 PM   #4
Its possible you will lose all trunk space and if you are handy you can make the box yourself if not im sure there is a shop around that will build it for you but it wont be cheap
Old 12-08-2011, 08:54 PM   #5
Hmm well I really don't care too much about the trunk space. Also how do y'all think the 15's will sound with it being a convertible and all?
Old 12-08-2011, 08:55 PM   #6
I havent heard subs in a convert. I have no clue sorry
Old 12-09-2011, 06:51 AM   #7
Has anyone?
Old 12-09-2011, 09:46 AM   #8
BigB227's Avatar
I have 2 12's in my convertible 03 they soud great but when you put the top down you lose alot of the bass lol but you can still feel it, putting them in was a PITA!!!!!
BigB227 is offline   Reply With Quote
Old 12-16-2011, 06:33 AM   #9
V6_roller's Avatar
Region: Arkansas
Thanks
I've got two 15 and two twelves 4 5x7 4 2 inch tweeters 2 6x9 and 4 12 in mine bt no back seat
V6_roller is offline   Reply With Quote
Old 12-22-2011, 12:49 PM   #10
Horseplay's Avatar
wow your a man of your music bro lol. take a pic of your setup. i want some jamz in mine but idk what to put.
Low2v
Old 12-23-2011, 01:23 AM   #11
Justasix98's Avatar
Thanks
2 15"s? Especially with it being a Vert it's going to be hard to keep your bass. I have 2 12" Kicker Comps, sealed dual chambered box, Kicker ZX 750/1 mono amp, all 2 gauge wiring, and I've hit 132.2 decibels which is pretty loud, while still holding a strong 13.4 volts. It all depends what you want in your system and what you listen too. If you want that long carrying bass, go with a ported box, but if you like that solid punch bass, but also that nice deep bass go sealed. For 2 15's, a lot comes into play when it's a Mustang. We don't have much airspace, and for subs that big (depending on what kind you get) a lot of specs come in too. Each sub is going to have a recommended cu ft of air in the box. As we all know mustangs do not have much trunk space as it is. Your probably going to have to get a custom box built (unless you can build it yourself) which is going to run you a few hundred dollars. Then power. I'd recommend getting a high output alternator (around 150-160amp). Factory most Mustangs have 130amp alternators, and those 15's are going to be pulling plenty of power. Also you have to remember, all bass is is moving air. More you move, louder it gets. And the further it travels, the smoother it'll get. For instance, if you have your subs in your trunk, with them aimed at the back seat, the air doesn't have to travel too far, making them sound decent but you'll be able to hear a lot of distortion from the subs themselves. Aim your subs at the trunk door, and the air travels further, making them sound quite a bit better, and less distorted. Getting two 15"s to fit in a Mustang is a hell of a job alone. I'm not doubting you, I'm just saying its going to be expensive as hell and time consuming. I'd recommend you tone it down just a notch, like 2-3 12"s, maybe a few 10"s. Like I said its all what you prefer, but you can still get great quality sound from smaller subs. I hope this info has helped ya out a bit.
Just A Sixxer!
Proud member of WickedStangs Okc Chapter!
Justasix98 is offline   Reply With Quote
Old 12-23-2011, 09:04 AM   #12
V6_roller's Avatar
Region: Arkansas
When I get it back from my audio guy I post sum pics I'm gitting it upgraded with two extra 12a and a bigger alternator
Old 12-23-2011, 09:16 AM   #13
Horseplay's Avatar
badass! any ideas on how i can set up mine ?
Low2v
Old 12-23-2011, 09:19 AM   #14
V6_roller's Avatar
Region: Arkansas
What u wanting outa it
Old 12-23-2011, 11:02 AM   #15
Horseplay's Avatar
i dont want something huge u know. a simple setup with a decent bang
Low2v
Old 12-23-2011, 11:28 AM   #16
V6_roller's Avatar
Region: Arkansas
The fusion set ups are super easy fairly cheap and got pritty gd sound
Old 12-29-2011, 11:16 AM   #17
ColeJohnson's Avatar
Re: 2 15" kickers in the trunk?
Thanks
Honestly you can make anything fit wherever you want with enough effort and skill. The question should be: With the space I have, will 2 15"s be the best sound and use of space?
Answer is simply a big resounding no. You'll have terrible time getting even close to the correct volume, and 2 15"s would just suck, honestly. Idea sounds cool, but I could probably get one 10" to hit just as hard as 2 15"s in the same trunk space for a lot less money and still have 75% of the trunk available to use.
My Alpine type R 10" gets complaints from houses down the street when i only have it running at half volume... Lol.
But if you just HAVE to use 2 '15s.. you can fit them. It won't be cheap and it won't sound as good as it could, but it can be done.
Edit: I just remembered that I used to have 2 12" kickers before I switched to a single Alpine Type R 10", and I can say, without a doubt, the 10" is probably 2x louder. It all depends on your wiring and amp/sub/box setup.
2016 Comp Orange GT (current)
Old 12-29-2011, 11:33 AM   #18
Horseplay's Avatar
do u got a pic of ur alpine bro?
Low2v
Old 12-29-2011, 11:57 AM   #19
Uploaded some pics of the trunk with the sub and amp in the backdrop. Also uploaded a pic of the fuse in the engine compartment and a pic of my head unit.
