Sub not working! - Mustang Evolution
Old 04-17-2012, 01:14 PM   #1
Bamman's Avatar
Sub not working!
i just installed a new kenwood touch screen and the sub is wanting to play to the music, when i first plugged it in it worked for a minute or 2. then just all of a sudden cut out, and non of the wires were touched from before. any help?!
8 Cylinders Little Brother.
Bamman is offline   Reply With Quote
Old 04-17-2012, 01:28 PM   #2
Are we talking a aftermarket sub or factory? Start with power. Make sure you have 12v everywhere you should. If you do have power then measure the resistance and make sure that is correct.
Tec_ is offline   Reply With Quote
Old 04-17-2012, 01:30 PM   #3
mi03svt's Avatar
You dont have a mono amp do u? Assuming it it all aftermarket.
mi03svt is offline   Reply With Quote
Old 04-17-2012, 01:33 PM   #4
Bamman's Avatar
Re: Sub not working!
2 12inch subs, their not mine its a customers. but it worked for a few min then it all cut out i still get music but no sub. and all the wiring is fine.
Old 04-17-2012, 01:35 PM   #5
mi03svt's Avatar
Check amp fuses and any other inline fuses you have. Kinda amp you dealing with here?
Old 04-17-2012, 01:37 PM   #6
Bamman's Avatar
i checked all the fuses, i honestly couldnt tell ya. some off brand stuff.
Old 04-17-2012, 01:51 PM   #7
mi03svt's Avatar
I had the problem of having a 600 w mono amp hooked to two 12s after being told it should be big enough to push both speakers, it clearly wasnt. So we went and bought 2 channel with enough power and it worked just fine. It sounds like exactly the same problem we had, thats why i suggest makin sure you ars dealing with compatible equipment here.
Old 04-18-2012, 08:48 AM   #8
Bamman's Avatar
after trouble shooting for about 3 hours..... the amp was blown.
Old 04-18-2012, 09:10 AM   #9
MiGT01's Avatar
LoL damn...
01 Black Beauty GT
Eibach pro kit,Tokico shocks/struts,BBK CAI,75mm TB/ Plenum,4.10 FRPP gears,BBK o/r X pipe,Magnaflow Catback,SCT Tuner running 91 Tune,Bama Tunes for Life Member,RAM HD Clutch,BM shifter with MGW "GT" knob,AM smoked Headlights/Sylvania zXe bulbs,VHT smoked tails/3rd brake,Redtop Optima,Mach 1 grille delete,Mach 1 chin spoiler,BULLITT Pedals,20% tint all round,4.6 High Performance Badges
MiGT01 is offline   Reply With Quote
06:37 AM
