Mach 460 :$ - Mustang Evolution
Old 04-29-2012, 06:51 PM   #1
Jord05's Avatar
Mach 460 :$
Some one pls help me I bought new speakers for my mustang gt with the Mach 460 system how do I hook them up thanks for the help ppl
Jord05 is offline   Reply With Quote
Old 04-29-2012, 10:05 PM   #2
Easiest would be to get the speaker wire adaptor for your car. They run about $14 at bestbuy. Plugs into the stock harness and plugs into your speakers. Or you can google your speaker harness to find out what colors are positive and negative and clip the wire and solder it to your speakers.
Tec_ is offline   Reply With Quote
Old 04-29-2012, 10:12 PM   #3
Jord05's Avatar
Yeah I tried hooking the wires up but the speakers are real quite
Old 04-29-2012, 10:22 PM   #4
What all have you done?
Old 04-29-2012, 10:25 PM   #5
Jord05's Avatar
Just hooked up the tweeter and they sound really bad and I was stumped on how to hook up the other speaker
Old 04-29-2012, 10:49 PM   #6
Did you get component speakers? Or coaxial speakers?
Old 04-29-2012, 11:01 PM   #7
Jord05's Avatar
These are them
Old 04-29-2012, 11:45 PM   #8
Jord05's Avatar
Component. Soeakers
Old 04-30-2012, 11:10 AM   #9
Are you just replacing speakers and not using the crossovers?
Old 04-30-2012, 12:41 PM   #10
Jord05's Avatar
Whats a cross over ? I'm not real good with audio stuff I'm more about motors . So any pictures would be helpfully thanks tec
Old 04-30-2012, 01:47 PM   #11
The crossover is the box in the picture and according to the google this should be your speakers.
What I'm wondering is if your using the crossover how you have it hooked up.
Old 04-30-2012, 02:34 PM   #12
Jord05's Avatar
No mine didn't come wit the cross over
Old 04-30-2012, 03:19 PM   #13
If they are meant to be drop in replacements I would double check the polarity of the speakers and make sure you have them wired correctly. And I would also double check the impedance (resistance) of the stock speakers vs the new ones. That can cause speakers to not play correctly and a blown speaker can sometimes pull a amp in to protection mode.
Old 04-30-2012, 06:25 PM   #14
Jord05's Avatar
I may just bi pass the amp cause I can't figure it out
---------- Post added at 06:25 PM ---------- Previous post was at 06:09 PM ----------
Or should I put my stock back in?
Old 04-30-2012, 10:01 PM   #15
Measure the resistance of the stock and the resistance of the new speakers if they don't match they won't work. A little variance is ok but not a lot.
Also make sure your polarity is correct if the speakers are the same impedance.
Old 04-30-2012, 10:02 PM   #16
Jord05's Avatar
in English pls lol
Old 05-01-2012, 07:01 AM   #17
So take a digital multimeter and set it to resistance and attach the + lead to the + of the old speaker. Attach the - lead to the - of the speaker. Do the same with the new speakers. If the resistance dose not match like the pic i drew the speakers won't work.
This is what I found for the 2000 mustang I think that's what you have but its for a US mustang I think you're profile says your from Canada and the directechs I looked at didn't have anything for it.
So make sure your + speaker wire is attached to the + on the speaker and make sure none of your connections are exposed and touching bare metal.
Old 05-01-2012, 05:25 PM   #18
Jord05's Avatar
Ok I'll try it out tomorrow and I'll take some pics to show u
02:50 AM
