mach460 by-pass - Mustang Evolution
Old 01-17-2012, 04:04 AM   #1
mach460 by-pass
heres the diagram for iliminating the fatory mach460 system/amps after you installed a aftermarket head unit, because aftermarket harness wont give you a nice even sound then whit the stock unit.
robertoortiz85 is offline   Reply With Quote
Old 01-17-2012, 03:47 PM   #2
99redgt's Avatar
Hey I'm installing a new deck tomorrow along with the f And r speakers should I disable the Mach system ? If so do I have to run new speaker wire?
99redgt is offline   Reply With Quote
Old 01-17-2012, 04:16 PM   #3
no seens there already run tru the mid/tweeters sow whit these bypass you be ready and finish quickly
Old 01-18-2012, 08:50 PM   #4
99redgt's Avatar
Hey do u know what size Speakers That are located I behind my mirror i want to replace them and I'm not sure if a 1" tweeter would be good?
Old 01-18-2012, 10:10 PM   #5
Mile high JDF's Avatar
I did this by-pass just a couple days ago, it worked great!!! Thanks for the diagram
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 01-19-2012, 04:14 PM   #6
the mid-speaker zise is 2 1/2 but are you still using your mach system if sow puting a tweeter it would sound a bit high and no mid's since the mach speakers are trowing only bass on the bottom, try to keep the mid speakers and just add the tweeters on the corner pillars thats how i have them and it sound good.
but if your not using your mach system any more then the tweeters would fit there maybe ifyou get some big tweeters like pionner brand makes some 2 1/2 they would sound nice or any others, just remember to add a capacitor or bass blocker some people call them like that to avoid bass in the tweeter and to not burn then also, most sound shops sell them for like $1 put it in between the positive cable in the tweeter.
Old 01-19-2012, 04:51 PM   #7
try a non-polorize capacitor type 100v 50uf it should over 100watts sow the tweeter wont get bass and not burn
Old 01-19-2012, 04:55 PM   #8
just remember to hook up,the correct polarity (+) ( -) cable there color coded you can check out these wedd page under vehicle wiring and it shows you which color is which in every door, www.12volt.com or audiovoxtech.com
Old 01-20-2012, 02:49 PM   #9
99redgt's Avatar
Can I tie my tweeter into any speaker wire?
Old 01-21-2012, 12:13 PM   #10
yeah rigth and left fronts, wires , are you goint to put them by doors or by windshield, if sow just pass two wires from radio ,
Old 01-21-2012, 06:49 PM   #11
99redgt's Avatar
I was thinking of putting them in the piller or seatbelt that way it's close to my ear
Old 01-21-2012, 07:05 PM   #12
thats cool, just run the two lines from radio and your all set
Ipod hookup for mach460? CrimsonGT Mustang Audio & Video 8 12-31-2011 06:28 PM
First 9sec pass in a NA 2011 5.0 DDTCM At the Track 12 12-11-2011 10:10 PM
The box on the pass side engine compartment Tj88mustang 1979-1995 Mustang GT 16 10-10-2011 09:46 AM
Help with Mach460 Audio joestang406 Mustang Audio & Video 13 07-30-2011 11:15 AM
03:27 PM
