HELP!!!! new stereo installation for 2000 mustang - Mustang Evolution
Old 12-17-2011, 12:58 AM   #1
Region: Iowa
I am installing my JVC stereo.
I got a few problems. Hope someone here could helps me.
1. how to remove the small thing see the following pic
2. I got only 4 pin wired.
Ground (black), ignition, illumination, and battery. is this correct?
3. I found 2 blocks of black small box. One has 8 wire holes and one has 6 wire holes. I guess the 8-hole one is for sound. right? Do I need the 6-hole small box?
4. for the 8-hole small box, is this deep enough? not sure. seems plenty of room outside of the adapter. And I don't get any sound out from speakers. not sure what's wrong here?
Thank you for your time.
aminohelix is offline   Reply With Quote
Old 12-17-2011, 01:14 AM   #2
Mile high JDF's Avatar
1) it's just a ground I don't exactly remember how I got mine off but it should just pull off. Either that or there should
Be a tab on it that lifts up
2)everything seems correct
3)the 8 pin should be the rear deck speakers and the 6pin should be the door speakers
4)I wanna say it should click into place. For the RCAs do you have white on bottom and red in top (or vice versa) or is it white on one side red on the other?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 12-17-2011, 01:24 AM   #3
Region: Iowa
Re: HELP!!!! new stereo installation for 2000 mustang
Hi JDF, Thank you so much.
for 1. it's really really tight. I am just wondering if the whole black thing come off the white metal? or some back stuck with metal, some other thing come off from the black box??
for 3. I bought the adapter. It only comes with the 8-pin one. In this case I still need 6pin one? The problems is even now the rear deck speaker is still now working. Or I have to get both 8pin and 6pin together then the whole speaker system works? I want to test 8pin if it works. Then I could get another 6pin one.
And also, for 8pin, it comes with 4 aux. inputs. Please see the picture. How do I use those. I only have 4 input on my new stereo. Does the 6pin adapter come with 4 inputs as well?
for 4. I have 2 whites on one side and 2 reds on the other side. how do I use this for my 8pin adapter? does 8pin work itself?
Old 12-17-2011, 01:33 AM   #4
1) it's an amplifier ground. Sadly I dont remember how I got mine off. I believe it involved a lot of tugging and swearing.
3) I have yet to find a 6 pin adaptor. However a guy on here(robertoonizer?? Something like that) drew a diagram as a way to bypass the door amplifiers. I'll attach a picture.
4) put the purple input where the white input is. The purple and green inputs are for the tweeters and the white and gray are for the rear speakers. I may be wrong but red means left side sound and white means right side sound.
Old 12-17-2011, 01:41 AM   #5
Region: Iowa
1) for the new Stereo, do I even need the black amplifier ground??
3) the picture seems a lot extra work with speakers. I might just try the 8 pin first and then see what's going on.
4) I will try your way first. and let you know tomorrow. so much pain right now.
thank you.
Old 12-17-2011, 01:44 AM   #6
thank you.
1) Honestly I don't think so.
3)I haven't done it myself but I need more volume so I'm doing it soon.
4) works for me
And you're very welcome.
Old 12-17-2011, 02:23 PM   #7
Region: Iowa
Hi JDF,
I think my 8-pin amp one is not working!!! it must be broken. there is no sound at all!!!
Old 12-17-2011, 02:39 PM   #8
Hi JDF,
Did it go all the way in and click? I think that's what mine did. Have you tried pulling it out and turning it around?
Old 12-17-2011, 02:45 PM   #9
Region: Iowa
I tried push really hard, i think that is the deepest I can go.
no you can't turn it around because that won't. the power supply wiring adaptor works. Now I am not sure if it's the problem of the wire or the problem of the new JVC radio......
how could I test it??
Old 12-17-2011, 03:26 PM   #10
I guess I should ask, what are you trying to listen to: radio, auxiliary, etc
Old 12-17-2011, 03:32 PM   #11
Region: Iowa
radio?? any different??
Are those four inputs only for auxiliary?? not for radio??
Old 12-17-2011, 03:50 PM   #12
Is your antenna plugged in? And also does your radio have an instruction guide? Also check your fuses, see of any are blown
Old 12-17-2011, 04:43 PM   #13
Region: Iowa
yea. the antenna was plugged in. w/o antenna, I couldn't search frequencies.
There is only one fuse in the radio. it's ok. if its not, the lights or other functions shouldn't work, right?
