Amp back feed noise through speakers - Mustang Evolution
Old 02-29-2012, 12:52 PM   #1
I've got a 04 Cobra that recently started making this god awful noise through my speakers which sounds like a amp back feed issue. It doesn't like every 3rd time I'm in the car. Not sure if it's bad wiring or the amp going out. It has the Mach sound system. Any ideas or thoughts??
SNK3BTE04 is offline   Reply With Quote
Old 02-29-2012, 10:25 PM   #2
2003SonicBlue's Avatar
Time for a new car.
---------- Post added at 11:25 PM ---------- Previous post was at 11:25 PM ----------
Nah I'm just kidding. Check all of your wiring before you replace something, also check amp gain, ext.
2003SonicBlue is offline   Reply With Quote
Old 03-01-2012, 09:52 PM   #3
dmax8709's Avatar
Do u have a line converter on ur rca? Check maybe ur rca wires r to close to the power wire for the amp kit? Or is everything factory or aftermarket ?
dmax8709 is offline   Reply With Quote
Old 03-02-2012, 06:06 PM   #4
Everything is factory. I haven't looked closely to it as of yet but will. It sounds like its feeding backwards through RCA or something.
Old 03-02-2012, 06:17 PM   #5
dmax8709's Avatar
So everything is factory no system or subs ?When ur alternator starts goin bad u can hear a lil feedback. I've had that happen. Check all ur wires to see if any r cut.
Old 03-02-2012, 09:17 PM   #6
Yeah no subs. All factory Mach 460 components. I'm not sure about the alternator but it's a possiable though. It def sounds like a wiring issue with the amp cause it does it on occasion. When the radio first comes on theres a delay for the amp to kick in which is when the noise comes on.
Old 03-02-2012, 09:27 PM   #7
dmax8709's Avatar
Yea sounds like the factory amps r goin bad unless ya wiring is. But more than likely the amps. Sorry for the bad news.
Old 03-02-2012, 09:29 PM   #8
vinnygt's Avatar
Yeah I'm pretty sure it's your amps. Since it only does it sometimes. If it was a cut wire or something it would do it all the time. But look at the plus side. Now u got a reason to upgrade your sound system on that beast
vinnygt is offline   Reply With Quote
Old 03-02-2012, 09:32 PM   #9
dmax8709's Avatar
Yea only way id be wiring if it only did it when it touched another wire. I upgraded mine. I just ripped all my 460 out. All amps and everything. Replaced it all with Kenwood and Kenwood head unit
Old 03-02-2012, 11:20 PM   #10
I'm guessing a upgrade is the answer I see. The Mach system is pretty good considering the age I it. Thanks for the imput people.
Old 03-02-2012, 11:55 PM   #11
dmax8709's Avatar
No prob. Got any ideas on what u will upgrade to? U can just go to a junkyard and find a mach 460 car and getting the amps out of it
Old 03-03-2012, 10:55 AM   #12
vinnygt's Avatar
That's what I did when my amps when out. I got a Kenwood head Unit too. Love it. And much easier to install then trying to fix my 460 system that would probably end up breaking again lol
Old 03-03-2012, 11:08 AM   #13
No ideas yet but the Kenwood series are always great systems for sure. I may go with a touch screen deck and find replacement amps. The speakers are still hitting good so need to change those ...... Yet.
---------- Post added at 12:08 PM ---------- Previous post was at 12:07 PM ----------
Lol yeah true.
Old 03-06-2012, 09:39 PM   #14
Rot Manik's Avatar
I had the same problem before, it was the coil wire believe it or not! I had to take it to a local stereo shop to find out what the prob. was.. Save the 280.$ I spent and give it a shot
Rot Manik is offline   Reply With Quote
Old 03-07-2012, 12:13 AM   #15
dmax8709's Avatar
And if u dont wanna redo anything go to junkyard and rob one of just the amps. To swap them out will take 15min. And the junkyard shouldn't want much for them
Old 03-13-2012, 12:41 PM   #16
Gonna check that out. Thanks
Old 03-28-2012, 08:49 AM   #17
if everything is stock yeah is your amps, or atlease you had add any mods like gauges or something near left kick panel wiring
robertoortiz85 is offline   Reply With Quote
Trickflow Heads & Cams FORDGT14 1996-2004 Mustang GT 29 04-18-2012 11:37 AM
Mods+broken back=sad me Silversky545 2005-2010 Mustang GT 9 03-03-2012 12:55 AM
B&M shifter StackeStang 1996-2004 Mustang GT 13 03-02-2012 01:04 AM
SLP axle back without muffler Runninpony 2011-2014 Mustang GT 1 02-29-2012 09:17 AM
Tech question about exhaust? Axle back bolt to Cat back? 2012Coyote 2011-2014 Mustang GT 3 02-28-2012 05:56 PM
06:35 PM