JL Audio 500RMS amp - $200ish
Alpine Type R 10" - $175ish
Carpeted and ported Box- $50
4gauge Wiring kit- $55
Pioneer AVH3300BT Head Unit- $485
Sub wiring install was $70, I installed the head unit myself so no charge there.
Total was roughly $1000 after tax. You could do it for cheaper if you'd like, but I bought what I wanted after advice from many people and from many different sound shops. So like I said.. You can do whatever you like and you should. Don't let any one person's opinion sway you from your aspirations, but if a lot of people say the same thing.. You might wanna think on it. I originally wanted to run a single 15" in the trunk ported and the sound shopS(yes, plural) said it would sound bad because you can't get proper air space in trunks like my '02 mustang.
ID:	36834   Click image for larger version
ID:	36836   Click image for larger version
Old 12-29-2011, 01:48 PM   #20
Horseplay's Avatar
NICE +1
i needa get me one of those systems
Low2v
Old 12-29-2011, 03:25 PM   #21
Justasix98's Avatar
@ Cole
That's a pretty good setup, looks like a good install, and that's a really nice dd
I'll post up some pics on mine, proudly installed all myself
And feedback is always good news!
I only have about $800 tied into my system, had it tested and it ran 132.2 decibels
ID:	36843   Click image for larger version
Just A Sixxer!
Old 12-29-2011, 09:43 PM   #22
Originally Posted by Justasix98
@ Cole
I appreciate it. It is really good for my taste in music. I do urge people to get a lot of different opinions. I must've hypothetically setup twenty systems and ran it by sound shops to get their inputs before going with this. Take your time, as with everything.
Old 12-29-2011, 09:55 PM   #23
Las0mbra's Avatar
Now I want to show off my setup ha...
Alpine MRX-m50 500rms amp/tested at 580rms-$175
Alpine CDE-122 HU - $160
Alpine type-R 12" (btw... For the price, alpine type r's hit freakin hard...)-$125 on amazon
Sealed box-$30 carpeted
Alpine KTP-445 45rms x 4 compact amp (look it up) in the mail-$129
Rockford Fosgate R1682 full range speakers-$45 a pair on sale
Total cost is about $710 without all the random extra stuff. All installed by me, and I'm cheap labor
Btw... In the pic I have a Mrp-m500 amp. Stolen by some stupid fuking a$$holes.
ID:	36873   Click image for larger version
ID:	36876   Click image for larger version
ID:	36878   Click image for larger version
Old 12-29-2011, 10:14 PM   #24
I'm getting a 4 channel amp and component speakers whenever the stock speakers blow. Thanks for the info.
Old 12-29-2011, 10:17 PM   #25
Las0mbra's Avatar
You're welcome... Too bad my setup doesn't look very clean... My amp is hidden and locked under my spare, and my sub is held in place with bungee cords. Ha, got broken into and everything got stolen. So, everything is locked and taken inside every night.
Old 12-30-2011, 12:14 AM   #26
Las0mbra's Avatar
Hey, since we're talking about audio... How does this idea sound? I'm thinking about adding another set of speakers to my mustang... I was thinking about instead of the normal kick panel mounting space, what about cutting out a spot in the back seat are about the arm rest? I would put some Rockford Fosgate 5.25" in I think... Btw, I mean the top left area of the plastic in this pic. Good idea or stupid?
Old 12-30-2011, 12:26 AM   #27
I guess the only problem you would run into is the wiring. Otherwise, if you can find the proper mounting bracket, I think it's a pretty awesome idea. May look cool as well! I just hope the area is deep enough for speakers.
I would try to research it a bit and maybe figure out the dimensions to see if it works before cutting or buying anything.
Old 12-30-2011, 12:38 AM   #28
Las0mbra's Avatar
I've removed the panels before and it's a solid 3-3.5" of depth which is plenty. And I would run them with my rear speakers power together. 45watts rms should be fine for both.
---------- Post added at 01:37 AM ---------- Previous post was at 01:33 AM ----------
Oh, and here are the speakers I have in mind..http://www.sonicelectronix.com/viewi...836&show_tab=2
---------- Post added at 01:38 AM ---------- Previous post was at 01:37 AM ----------
Also, I could spraypaint the grill to match the grey I have in back
Old 12-30-2011, 05:49 AM   #29
Justasix98's Avatar
Never a stupid idea lol, the wiring itself would be easy, as Cole said the only thing I would be worried about is mounting depth. Personally I would get a rubber grommet for the outside where the speaker will set, and circular piece of wood on the inside of the plastic (to screw the speaker into). It'll hold it securely for a long time, with no worries about flexing the plastic and re-tightening screws.
Just A Sixxer!
Old 12-30-2011, 08:41 AM   #30
Las0mbra's Avatar
Hmm. Dang. Now I have to decide if it would be worth it to cut the plastic...
Old 12-30-2011, 05:23 PM   #31
Justasix98's Avatar
Just a chance you gotta take
Just A Sixxer!
trunk badge???? bigsmitty24 2011-2014 Mustang GT 41 12-07-2011 12:34 PM
Trunk clunk from bumps Macluva18 Pre-2005 V6 Mustang 10 11-20-2011 10:11 AM
trunk light help RVAStang05 2005-2010 Mustang GT 1 11-03-2011 01:00 PM
Trunk release on 07 GT uh60facilitator General Mustang Discussion 5 08-17-2011 11:56 AM
Trunk bulb MVP u eNVy ME 2005-2010 Mustang GT 2 08-09-2011 07:37 AM
06:20 PM
