speaker wiring - Mustang Evolution
Old 01-05-2012, 03:19 PM   #1
insomniac717's Avatar
speaker wiring
Ok so my left speakers are out and I was wondering if I could wire new ones up using the rca ports on the back of my head unit
insomniac717 is offline   Reply With Quote
Old 01-05-2012, 03:22 PM   #2
Old 01-05-2012, 04:33 PM   #3
Mile high JDF's Avatar
That's an aftermarket deck, correct? Are you using the stock speakers or are you putting in aftermarket ones?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 01-05-2012, 04:35 PM   #4
Aftermarket headunit and aftermarket speakers
Old 01-05-2012, 04:42 PM   #5
Your deck should have 2 wires one labeled left front, the other right front. I believe you will have to run a wire all the way o the speakers, unless they have RCAs
Old 01-05-2012, 05:13 PM   #6
So if I plug an rca cable into the right front speaker port and wire it back to a speaker it will work?
Old 01-05-2012, 05:25 PM   #7
93slowstang's Avatar
No, it will not work.
Old 01-05-2012, 10:42 PM   #8
No, if your speakers were designed for RCAs then you woulda have to buy an adaptor kit. I believe your aftermarket speakers run off speaker wire. They should have one, maybe two wires coming off them. You will have to route speaker wire from the door speakers to your stereo deck. The only time you would have to use the RCA inputs is if you keep the Mach 460 (I dont know if yours has it or not) speakers in because those require an adaptor kit. Do you think you could put up a picture of the back of your aftermarket speaker?
Old 01-06-2012, 02:16 PM   #9
But its speaker wires with rca connectors at the one end of them. Why wouldn't it work
Old 01-06-2012, 02:22 PM   #10
I guess that could work. It's just the left speakers correct?
Old 01-06-2012, 02:23 PM   #11
Yep just the left front and back
Old 01-06-2012, 02:26 PM   #12
This is the wire
Old 01-06-2012, 02:28 PM   #13
Yeah that seems like it could work. I've honestly never seen that kind of wire before
Old 01-06-2012, 02:31 PM   #14
Ha me either but I can't figure out why my left side is out so im trying something new
Old 01-06-2012, 02:38 PM   #15
Yeah. Well let me know how it goes
Old 01-16-2012, 06:07 AM   #16
if you wired it like that you wont get almost no sound from it because rca outputs are for amplifires input and are low in volume /voltage, you dont need to run new speaker wires because is already run tru the midrange/tweeters on the corner of your front doors and rear deck, since ford only made the mach460 for bass really and the highs from the headunit, sow all you need to do is bypass the old system in front doors and rear deck by cutting mach system wires and tapping from mid/tweeter wiring , I will post the diagram in a few hours when I get off work , it would only take you like an hour to do
robertoortiz85 is offline   Reply With Quote
small speaker kickerofdoom Mustang Audio & Video 3 11-08-2011 06:50 AM
2000 Mustang fuel gauge wiring Supernaut351W Pre-2005 V6 Mustang 3 10-19-2011 11:14 PM
Wiring harness 01gtstang Mustang Audio & Video 3 10-08-2011 09:08 PM
Speaker setup? Rocco4.6 Mustang Audio & Video 22 09-08-2011 08:17 PM
Asap response speaker Dubya11 Mustang Audio & Video 20 07-23-2011 04:15 PM
12:04 PM
