Help! - Mustang Evolution
Old 01-17-2012, 02:57 PM   #1
afree05's Avatar
Help!
just switched my head unit with a aftermarket JVC headunit, and aftermarket speakers, and now whenever the volume is above twenty, the speakers let out a short squeak and then cut out. This usually happens within two-three seconds, but it will just keep doing it, also, the passenger side front speaker doesn't work anymore, any help would be awesome!
afree05 is offline   Reply With Quote
Old 01-17-2012, 05:12 PM   #2
Mile high JDF's Avatar
What's the watt output of your head unit?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 01-17-2012, 08:07 PM   #3
afree05's Avatar
it's 50x4
Old 01-17-2012, 10:22 PM   #4
afree05's Avatar
it's 50x4 I beleive
---------- Post added at 05:22 AM ---------- Previous post was at 05:16 AM ----------
and the speakers are rated at 50 watts RMS and 250 peak
Old 01-18-2012, 02:17 PM   #5
afree05's Avatar
okay. when it's just on the right side, it works fine, except for the front passenger side not working, I think there a problem in the drivers side front speaker
Old 01-18-2012, 03:55 PM   #6
And you aren't running an aftermarket amp, correct?
Old 01-18-2012, 08:23 PM   #7
afree05's Avatar
for the door speakers its in the radio, and I have a small amp with my sub
Old 01-18-2012, 10:09 PM   #8
Have you torn it apart again? Maybe you mixed up some wires
Old 01-19-2012, 08:43 AM   #9
afree05's Avatar
not yet, that's my plan for sunday, it's supposed to be like 65. and it's like 40 today. I THINK It's the rear driver speaker screwing with all of it...
Old 01-19-2012, 08:45 AM   #10
Y2E0L0L5OGWT's Avatar
Re: Help!
Do you have the shaker system? If so, that's your problem...
Old 01-19-2012, 09:38 AM   #11
afree05's Avatar
no, it's just the basic
---------- Post added at 04:38 PM ---------- Previous post was at 04:37 PM ----------
stock system. I wanted subs and an iPod hookup. haha
Old 01-19-2012, 09:44 AM   #12
Re: Help!
Then my guess is either that you have a wire or two backwards or you may created a ground loop problem, depending on where you have the head unity grounded.
Old 01-19-2012, 01:49 PM   #13
afree05's Avatar
well the passenger front speaker doesn't work at all, and I unhooked the rear driver speaker and it works fine now, except I only have two speakers,(front left and back right), but that'll do for now.
Old 01-19-2012, 01:59 PM   #14
2Greeny7's Avatar
Send a message via Skype™ to 2Greeny7
Re: Help!
Check the wiring of your head unit, sounds like the problem is there
2Greeny7 is offline   Reply With Quote
Old 01-20-2012, 12:22 AM   #15
afree05's Avatar
I hope so. I don't know what it would be though, I used a wiring harness and followed the diagram.
Old 01-20-2012, 07:03 AM   #16
2Greeny7's Avatar
Where did you buy it from?
2001 V6
CAI, SF3/X3 Tuner, 4.10 Gears, Auburn lim-slip
GT4 Rims (Summer), Stock Rims (Winter)
2 Subs, New speakers all around
1 Great Car 1 Happy Kid
July '12 Mustang of the Month
Old 01-20-2012, 03:32 PM   #17
afree05's Avatar
the harness?, if so, audio specialists. there about the best audio shop around here.
Old 01-20-2012, 06:14 PM   #18
2Greeny7's Avatar
Hmm, i would have it looked at. But im talking about the head unit, that sounds like the problem to me. If you have a lot of free time take the speakers out and move them around in the car so rear deck into the front and see if the same speakers go out or if its the same spot of the speakers (this will pin point the area of the problem)
2001 V6
Old 01-20-2012, 11:55 PM   #19
afree05's Avatar
I did that, it's the left rear., I'm guessing it's the headunit...
Old 01-21-2012, 08:07 AM   #20
2Greeny7's Avatar
Yeah thats what i was thinking, and buy your head unit off of cruntchfield.com they have AWESOME customer service (like AM) and they will tell you what will fit and give you all of the installation hardware for free. Its a good buy!
2001 V6
Old 01-23-2012, 02:29 AM   #21
afree05's Avatar
thanks!, I'll be sure to look into it.
03:40 PM