The instruction guide confused me. basically, on the instruction.
please see the pictures.
Old 12-17-2011, 04:53 PM   #14
Ok swap the green and purple inputs with the gray and white. Gray and white are for the rears I think so let's try that
Old 12-17-2011, 05:07 PM   #15
Region: Iowa
no. it's not working. guess either the amp input adapter broken, or the stereo. . y my life is tough. hehe
Old 12-17-2011, 05:11 PM   #16
Did you check your fuse block? Also did you manage to get that ground off?
Old 12-17-2011, 05:30 PM   #17
Region: Iowa
yea. i get the amp ground off.
The thing is I tested everything on my factory stereo again. It works simultaneously. Every time I plugged in the cable, the sound from the factory stereo came out right away.
thank you JDF
Old 12-17-2011, 05:44 PM   #18
Where did you get the kit from?
Old 12-17-2011, 06:23 PM   #19
Region: Iowa
amazon.
this link.
Amazon.com: Metra 70-5510 Factory Amplifier Integration Harness for Select 1986-2000 Ford Vehicles: Car Electronics
stereo is this link
http://www.amazon.com/gp/product/B00...00_i00_details
I also bought this one:
Amazon.com: Metra 99-5700 Installation Multi-Kit for 1975-2000 Ford/Jeep/Lincoln/Mazda/Mercury Vehicles (Black): Car Electronics
Old 12-17-2011, 06:43 PM   #20
That's definitely the right adaptor kit. Have you tried to see what other wires you could connect? Cause you said you have power, ground, illumination, and one other correct?
Old 12-17-2011, 06:48 PM   #21
Region: Iowa
yea. ignition. other's are amp wires + something called dimmer, dimmer ground, whatnot.
Old 12-17-2011, 06:56 PM   #22
See of there's a hook up for the amp wires
Old 12-17-2011, 07:02 PM   #23
Region: Iowa
what does that mean? but I have amp adapter already, right???
Old 12-18-2011, 12:38 AM   #24
The amp still need power to it. I think that's the power wire
Old 12-18-2011, 12:51 AM   #25
Region: Iowa
hmm. maybe you are right?
but the harness adapter doesn't have wires for amp. Do you remember you did that??not sure what wire to do tho. any clue? but you made good point..
Old 12-18-2011, 01:25 AM   #26
Idk. I'll check mine tomorrow if I find the time
Old 12-18-2011, 01:39 AM   #27
Region: Iowa
Thank you.
btw, where you at?
Old 12-18-2011, 01:52 AM   #28
I'm in Colorado
Old 12-20-2011, 08:08 AM   #29
KATO's Avatar
What's the latest going on with this?
07 GT. SCT: CUSTOM TUNE by "MUSTANG SPECIALTIES". LMR: GEN2 2010 STYLE HEADLIGHTS, RAXIOM: 2010 SMOKED COYOTE TAIL LIGHTS, WHEELS: STAGGERED WHL 22X8.5F-22X10R MORE LISTED INSIDE.
Old 12-20-2011, 11:05 AM   #30
He's managed to get everything connected, however it's still not playing thought the speakers.
Old 12-20-2011, 04:37 PM   #31
Region: Iowa
have you checked your wiring, JDF??
Old 12-20-2011, 10:49 PM   #32
Sadly no. I've been busy with work the past two days.
Old 12-20-2011, 10:50 PM   #33
Region: Iowa
no problem. take your time then. I am on vacation. haha
Old 12-20-2011, 11:00 PM   #34
Nice. I'll try and take a look tomorrow. Unless I pick up another shift.
Old 12-21-2011, 03:01 PM   #35
Alright so I took a look at my wiring diagrams for my stereo and adaptor kit. On the adaptor side there is a blue/white wire that is labeled amp turn-on. On the stereo side (I have a Sony DSX100) it has a wire labeled AMP REM (or amp turn-on) for yours I would assume that your amp+ wire is the amp power/turn-on. Try connecting that with the blue/white from the adaptor kit
2000 mustang
1969 Mustang Coupe Restoration Project yellow99 Classic Mustangs 5 10-15-2011 10:05 AM
1995 Mustang SVT Cobra Project yellow99 1979-1995 Mustang GT 0 09-03-2011 05:51 PM
1971 Mustang Fastback Project yellow99 Classic Mustangs 0 09-03-2011 05:49 PM
11:52 PM
