Installing new head unit in 96 svt with mach 460 - Mustang Evolution
Old 03-27-2012, 07:43 AM   #1
Moose8878's Avatar
Hey guys Im trying to install an alpine head unit in my 1996 svt mystic cobra. I wired everything up with the wire kit they gave me at autozone. I installed two subs and two sub amps and was trying to leave the Mach 460 speakers the way they are. I have power at the headunit, it comes on and is playing. The subs work fine but I have no sound coming out of the 460 system. Anybody got any suggestions? O yea the wiring kit I got came with a flat gray plug and square black plug
[MOOSE]
Moose8878 is offline   Reply With Quote
Old 03-27-2012, 09:46 AM   #2
Titus Wadicus
svtlx's Avatar
Re: Installing new head unit in 96 svt with mach 460
there is a blue wire on the "car side" of the harness.. looks like a power remote wire. make sure it is wired to power remote on the stereo or at least getn 12 volts on ignition. i ran into this a couple days ago doin mine. im pretty sure it powers the cars amp or something.
hope this helps and good luck
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 03-28-2012, 07:29 AM   #3
yeah the blue wire in the harness you got from autozone is the remote control turns on the amps of the car just remember on your alpine has two wires blue and a blue/white strive wire use the blue white that's the amp turn on wire the other one blue turns on power antenas went cd/aux/ipot is selected anyways mustangs don't have power antenas
robertoortiz85 is offline   Reply With Quote
Old 03-28-2012, 09:56 AM   #4
Bamman's Avatar
i think ur problem might be just the harness.. if you go to walmart you can buy a premium aftermarket harness, its only $9 dollars at walmart then just do the usual matching the color wires. i just put a 12" JL in my car with a JVC(Jvc is real friendly with mach systems) and it spliced it perfectly with the already mach system and ran off the amp to the sub, and the 2 amps you have to power your tweets and all 4 6x8 door speakers.
Bamman is offline   Reply With Quote
Old 03-29-2012, 11:35 AM   #5
Moose8878's Avatar
Thxs guys u were right on money. I've never had a fancy car so I've never needed the wire except for sub amps. So Thxs a billion
[MOOSE]
Old 03-29-2012, 01:16 PM   #6
Bamman's Avatar
no problem.
Old 03-29-2012, 02:29 PM   #7
you welcome, in my threads in my profile I have the diagram to delete the mach system if you swap the original head unit or if system amps are not working any more
Old 03-29-2012, 03:11 PM   #8
Moose8878's Avatar
Thxs dude but everything works great rlly pleased with it
[MOOSE]
Old 04-09-2012, 12:36 AM   #9
Spiney's Avatar
Just for future reference when you put in the new head did you leave the Mach 460 CD and Cassette player in the dash? I have a 96 SVT Cobra with the Mach 460. Right now I'm happy with the system except for not having an input for iPhone. But someday I may want to upgrade. Thanks, Spiney
Spiney is offline   Reply With Quote
Old 04-09-2012, 06:39 AM   #10
Moose8878's Avatar
No I removed the cd player in favor for a place to keep my phone and iPods. That sucks bro my alpine only cost 160 and it links with my iPhone and I touch
[MOOSE]
Old 04-09-2012, 09:24 PM   #11
Spiney's Avatar
What was the total cost with harnesses etc. would it be easy to put old components back in? Did you use the Mach 460 amps?
I want to be able to return car to stock if a collector ever bought it. Mine is low miles and was a garage queen when I bought it. It has some upgrades but I have all of the original parts in like new condition. Thanks, Spiney-Dave
Old 04-11-2012, 05:30 AM   #12
Moose8878's Avatar
Idk the plastic install kit was like $30 at autozone. The wire harness came from autozone as well and was only $25. If u read towards the beginning of this thread you'll see were someone told me how to use the 460 amps with an aftermarket system. Returning the stock equipment is easy cause the autozone harness hard wires into aftermarket headunit but plugs into the stock car harness and is just as easy to remove. The only thing I can say I dislike about my whole system is the 460 speakers put out way to much treble, I turned my treble to -5 lol
[MOOSE]
Old 04-11-2012, 07:36 AM   #13
that's alittle to much what you pay, ussualy the kit cost 12.99 and harness same or even 8.99,
---------- Post added at 07:36 AM ---------- Previous post was at 07:31 AM ----------
is because like I mention the stock system works tru all four tweeters runed tru the headunits high output and the four 5x7 tru low pass outputs off the stock amps and went you change the headunit the highs are louder and lows sometimes really low and sound really bad so that's why the bypass is done to get that nice aftermarket sound
svt
You guys with tuners Kingmidas87 Pre-2005 V6 Mustang 48 04-08-2012 04:32 PM
Anyone rolling with 20inch on a lowered Pony? avengnd 2011-2014 Mustang GT 21 03-27-2012 09:52 PM
Finding tire width for new rims... DaYanks4Ev Pre-2005 V6 Mustang 9 03-26-2012 10:00 PM
New Stuff jjsg09 1996-2004 Mustang GT 7 03-26-2012 09:20 PM
Mach 1000 system. Head unit and subs an amps 1995boss Mustang Parts for Sale and Wanted 8 03-26-2012 07:23 PM
03:00 AM
